Best way to migrate from Razberry to Aeon USB
Quax1507
Post by Quax1507 »
I am thinking of migrating my old Razberry (no Plus) to an Aeon Gen.5 USB Controller.
I have about 100 devices in my Zwave network.
Is there any Migration path without re-inclusion of my existing devices?
Perhaps installing another PI with the Aeon as secondary Controller?
Has anybody done this before?
Thank You!
Regards,
Quax1507
Domosapiens
Domoticz version: V3.5981
Re: Best way to migrate from Razberry to Aeon USB
Post by Domosapiens »
Quax1507
Post by Quax1507 »
Thank You!
Are Zensys Tools available for Raspbian?
nizaga
Post by nizaga »
Did you ever find a solution for this? Is there any solution for instance to migrate from razberry 1 to razberry 2 without having to re-include all devices?
Quax1507
Post by Quax1507 »
I never found a solution for my problem.
I think Yours is different and solveable:
1. Take a Pi2 and install OS+Domoticz (clean)
2. Shutdown old Domoticz an Pi1
3. Copy complete /home/pi/domoticz from old Pi1 to ne Pi2
4. Remove Razberry module from Pi1 and plug it into Pi2
5. Start Domoticz on Pi2
Should work...
nizaga
Post by nizaga »
hi, thanks for your answer but i want to migrate the RAZBERRY not the Raspberry. I mean using a new generation razberry. Could i just substitute the hardware and that's it?
barbaar
Post by barbaar »
I just did this.. I migrated from a RPI3 with a Razberry to and Odroid with the Aeon gen 5 stick. So different Zwave controller and different Domoticz install..
What I did was firs adding the Aeon stick as a secondary controller to the network. After that I backed op my Domoticz database on the RPI and restored it on the Odroid. Last step was to make the Odroid (with Aeon stick) the primary controller. And this all worked!
I have not (yet) removed the (now secondary) Razberry controller..
