Ok so this is my setup.
Once I compared the test and live code I could see the extra character is dealt with in the live code so I am guessing I have not set up the domoticz devices properly.
The only device I have not added is the eco switch but I see the test script is showing as a valve... is this the problem?
As you can see I have two thermostats.
Any guidance much appreciated.
How can i debug the lua??
Rooms
Sitting Room 0F9642 109 111
Guest Bedroom 1560CA 109 111
Kitchen 10278A 110 101
Music Room 102784 109 111
Dressing Room 1027E0 109 111
Guest Bathroom 118612 109 111
Master Bathroom 10282C 109 111
Office 1184BB 101 99
Master Bedroom 1184C3 109 111
Devices
Kitchen-Stat 103417
Master Bathroom-Rad 10282C
Kitchen-Rad 10278A
Music Room Front-Rad 102784
Music Room Back-Rad 1184B9
Guest Bedroom Store-Rad 1555DD
Dressing Room-Rad 1027E0
Guest Bathroom-Rad 118612
Guest Bedroom-Rad 1560CA
Sitting Room-Stat 14E23D
Sitting Room Rear-Rad 0F964F
Sitting Room Front-Rad 0F9642
Office-Rad 1184BB
Eco Switch 0B3A8B
Master Bedroom-Rad 1184C3
Device status
Valve Guest Bathroom-Rad Setpoint=10 Temp=0 Valve pos=0 Battery=OK Mode=Auto
Valve Music Room Front-Rad Setpoint=10 Temp=0 Valve pos=0 Battery=OK Mode=Auto
Thermostat Sitting Room-Stat Setpoint=20.5 Temp=19.8 Valve pos=-1 Battery=OK Mode=Auto
Valve Master Bedroom-Rad Setpoint=10 Temp=0 Valve pos=0 Battery=OK Mode=Auto
Valve Sitting Room Rear-Rad Setpoint=20.5 Temp=0 Valve pos=100 Battery=OK Mode=Auto
Valve Eco Switch Setpoint=20.5 Temp=0 Valve pos=100 Battery=OK Mode=Auto
Valve Office-Rad Setpoint=10 Temp=0 Valve pos=0 Battery=OK Mode=Auto
Valve Music Room Back-Rad Setpoint=10 Temp=0 Valve pos=0 Battery=OK Mode=Auto
Valve Dressing Room-Rad Setpoint=10 Temp=0 Valve pos=0 Battery=OK Mode=Auto
Valve Master Bathroom-Rad Setpoint=10 Temp=0 Valve pos=0 Battery=OK Mode=Auto
Thermostat Kitchen-Stat Setpoint=22.5 Temp=17 Valve pos=-1 Battery=OK Mode=Auto
Valve Guest Bedroom Store-Rad Setpoint=10 Temp=0 Valve pos=0 Battery=OK Mode=Auto
Valve Sitting Room Front-Rad Setpoint=20.5 Temp=0 Valve pos=100 Battery=OK Mode=Auto
Valve Guest Bedroom-Rad Setpoint=10 Temp=0 Valve pos=0 Battery=OK Mode=Auto
Valve Kitchen-Rad Setpoint=22.5 Temp=0 Valve pos=100 Battery=OK Mode=Auto
