I can do a call to my hs server like:
http://192.168.1.123/jsonapi.asp?action ... ice&id=$31
Then i get:
{"id": "$31", "name": "CV-ketel", "room": "Zolder", "floor": "", "dimmable": onwaar, "status": 2, "value": 68, "since": "8-1-2017 10:20:40", "type": "Plugwise: CV-ketel", "status_support": onwaar, "misc": "65536"}
How do i get for example the "value" 68 (wich is watt)
In domoticz?
How to do this?
- Egregius
- Domoticz version: v2024.7
Re: How to do this?
Shell script executed by cron and jq to parse the json?
- G3rard
- Target OS: -
- Domoticz version: No
Re: How to do this?
You can use the HTTP/HTTPS Poller in the Domoticz hardware section. See the following url.
http://www.domoticz.com/forum/viewtopic ... 6&p=112529
There are some example LUA files which you can use in the scripts/lua_parsers directory.
In your case you can use the example_json.lua.
It's a great function and you can all control it from Domoticz, also the interval.
Recently some extra features have been added.
http://www.domoticz.com/forum/viewtopic ... 2&p=112629
Not using Domoticz anymore
edwin1234
- Domoticz version: 2021.1
Re: How to do this?
Thanks for your answers.
Is it also possible with node red?
And if so can you give an example of a node red flow?
