Cheap chinese z-wave products
trixwood
Re: Cheap chinese z-wave products
Post by trixwood »
Too bad that sticker on the photo is not on the actual plug. And their non existing specification tab on their website is also not a great help. Besides I ordered us versions for use in those area's. Is that also the same with 110v?
Pierryck
Post by Pierryck »
A quick feedback on my first chinese products: I have installed 3 power plug and 2 door/windows sensors from Neo coolcam and they all work fine with domoticz.
mschut
Domoticz version: V3.5613
Re: RE: Re: Cheap chinese z-wave products
Post by mschut »
trixwood wrote:That's quoting from an unverified source. According to the box max is 12A (i am a bit rusty, correct me if I am wrong, but that makes it at 230V: 2760 Watt)
Tanks, I am even a bit more rusty probably ;). This helps, explains even why my oven is shutting the plug down (3.5 kW).
However, after two plugs completely dying on my fridge I do not dare to try a third. But with 180W this cannot be the cause. Or, could a non grounded plug be the cause? It is grounded, but just for the sake of options it could be that the ground on this socket is not connected well.
Verstuurd vanaf mijn SM-G920F met Tapatalk
zalsson
Re: RE: Re: RE: Re: Cheap chinese z-wave products
Post by zalsson »
The plug that died for me is the only one that was connected with ground...
Skickat från min A0001 via Tapatalk
mschut
Re: RE: Re: RE: Re: RE: Re: Cheap chinese z-wave products
Post by mschut »
zalsson wrote: The plug that died for me is the only one that was connected with ground...
Did you try another plug on the same socket successful afterwards?
zalsson
Post by zalsson »
No didn't want it to die :) so skipped it, will try when the replacement comes.
mschut
Post by mschut »
Smart. I did, unsuccessful though... However, my theory was that it was a malfunctional plug. However, two dying plugs is no incident anymore. So something in the situation causing it to die, rather than a unlucky bad manufactured plug.
sincze
Domoticz version: 2024.4
Post by sincze »
trixwood wrote:Too bad that sticker on the photo is not on the actual plug. And their non existing specification tab on their website is also not a great help. Besides I ordered us versions for use in those area's. Is that also the same with 110v?
Jups I spotted the difference blue vs sticker. Ah well it's Chinese products may differ after any batch production. whats on the box is only what's on the box not inside :) I would stay in the safe side. Image with the sticker it mimics the Fibaro
Sent from my SM-G925F using Tapatalk
Pass2php
USB: RFXCom, ZWave, Sonoff 3
MQTT: ZIgbee2MQTT,
ZWAVE: Zwave-JS-UI
Solar: Omnik, PVOutput
Sensors: You name it I got 1.
sincze
Post by sincze »
mschut wrote:Smart. I did, unsuccessful though... However, my theory was that it was a malfunctional plug. However, two dying plugs is no incident anymore. So something in the situation causing it to die, rather than a unlucky bad manufactured plug.
Should I watch out connecting these plugs to grounded sockets? All of my sockets are grounded and most devices I use SCHUKO as well. Except for my OTGW that has a flat EU connector ??
Pass2php
MQTT: ZIgbee2MQTT,
ZWAVE: Zwave-JS-UI
zalsson
Post by zalsson »
No if it work it work, should not be a problem to use with grounded socket.
I hope I just was unlucky.
jf2020
Post by jf2020 »
mschut wrote:However, after two plugs completely dying on my fridge I do not dare to try a third. But with 180W this cannot be the cause. Or, could a non grounded plug be the cause? It is grounded, but just for the sake of options it could be that the ground on this socket is not connected well.
The issue is that your fridge is asking for much, much more than 180W when the compressor is starting (can be 10-15 amps or more depending on the compressor - some use a starting capacitor others have a special windings). This a well-known issue with inductive loads (i.e. motors) especially with fridge compressors. So it is relatively likely that the surge when powering it on is frying the plug,
mschut
Post by mschut »
Thanks. A technical explanation what my belly was thinking. Won't try another one ;)
Luigi87
Post by Luigi87 »
You are right 230V * 12A = 2760 Watt.
But i would not go higher than 10A on the plugs (they are from china after all).
It is a bit weird they die on you.
I have 4 plug in use, 2 are grounded and in use for my washing machine and dryer (no problems here), and 2 plug for 2 lamps who are not grounded.
I had also one plug who was bad, he died on me when useing it in an ungrounded lamp.
Cooling compressors are always a pain in the ..... they common have a high startup spike, which is not measured by simple current meters
LouiS22
Post by LouiS22 »
Just a quick note: according to domoticz github, latest beta (6327) contains an OZW update, among other things the Neo Siren and Motion Sensor got an updated xml. I remember some of us had problems with these devices. I don't own these ones, so can't tell what's working or not though.
Luigi87
Post by Luigi87 »
LouiS22 wrote:Just a quick note: according to domoticz github, latest beta (6327) contains an OZW update, among other things the Neo Siren and Motion Sensor got an updated xml. I remember some of us had problems with these devices. I don't own these ones, so can't tell what's working or not though.
Ah nice, i have a sirene divice whitout parameters.
But i am a bit reserved about running the Beta versions. Don't like to introduce (more) bugs in my system.
LouiS22
Post by LouiS22 »
you can always grab the relevant xmls to test your gear ;)
Luigi87
Post by Luigi87 »
How does this works? I know how to place a XML in the Open Z-wave folder, but not to get it from the Domoticz data.
And when the XML is in the folder, do i need to exclude and include the sirene again?
LouiS22
Post by LouiS22 »
Ithink you have to exclude, so do that.
1. make a backup of your manufacturer_specific.xml.
2. Then visit domoticz github: https://github.com/domoticz/domoticz/tree/master/Config
3. grab the manufacturer_specific.xml and the files from shenzen_neo folder.
4. Place the neo folder files into your neo folder files
5. place the new specific.xml
6. reboot your pi
7. include your device
Hopefully you'll have a fully working stuff.
kman
Post by kman »
Hi All,
Thanks for all the super info in this thread.
@Louis: Thank you for the starting the discussion on chinese sensors. Following which I have ordered PIR, Door, and Water leakage sensors.
(there is so much going on in this thread, it is a little dizzing to get this info, if everything is OK with this chinese PIR and Door - as I awaiting mine to be delivered)
Btw, it's also nice to see the open-zwave has already added the necessary configuration for these (just need to grab them, when I have my sensors arrive)
+ .../open-zwave-master/config/manufacturer_specific.xml
+ "shenzen_neo/nas-ds01z.xml
+ "shenzen_neo/nas-pd01z.xml"
So, two quick questions:
1. So, is the performance of chinese PIR and Door sensor reliable?
2. Also, has someone tried to use these chinese sensors in combination with TKB range extender & does it work well?
thanks again.
Luigi87
Post by Luigi87 »
LouiS22 wrote:Ithink you have to exclude, so do that.
6. reboot your pi
Thanks i will try to fix this tonight :D
