Installation on OSX El Capitan
KristianO
Target OS: OS X
Post by KristianO »
Hi!
Im very new to Domoticz and would very much appriciate of someone could help me out with an installation of Domoticz on a OSX server.
I tried the following steps:
1. Download Xcode from the Mac App Store. When it’s download launch it.
2. Download and install MacPorts – you can find this by Googling it. We installed the version for Mac OS Mavericks
3. In Terminal run this command: sudo port selfupdate
4. In Terminal run: sudo port upgrade outdated
5. Run: sudo port install cmake
6. Run: sudo port install boost
7. Run: sudo port install libusb
8. Run: sudo port install libusb-compat
9: git clone https://github.com/domoticz/domoticz.git domoticz (installed under /Users/kristian/Library/domoticz/
10. Run: cd domoticz
11. Run: cmake CMakeLists.txt
At step 11 i get the following error:
Boost version: 1.59.0
Boost include path: /opt/local/include
Could not find the following static Boost libraries:
boost_thread
boost_date_time
How to proceed?
gizmocuz
Re: Installation on OSX El Capitan
Post by gizmocuz »
you can try to download the OSx version here:
http://www.domoticz.com/releases/?dir=beta
and install it like:
   mkdir ~/domoticz
   cd ~/domoticz
   wget http://www.domoticz.com/releases/domoticz_osx_x86_64_latest.tgz
   tar domoticz_osx_x86_64_latest.tgz
   rm domoticz_osx_x86_64_latest.tgz
then start it with
./domoticz
KristianO
Target OS: OS X
Post by KristianO »
Thanks alot for your replay!
After i did all the steps i get the following in the execution.
MACMINI:domoticz kristianolofsson$ ./domoticz
dyld: Library not loaded: /usr/local/lib/libusb-0.1.4.dylib
Referenced from: /Users/kristianolofsson/domoticz/./domoticz
Reason: image not found
Trace/BPT trap: 5
I also tried all the prev. steps again wo any problems. It seems like a problem in finding the libusb?
bellyd
Post by bellyd »
I had the same problem with Boost v1.59. I managed to work around it by using Boost 1.58 iso 1.59. Check my post of Nov 8th 2015: viewtopic.php?f=6&t=2581
NOTE: this will only work if you have 1.58 installed. I didn't find an easy way to retrieve an old(er) version via macports. What you can you is uninstall macports (see the macports wiki) and follow the homebrew instructions. This gave me a working Domoticz server today on El Capitan 10.11.2.
Success!
RPi 4B 4GB -- Oregon Scientific sensors -- KAKU switches -- MoreSense CO2 sensor --
zwaveJS2mqtt/z-wave.me UZB1 USB stick (z-wave+)/Aeotec Smart Switch 6/Fibaro FGWPEF-102 Switches
rotax
Target OS: OS X
Post by rotax »
open command line in Os X and type:
1) ruby -e "$(curl -fsSL https://raw.githubusercontent.com/Homeb ... er/install)" < /dev/null 2> /dev/null
2) brew install libusb-compat
3) brew install openssl
after these three steps Domoticz should run. I have done that in Sierra and it works fine.
trixwood
Post by trixwood »
How did you get the new plugin system compiled?
I found the option to disable it, but I have no idea how to include it...
Users browsing this forum: cmisip and 1 guest
