homebridge-edomoticz Plugin
- G3rard
- Target OS: -
- Domoticz version: No
Re: homebridge-edomoticz Plugin
@TheRamon, the dimlevel is indeed fixed in the plugin, but that was a 'dirty' fix as it seems to be wrong at Domoticz side. Was just wondering if you had a look at the mqtt part of Domoticz. But nothing important as it is working now. Will have a look at it myself as well.
Not using Domoticz anymore
Hi,TheRamon wrote: @Awst6000:
Heya, just tested "roomid", my room ID is 2 and seems to be working.
The parameter roomID works correct, but the parameter loadscenes = 1 doesn't help to get my Domoticz groups and scenes in Elgato Eve.
Is it possible that I don't have the most recent version of HomeBridge? Can I check this with <npm -g outdated>?
I tried some workarounds for the groups/scenes, but no luck so far.
Txs.
- TheRamon
- Domoticz version: BETA
Ahhhh!! Thanks for reminding me. You're right, it kind of was a dirty fix doing +1 on all.G3rard wrote:@TheRamon, the dimlevel is indeed fixed in the plugin, but that was a 'dirty' fix as it seems to be wrong at Domoticz side. Was just wondering if you had a look at the mqtt part of Domoticz. But nothing important as it is working now. Will have a look at it myself as well.
Right! Never used that parameter myself, didn't even know it existed. Will have a look after Christmas, see if there is any way to kind of "import" those. If that parameter exists but doesn't work, I'll try and fix it.Awst6000 wrote:Hi,TheRamon wrote: @Awst6000:
Txs.
I also tried the parameter usescenes, but still no luck.
Happy Christmas!
Happy Christmas!
Hi, first of all thanks for the impressive work you made. it was very simple to get up and running all the system. I have various sensor and switch added in domoticz via OpenZ-wave (razberry 2 board) and seems that all work good. Now i want to know if it's possible to change the way that homebridge see a switch, i use one of them to open my door, anche from siri now i have to say "Turn on Principal Door" instead of "open Principal Door". Because Siri recognize the command open but she (it?) can't associate to a door opener actuator, i want to know if it's possible to change that switch to a door opener.
Sorry for my very poor english.
After about 3 days working reacts home on the iPhone anymore. Can not connect. Restart Domoticz solves the problem.
Is there a solution to restart home bridge automatically?
Hi there, are there any forthcoming plans for full bi-directional secpanel support? Today it's working only from domoticz to Home, not the other way round. It would be awesome that I can switch the secpanel from within Home
Verzonden vanaf mijn iPad met Tapatalk
Ok sorry for the late answerTheRamon wrote:@phobosman:
So i try to identifie the problem
i start homebridge with full debug
All debug
[33;1mAccessory [0m[Navez House] Got Characteristic "On" value: 1 [33m+0ms[0m
[33;1mAccessory [0m[Navez House] Getting value for Characteristic "On" [33m+0ms[0m
[33;1mAccessory [0m[Navez House] Getting value for Characteristic "Target Position" [33m+0ms[0m
[33;1mAccessory [0m[Navez House] Got Characteristic "Target Position" value: 53 [33m+0ms[0m
[35;1mEventedHTTPServer [0m[::ffff:10.0.0.240] Sending HTTP event '39.10' with data: {"characteristics":[{"aid":39,"iid":10,"value":53}]} [35m+0ms[0m
[35;1mEventedHTTPServer [0m[::ffff:10.0.0.128] Muting event '39.10' notification for this connection since it originated here. [35m+1ms[0m
[33;1mAccessory [0m[Navez House] Getting value for Characteristic "Current Position" [33m+0ms[0m
[33;1mAccessory [0m[Navez House] Got Characteristic "Current Position" value: 53 [33m+0ms[0m
[35;1mEventedHTTPServer [0m[::ffff:10.0.0.128] Muting event '39.9' notification for this connection since it originated here. [35m+0ms[0m
[33;1mAccessory [0m[Navez House] Getting value for Characteristic "On" [33m+1ms[0m
[33;1mAccessory [0m[Navez House] Getting value for Characteristic "Current Temperature" [33m+0ms[0m
[33;1mAccessory [0m[Navez House] Getting value for Characteristic "Motion Detected" [33m+1ms[0m
[33;1mAccessory [0m[Navez House] Got Characteristic "Motion Detected" value: false [33m+0ms[0m
[37m[12/31/2016, 10:27:37 AM][39m [36m[eDomoticz][39m Data Received for Seche Linge.
[33;1mAccessory [0m[Navez House] Got Characteristic "On" value: 0 [33m+19ms[0m
[37m[12/31/2016, 10:27:37 AM][39m [36m[eDomoticz][39m Data Received for Cafetiere.
[33;1mAccessory [0m[Navez House] Got Characteristic "On" value: 0 [33m+0ms[0m
[37m[12/31/2016, 10:27:37 AM][39m [36m[eDomoticz][39m Data Received for Emy volet.
[37m[12/31/2016, 10:27:37 AM][39m [36m[eDomoticz][39m Data Received for Emy volet: 100
[37m[12/31/2016, 10:27:37 AM][39m [36m[eDomoticz][39m Data Received for Jules volet.
[37m[12/31/2016, 10:27:37 AM][39m [36m[eDomoticz][39m Data Received for Jules volet: 100
[37m[12/31/2016, 10:27:37 AM][39m [36m[eDomoticz][39m Data Received for Télévision.
[33;1mAccessory [0m[Navez House] Got Characteristic "On" value: 0 [33m+2ms[0m
[37m[12/31/2016, 10:27:37 AM][39m [36m[eDomoticz][39m Data Received for Sirene Maison.
[33;1mAccessory [0m[Navez House] Got Characteristic "On" value: 0 [33m+1ms[0m
[37m[12/31/2016, 10:27:37 AM][39m [36m[eDomoticz][39m Data Received for Camera maison.
[37m[12/31/2016, 10:27:37 AM][39m [36m[eDomoticz][39m Data Received for tele volet.
[37m[12/31/2016, 10:27:37 AM][39m [36m[eDomoticz][39m Data Received for tele volet: 100
[37m[12/31/2016, 10:27:37 AM][39m [36m[eDomoticz][39m Data Received for Cuisine.
[37m[12/31/2016, 10:27:37 AM][39m [36m[eDomoticz][39m Data Received for Cellier volet.
[37m[12/31/2016, 10:27:37 AM][39m [36m[eDomoticz][39m Data Received for Cellier volet: 100
[37m[12/31/2016, 10:27:37 AM][39m [36m[eDomoticz][39m Data Received for garage.
[37m[12/31/2016, 10:27:37 AM][39m [36m[eDomoticz][39m Data Received for garage: 1
[33;1mAccessory [0m[Navez House] Got Characteristic "Lock Current State" value: 1 [33m+1ms[0m
[33;1mAccessory [0m[Navez House] Got Characteristic "Lock Target State" value: 1 [33m+0ms[0m
[37m[12/31/2016, 10:27:37 AM][39m [36m[eDomoticz][39m Data Received for Parent volet.
[37m[12/31/2016, 10:27:37 AM][39m [36m[eDomoticz][39m Data Received for Parent volet: 100
[37m[12/31/2016, 10:27:37 AM][39m [36m[eDomoticz][39m Data Received for Camera jardin.
[37m[12/31/2016, 10:27:37 AM][39m [36m[eDomoticz][39m Data Received for Escalier.
[37m[12/31/2016, 10:27:37 AM][39m [36m[eDomoticz][39m Data Received for Cuisine volet.
[37m[12/31/2016, 10:27:37 AM][39m [36m[eDomoticz][39m Data Received for Cuisine volet: 100
[37m[12/31/2016, 10:27:37 AM][39m [36m[eDomoticz][39m Data Received for Derrière.
[37m[12/31/2016, 10:27:37 AM][39m [36m[eDomoticz][39m Data Received for Off.
[37m[12/31/2016, 10:27:37 AM][39m [36m[eDomoticz][39m Data Received for Camera porte.
[37m[12/31/2016, 10:27:37 AM][39m [36m[eDomoticz][39m Data Received for Camera emy.
[37m[12/31/2016, 10:27:37 AM][39m [36m[eDomoticz][39m Data Received for presence.
[37m[12/31/2016, 10:27:37 AM][39m [36m[eDomoticz][39m Data Received for Internet Jules.
[37m[12/31/2016, 10:27:37 AM][39m [36m[eDomoticz][39m Data Received for Lave vaisselle.
[37m[12/31/2016, 10:27:37 AM][39m [36m[eDomoticz][39m Data Received for salle a manger volet.
[37m[12/31/2016, 10:27:37 AM][39m [36m[eDomoticz][39m Data Received for salle a manger volet: 53
[37m[12/31/2016, 10:27:37 AM][39m [36m[eDomoticz][39m Data Received for radiateur sdb.
[37m[12/31/2016, 10:27:37 AM][39m [36m[eDomoticz][39m Data Received for Camera chemin.
[37m[12/31/2016, 10:27:37 AM][39m [36m[eDomoticz][39m Data Received for Temp Ext Devant.
[37m[12/31/2016, 10:27:37 AM][39m [36m[eDomoticz][39m Data Received for Temp Ext Devant: 1.4
[33;1mAccessory [0m[Navez House] Got Characteristic "Current Temperature" value: 1.4 [33m+0ms[0m
[37m[12/31/2016, 10:27:37 AM][39m [36m[eDomoticz][39m Data Received for Camera garage.
[37m[12/31/2016, 10:27:37 AM][39m [36m[eDomoticz][39m Data Received for Camera Devant.
[37m[12/31/2016, 10:27:37 AM][39m [36m[eDomoticz][39m Data Received for Camera derriere.
[37m[12/31/2016, 10:27:37 AM][39m [36m[eDomoticz][39m Data Received for lampe Télé.
[37m[12/31/2016, 10:27:37 AM][39m [36m[eDomoticz][39m Data Received for Camera parking.
[37m[12/31/2016, 10:27:37 AM][39m [36m[eDomoticz][39m Data Received for Temp Ext.
[37m[12/31/2016, 10:27:37 AM][39m [36m[eDomoticz][39m Data Received for Temp Ext: -0.8
[33;1mAccessory [0m[Navez House] Got Characteristic "Current Temperature" value: -0.8 [33m+1ms[0m
[37m[12/31/2016, 10:27:37 AM][39m [36m[eDomoticz][39m Data Received for Salon.
[37m[12/31/2016, 10:27:37 AM][39m [36m[eDomoticz][39m Data Received for Protection.
[37m[12/31/2016, 10:27:37 AM][39m [36m[eDomoticz][39m Data Received for Devant.
[35;1mEventedHTTPServer [0m[::ffff:10.0.0.128] HTTP Response is finished [35m+0ms[0m
[37m[12/31/2016, 10:27:40 AM][39m [36m[eDomoticz][39m MQTT Message received for Temp Salon.
[35;1mEventedHTTPServer [0m[::ffff:10.0.0.240] Sending HTTP event '30.9' with data: {"characteristics":[{"aid":30,"iid":9,"value":17.5}]} [35m+13s[0m
[35;1mEventedHTTPServer [0m[::ffff:10.0.0.128] Sending HTTP event '30.9' with data: {"characteristics":[{"aid":30,"iid":9,"value":17.5}]} [35m+0ms[0m
[35;1mEventedHTTPServer [0m[::ffff:10.0.0.224] HTTP request: /characteristics [35m+267ms[0m
[35;1mHAPServer [0m[CC:21:3E:E4:DE:31] HAP Request: PUT /characteristics [35m+0ms[0m
[33;1mAccessory [0m[Navez House] Processing characteristic set: [{"aid":12,"iid":9,"ev":false}] [33m+0ms[0m
[33;1mAccessory [0m[Navez House] Unregistering Characteristic "Current Position" for events [33m+0ms[0m
[35;1mEventedHTTPServer [0m[::ffff:10.0.0.224] HTTP Response is finished [35m+0ms[0m
[35;1mEventedHTTPServer [0m[::ffff:10.0.0.224] HTTP request: /characteristics [35m+7ms[0m
[33;1mAccessory [0m[Navez House] Processing characteristic set: [{"aid":14,"iid":9,"ev":false}] [33m+0ms[0m
[35;1mEventedHTTPServer [0m[::ffff:10.0.0.224] HTTP request: /characteristics [35m+5ms[0m
[33;1mAccessory [0m[Navez House] Processing characteristic set: [{"aid":18,"iid":9,"ev":false}] [33m+0ms[0m
[35;1mEventedHTTPServer [0m[::ffff:10.0.0.224] HTTP request: /characteristics [35m+86ms[0m
[33;1mAccessory [0m[Navez House] Processing characteristic set: [{"aid":21,"iid":9,"ev":false}] [33m+0ms[0m
[35;1mEventedHTTPServer [0m[::ffff:10.0.0.224] HTTP request: /characteristics [35m+12ms[0m
[33;1mAccessory [0m[Navez House] Processing characteristic set: [{"aid":24,"iid":9,"ev":false}] [33m+0ms[0m
[35;1mEventedHTTPServer [0m[::ffff:10.0.0.224] HTTP request: /characteristics [35m+8ms[0m
[33;1mAccessory [0m[Navez House] Processing characteristic set: [{"aid":35,"iid":9,"ev":true}] [33m+0ms[0m
[33;1mAccessory [0m[Navez House] Registering Characteristic "Lock Current State" for events [33m+0ms[0m
[35;1mEventedHTTPServer [0m[::ffff:10.0.0.224] HTTP Response is finished [35m+1ms[0m
[33;1mAccessory [0m[Navez House] Processing characteristic set: [{"aid":39,"iid":9,"ev":false}] [33m+0ms[0m
[33;1mAccessory [0m[Navez House] Processing characteristic set: [{"aid":41,"iid":9,"ev":false}] [33m+0ms[0m
[35;1mEventedHTTPServer [0m[::ffff:10.0.0.224] HTTP request: /characteristics [35m+338ms[0m
[33;1mAccessory [0m[Navez House] Processing characteristic set: [{"aid":45,"iid":9,"ev":true}] [33m+0ms[0m
[33;1mAccessory [0m[Navez House] Registering Characteristic "Motion Detected" for events [33m+0ms[0m
[37m[12/31/2016, 10:28:02 AM][39m [36m[eDomoticz][39m MQTT Message received for Temp Parent.
[35;1mEventedHTTPServer [0m[::ffff:10.0.0.240] Sending HTTP event '46.9' with data: {"characteristics":[{"aid":46,"iid":9,"value":14.2}]} [35m+11s[0m
[35;1mEventedHTTPServer [0m[::ffff:10.0.0.128] Sending HTTP event '46.9' with data: {"characteristics":[{"aid":46,"iid":9,"value":14.2}]} [35m+0ms[0m
[35;1mEventedHTTPServer [0m[::ffff:10.0.0.128] HTTP request: /characteristics [35m+5s[0m
[33;1mAccessory [0m[Navez House] Processing characteristic set: [{"aid":39,"iid":10,"value":0}] [33m+0ms[0m
[33;1mAccessory [0m[Navez House] Setting Characteristic "Target Position" to value 0 [33m+1ms[0m
[35;1mEventedHTTPServer [0m[::ffff:10.0.0.240] Sending HTTP event '39.10' with data: {"characteristics":[{"aid":39,"iid":10,"value":0}]} [35m+1ms[0m
[35;1mEventedHTTPServer [0m[::ffff:10.0.0.128] Muting event '39.10' notification for this connection since it originated here. [35m+0ms[0m
[35;1mEventedHTTPServer [0m[::ffff:10.0.0.128] Sending HTTP event '39.9' with data: {"characteristics":[{"aid":39,"iid":9,"value":0}]} [35m+1ms[0m
[35;1mEventedHTTPServer [0m[::ffff:10.0.0.128] HTTP Response is finished [35m+1ms[0m
[35;1mEventedHTTPServer [0m[::ffff:10.0.0.128] Writing pending HTTP event data [35m+0ms[0m
[37m[12/31/2016, 10:28:07 AM][39m [36m[eDomoticz][39m MQTT Message received for salle a manger volet.
Name: salle a manger volet
Device: Lighting 2,AC
Is Switch: true
SwitchTypeVal: 16
MQTT Message:
"Battery": 255,
"RSSI": 12,
"dtype": "Lighting 2",
"id": "0010000",
"idx": 505,
"name": "salle a manger volet",
"nvalue": 0,
"stype": "AC",
"svalue1": "0",
"switchType": "Blinds Percentage Inverted",
"unit": 1
[35;1mEventedHTTPServer [0m[::ffff:10.0.0.128] HTTP request: /characteristics [35m+23s[0m
[35;1mHAPServer [0m[D2:C1:77:FA:F5:F0] HAP Request: PUT /characteristics [35m+0ms[0m
[33;1mAccessory [0m[8-chemin] Processing characteristic set: [{"aid":1,"iid":21,"ev":true}] [33m+0ms[0m
[33;1mAccessory [0m[8-chemin] Registering Characteristic "Streaming Status" for events [33m+0ms[0m
[35;1mEventedHTTPServer [0m[::ffff:10.0.0.128] HTTP request: /characteristics?id=1.21 [35m+4ms[0m
[35;1mHAPServer [0m[D2:C1:77:FA:F5:F0] HAP Request: GET /characteristics?id=1.21 [35m+0ms[0m
[33;1mAccessory [0m[8-chemin] Getting value for Characteristic "Streaming Status" [33m+1ms[0m
[33;1mAccessory [0m[8-chemin] Got Characteristic "Streaming Status" value: AQEA [33m+0ms[0m
[35;1mEventedHTTPServer [0m[::ffff:10.0.0.128] HTTP request: /characteristics [35m+7ms[0m
[33;1mAccessory [0m[8-chemin] Processing characteristic set: [{"aid":1,"iid":14,"ev":true}] [33m+0ms[0m
[35;1mEventedHTTPServer [0m[::ffff:10.0.0.128] HTTP request: /characteristics?id=1.14 [35m+3ms[0m
[35;1mHAPServer [0m[D2:C1:77:FA:F5:F0] HAP Request: GET /characteristics?id=1.14 [35m+0ms[0m
[35;1mEventedHTTPServer [0m[::ffff:10.0.0.128] HTTP request: /characteristics [35m+62ms[0m
[35;1mHAPServer [0m[48:6E:89:12:55:32] HAP Request: PUT /characteristics [35m+0ms[0m
[33;1mAccessory [0m[7-jardin] Processing characteristic set: [{"aid":1,"iid":14,"ev":true}] [33m+0ms[0m
[33;1mAccessory [0m[7-jardin] Registering Characteristic "Streaming Status" for events [33m+0ms[0m
[35;1mEventedHTTPServer [0m[::ffff:10.0.0.128] HTTP request: /characteristics?id=1.14 [35m+4ms[0m
[35;1mHAPServer [0m[48:6E:89:12:55:32] HAP Request: GET /characteristics?id=1.14 [35m+0ms[0m
[33;1mAccessory [0m[7-jardin] Getting value for Characteristic "Streaming Status" [33m+0ms[0m
[33;1mAccessory [0m[7-jardin] Got Characteristic "Streaming Status" value: AQEA [33m+0ms[0m
[35;1mEventedHTTPServer [0m[::ffff:10.0.0.128] HTTP request: /characteristics [35m+4ms[0m
[33;1mAccessory [0m[7-jardin] Processing characteristic set: [{"aid":1,"iid":21,"ev":true}] [33m+0ms[0m
[35;1mEventedHTTPServer [0m[::ffff:10.0.0.128] HTTP request: /characteristics?id=1.21 [35m+5ms[0m
[35;1mHAPServer [0m[48:6E:89:12:55:32] HAP Request: GET /characteristics?id=1.21 [35m+0ms[0m
[35;1mEventedHTTPServer [0m[::ffff:10.0.0.128] HTTP request: /characteristics [35m+25ms[0m
[35;1mHAPServer [0m[94:79:E9:70:CE:A7] HAP Request: PUT /characteristics [35m+0ms[0m
[33;1mAccessory [0m[6-derriere] Processing characteristic set: [{"aid":1,"iid":21,"ev":true}] [33m+0ms[0m
[33;1mAccessory [0m[6-derriere] Registering Characteristic "Streaming Status" for events [33m+0ms[0m
[35;1mHAPServer [0m[94:79:E9:70:CE:A7] HAP Request: GET /characteristics?id=1.21 [35m+1ms[0m
[33;1mAccessory [0m[6-derriere] Getting value for Characteristic "Streaming Status" [33m+0ms[0m
[33;1mAccessory [0m[6-derriere] Got Characteristic "Streaming Status" value: AQEA [33m+0ms[0m
[35;1mEventedHTTPServer [0m[::ffff:10.0.0.128] HTTP request: /characteristics [35m+3ms[0m
[33;1mAccessory [0m[6-derriere] Processing characteristic set: [{"aid":1,"iid":14,"ev":true}] [33m+1ms[0m
[35;1mEventedHTTPServer [0m[::ffff:10.0.0.128] HTTP request: /characteristics?id=1.14 [35m+5ms[0m
[35;1mHAPServer [0m[94:79:E9:70:CE:A7] HAP Request: GET /characteristics?id=1.14 [35m+0ms[0m
[35;1mEventedHTTPServer [0m[::ffff:10.0.0.128] HTTP request: /characteristics [35m+21ms[0m
[35;1mHAPServer [0m[8A:95:DB:7D:70:42] HAP Request: PUT /characteristics [35m+0ms[0m
[33;1mAccessory [0m[Motion Zoneminder] Processing characteristic set: [{"aid":1,"iid":12,"ev":true}] [33m+0ms[0m
[33;1mAccessory [0m[Motion Zoneminder] Registering Characteristic "Streaming Status" for events [33m+0ms[0m
[35;1mHAPServer [0m[29:88:F1:A7:76:29] HAP Request: PUT /characteristics [35m+0ms[0m
[33;1mAccessory [0m[5-emy] Processing characteristic set: [{"aid":1,"iid":21,"ev":true}] [33m+0ms[0m
[33;1mAccessory [0m[5-emy] Registering Characteristic "Streaming Status" for events [33m+0ms[0m
[35;1mEventedHTTPServer [0m[::ffff:10.0.0.128] HTTP request: /characteristics?id=1.12 [35m+1ms[0m
[35;1mHAPServer [0m[8A:95:DB:7D:70:42] HAP Request: GET /characteristics?id=1.12 [35m+0ms[0m
[33;1mAccessory [0m[Motion Zoneminder] Getting value for Characteristic "Streaming Status" [33m+0ms[0m
[33;1mAccessory [0m[Motion Zoneminder] Got Characteristic "Streaming Status" value: AQEA [33m+0ms[0m
[35;1mHAPServer [0m[29:88:F1:A7:76:29] HAP Request: GET /characteristics?id=1.21 [35m+0ms[0m
[33;1mAccessory [0m[5-emy] Getting value for Characteristic "Streaming Status" [33m+0ms[0m
[33;1mAccessory [0m[5-emy] Got Characteristic "Streaming Status" value: AQEA [33m+0ms[0m
[35;1mEventedHTTPServer [0m[::ffff:10.0.0.128] HTTP request: /characteristics [35m+2ms[0m
[35;1mHAPServer [0m[C7:01:D3:87:04:D0] HAP Request: PUT /characteristics [35m+1ms[0m
[33;1mAccessory [0m[4-garage] Processing characteristic set: [{"aid":1,"iid":21,"ev":true}] [33m+0ms[0m
[33;1mAccessory [0m[4-garage] Registering Characteristic "Streaming Status" for events [33m+0ms[0m
[35;1mHAPServer [0m[0B:1D:55:87:00:64] HAP Request: PUT /characteristics [35m+0ms[0m
[33;1mAccessory [0m[3-maison] Processing characteristic set: [{"aid":1,"iid":14,"ev":true}] [33m+1ms[0m
[33;1mAccessory [0m[3-maison] Registering Characteristic "Streaming Status" for events [33m+0ms[0m
[35;1mEventedHTTPServer [0m[::ffff:10.0.0.128] HTTP request: /characteristics [35m+1ms[0m
[33;1mAccessory [0m[5-emy] Processing characteristic set: [{"aid":1,"iid":14,"ev":true}] [33m+0ms[0m
[35;1mEventedHTTPServer [0m[::ffff:10.0.0.128] HTTP request: /characteristics?id=1.21 [35m+1ms[0m
[35;1mHAPServer [0m[C7:01:D3:87:04:D0] HAP Request: GET /characteristics?id=1.21 [35m+0ms[0m
[33;1mAccessory [0m[4-garage] Getting value for Characteristic "Streaming Status" [33m+0ms[0m
[33;1mAccessory [0m[4-garage] Got Characteristic "Streaming Status" value: AQEA [33m+0ms[0m
[35;1mHAPServer [0m[7D:50:91:D6:20:0A] HAP Request: PUT /characteristics [35m+0ms[0m
[33;1mAccessory [0m[2-parking] Processing characteristic set: [{"aid":1,"iid":14,"ev":true}] [33m+0ms[0m
[33;1mAccessory [0m[2-parking] Registering Characteristic "Streaming Status" for events [33m+0ms[0m
[35;1mHAPServer [0m[29:88:F1:A7:76:29] HAP Request: GET /characteristics?id=1.14 [35m+0ms[0m
[35;1mHAPServer [0m[C7:01:D3:87:04:D0] HAP Request: PUT /characteristics [35m+0ms[0m
[33;1mAccessory [0m[4-garage] Processing characteristic set: [{"aid":1,"iid":14,"ev":true}] [33m+0ms[0m
[35;1mEventedHTTPServer [0m[::ffff:10.0.0.128] HTTP request: /characteristics?id=1.14 [35m+0ms[0m
[35;1mHAPServer [0m[0B:1D:55:87:00:64] HAP Request: GET /characteristics?id=1.14 [35m+1ms[0m
[33;1mAccessory [0m[3-maison] Getting value for Characteristic "Streaming Status" [33m+0ms[0m
[33;1mAccessory [0m[3-maison] Got Characteristic "Streaming Status" value: AQEA [33m+0ms[0m
[35;1mHAPServer [0m[7D:50:91:D6:20:0A] HAP Request: GET /characteristics?id=1.14 [35m+0ms[0m
[33;1mAccessory [0m[2-parking] Getting value for Characteristic "Streaming Status" [33m+0ms[0m
[33;1mAccessory [0m[2-parking] Got Characteristic "Streaming Status" value: AQEA [33m+0ms[0m
[35;1mHAPServer [0m[C7:01:D3:87:04:D0] HAP Request: GET /characteristics?id=1.14 [35m+0ms[0m
[35;1mEventedHTTPServer [0m[::ffff:10.0.0.128] HTTP request: /characteristics [35m+0ms[0m
[35;1mHAPServer [0m[7D:50:91:D6:20:0A] HAP Request: PUT /characteristics [35m+1ms[0m
[33;1mAccessory [0m[2-parking] Processing characteristic set: [{"aid":1,"iid":21,"ev":true}] [33m+0ms[0m
[33;1mAccessory [0m[3-maison] Processing characteristic set: [{"aid":1,"iid":21,"ev":true}] [33m+1ms[0m
[35;1mHAPServer [0m[7D:50:91:D6:20:0A] HAP Request: GET /characteristics?id=1.21 [35m+0ms[0m
[33;1mAccessory [0m[2-parking] Getting value for Characteristic "Streaming Status" [33m+1ms[0m
[33;1mAccessory [0m[2-parking] Got Characteristic "Streaming Status" value: AQEA [33m+1ms[0m
[35;1mHAPServer [0m[43:C5:AF:13:4A:4E] HAP Request: PUT /characteristics [35m+0ms[0m
[33;1mAccessory [0m[0-devant] Processing characteristic set: [{"aid":1,"iid":14,"ev":true}] [33m+0ms[0m
[33;1mAccessory [0m[0-devant] Registering Characteristic "Streaming Status" for events [33m+0ms[0m
[35;1mHAPServer [0m[3F:57:46:4D:CA:41] HAP Request: PUT /characteristics [35m+0ms[0m
[33;1mAccessory [0m[1-porte] Processing characteristic set: [{"aid":1,"iid":14,"ev":true}] [33m+0ms[0m
[35;1mEventedHTTPServer [0m[::ffff:10.0.0.128] HTTP request: /characteristics?id=1.21 [35m+3ms[0m
[35;1mHAPServer [0m[3F:57:46:4D:CA:41] HAP Request: GET /characteristics?id=1.21 [35m+0ms[0m
[33;1mAccessory [0m[1-porte] Getting value for Characteristic "Streaming Status" [33m+0ms[0m
[33;1mAccessory [0m[1-porte] Got Characteristic "Streaming Status" value: AQEA [33m+0ms[0m
[35;1mEventedHTTPServer [0m[::ffff:10.0.0.128] HTTP request: /characteristics?id=27.9,2.9,18.9,18.10,21.9,21.10,34.9,47.9,9.9,41.9,41.10,13.9,12.10,12.9,35.9,35.10,24.9,24.10,8.9,19.9,14.10,14.9,15.9,23.9,11.9,6.9,37.9,20.9,22.9,39.10,39.9,38.9,4.9,48.9,7.9,3.9,5.9,36.9,10.9,29.9,26.9,25.9,16.9,45.9 [35m+388ms[0m
[35;1mHAPServer [0m[CC:21:3E:E4:DE:31] HAP Request: GET /characteristics?id=27.9,2.9,18.9,18.10,21.9,21.10,34.9,47.9,9.9,41.9,41.10,13.9,12.10,12.9,35.9,35.10,24.9,24.10,8.9,19.9,14.10,14.9,15.9,23.9,11.9,6.9,37.9,20.9,22.9,39.10,39.9,38.9,4.9,48.9,7.9,3.9,5.9,36.9,10.9,29.9,26.9,25.9,16.9,45.9 [35m+0ms[0m
[33;1mAccessory [0m[Navez House] Getting value for Characteristic "Current Position" [33m+1ms[0m
[33;1mAccessory [0m[Navez House] Got Characteristic "Current Position" value: 100 [33m+0ms[0m
[33;1mAccessory [0m[Navez House] Got Characteristic "Target Position" value: 100 [33m+0ms[0m
[33;1mAccessory [0m[Navez House] Getting value for Characteristic "Target Position" [33m+1ms[0m
[33;1mAccessory [0m[Navez House] Getting value for Characteristic "Lock Current State" [33m+0ms[0m
[33;1mAccessory [0m[Navez House] Getting value for Characteristic "Lock Target State" [33m+1ms[0m
[35;1mEventedHTTPServer [0m[::ffff:10.0.0.128] Muting event '39.9' notification for this connection since it originated here. [35m+2ms[0m
[33;1mAccessory [0m[Navez House] Getting value for Characteristic "Current Temperature" [33m+3ms[0m
[33;1mAccessory [0m[Navez House] Getting value for Characteristic "Motion Detected" [33m+0ms[0m
[37m[12/31/2016, 10:28:31 AM][39m [36m[eDomoticz][39m Data Received for Seche Linge.
[33;1mAccessory [0m[Navez House] Got Characteristic "On" value: 0 [33m+16ms[0m
[37m[12/31/2016, 10:28:31 AM][39m [36m[eDomoticz][39m Data Received for Cafetiere.
[37m[12/31/2016, 10:28:31 AM][39m [36m[eDomoticz][39m Data Received for Emy volet.
[37m[12/31/2016, 10:28:31 AM][39m [36m[eDomoticz][39m Data Received for Emy volet: 100
[37m[12/31/2016, 10:28:31 AM][39m [36m[eDomoticz][39m Data Received for Jules volet.
[37m[12/31/2016, 10:28:31 AM][39m [36m[eDomoticz][39m Data Received for Jules volet: 100
[37m[12/31/2016, 10:28:31 AM][39m [36m[eDomoticz][39m Data Received for Télévision.
[37m[12/31/2016, 10:28:31 AM][39m [36m[eDomoticz][39m Data Received for Sirene Maison.
[37m[12/31/2016, 10:28:31 AM][39m [36m[eDomoticz][39m Data Received for Camera maison.
[37m[12/31/2016, 10:28:31 AM][39m [36m[eDomoticz][39m Data Received for tele volet.
[37m[12/31/2016, 10:28:31 AM][39m [36m[eDomoticz][39m Data Received for tele volet: 100
[37m[12/31/2016, 10:28:31 AM][39m [36m[eDomoticz][39m Data Received for Cuisine.
[37m[12/31/2016, 10:28:31 AM][39m [36m[eDomoticz][39m Data Received for Cellier volet.
[37m[12/31/2016, 10:28:31 AM][39m [36m[eDomoticz][39m Data Received for Cellier volet: 100
[37m[12/31/2016, 10:28:31 AM][39m [36m[eDomoticz][39m Data Received for garage.
[37m[12/31/2016, 10:28:31 AM][39m [36m[eDomoticz][39m Data Received for garage: 1
[37m[12/31/2016, 10:28:31 AM][39m [36m[eDomoticz][39m Data Received for Parent volet.
[37m[12/31/2016, 10:28:31 AM][39m [36m[eDomoticz][39m Data Received for Parent volet: 100
[37m[12/31/2016, 10:28:31 AM][39m [36m[eDomoticz][39m Data Received for Camera jardin.
[37m[12/31/2016, 10:28:31 AM][39m [36m[eDomoticz][39m Data Received for Escalier.
[37m[12/31/2016, 10:28:31 AM][39m [36m[eDomoticz][39m Data Received for Cuisine volet.
[37m[12/31/2016, 10:28:31 AM][39m [36m[eDomoticz][39m Data Received for Cuisine volet: 100
[37m[12/31/2016, 10:28:31 AM][39m [36m[eDomoticz][39m Data Received for Derrière.
[37m[12/31/2016, 10:28:31 AM][39m [36m[eDomoticz][39m Data Received for Off.
[37m[12/31/2016, 10:28:31 AM][39m [36m[eDomoticz][39m Data Received for Camera porte.
[37m[12/31/2016, 10:28:31 AM][39m [36m[eDomoticz][39m Data Received for Camera emy.
[37m[12/31/2016, 10:28:31 AM][39m [36m[eDomoticz][39m Data Received for presence.
[37m[12/31/2016, 10:28:31 AM][39m [36m[eDomoticz][39m Data Received for Internet Jules.
[37m[12/31/2016, 10:28:31 AM][39m [36m[eDomoticz][39m Data Received for Lave vaisselle.
[37m[12/31/2016, 10:28:31 AM][39m [36m[eDomoticz][39m Data Received for salle a manger volet.
[37m[12/31/2016, 10:28:31 AM][39m [36m[eDomoticz][39m Data Received for salle a manger volet: 0
[37m[12/31/2016, 10:28:31 AM][39m [36m[eDomoticz][39m Data Received for radiateur sdb.
[37m[12/31/2016, 10:28:31 AM][39m [36m[eDomoticz][39m Data Received for Camera chemin.
[35;1mEventedHTTPServer [0m[::ffff:10.0.0.136] HTTP Response is finished [35m+0ms[0m
[35;1mEventedHTTPServer [0m[::ffff:10.0.0.136] HTTP request: /characteristics [35m+5ms[0m
[33;1mAccessory [0m[0-devant] Processing characteristic set: [{"aid":1,"iid":21,"ev":true}] [33m+0ms[0m
[35;1mEventedHTTPServer [0m[::ffff:10.0.0.136] HTTP request: /characteristics?id=1.14 [35m+3ms[0m
[35;1mHAPServer [0m[3F:57:46:4D:CA:41] HAP Request: GET /characteristics?id=1.14 [35m+0ms[0m
[35;1mEventedHTTPServer [0m[::ffff:10.0.0.136] HTTP request: /characteristics?id=1.21 [35m+8ms[0m
[35;1mHAPServer [0m[43:C5:AF:13:4A:4E] HAP Request: GET /characteristics?id=1.21 [35m+0ms[0m
[33;1mAccessory [0m[0-devant] Getting value for Characteristic "Streaming Status" [33m+0ms[0m
[33;1mAccessory [0m[0-devant] Got Characteristic "Streaming Status" value: AQEA [33m+1ms[0m
[35;1mEventedHTTPServer [0m[::ffff:10.0.0.136] HTTP request: /characteristics [35m+0ms[0m
[33;1mAccessory [0m[1-porte] Processing characteristic set: [{"aid":1,"iid":21,"ev":true}] [33m+0ms[0m
[33;1mAccessory [0m[1-porte] Registering Characteristic "Streaming Status" for events [33m+0ms[0m
[35;1mEventedHTTPServer [0m[::ffff:10.0.0.136] HTTP request: /characteristics?id=1.21 [35m+7ms[0m
Is Switch: true
SwitchTypeVal: 16
MQTT Message:
"Battery": 255,
"RSSI": 12,
"id": "0010000",
"idx": 505,
"nvalue": 0,
"stype": "AC",
"svalue1": "0",
"unit": 1
the first get is Got Characteristic "Target Position" value: 53
and domoticz report position 0[33;1mAccessory [0m[Navez House] Got Characteristic "Target Position" value: 53 [33m+0ms[0m
close home and reopen and value of blind is not closed but %
with branch mqtt all is ok
All debug
Is Switch: true
SwitchTypeVal: 16
MQTT Message:
"Battery": 255,
"RSSI": 12,
"id": "0010000",
"idx": 505,
"nvalue": 0,
"stype": "AC",
"svalue1": "0",
"unit": 1
Is Switch: true
SwitchTypeVal: 16
MQTT Message:
"Battery": 255,
"RSSI": 12,
"id": "0010000",
"idx": 505,
"nvalue": 0,
"stype": "AC",
"svalue1": "0",
"unit": 1
- Target OS: -
Hi all, I am getting close to the 100 device limit within eDomoticz and wondered what the best way of moving forward is.. Can I add another eDomoticz platform to the config file and point that to a new room ID and add the new devices to that? With MQTT running would I just add same info as the first eDomoticz for MQTT.. I'm at 80 devices so got a while yet - just wondered how you guys have/would do it.
Cheers
Cheers
Seems there is now support for "setcolbrightness" via mqtt (https://github.com/domoticz/domoticz/pull/1061) - could this be used to enhance the controlling of RGBW lights via homebridge-eDomoticz?
- Domoticz version: 3.5248
HEllo all,
i did the setup however i'm receiving this error when starting homebridge what should i do :
[1/2/2017, 9:21:07 PM] [eDomoticz] There was an error while getting the MQTT Hardware Device from Domoticz.
Please verify that you have added the MQTT Hardware Device and that the hardware device is enabled.
I did option 2
should i do the Enabling MQTT For improved realtime updates (speedier response) in order to fix the issue ?
Cheers,
Flo
I did option 2
Cheers,
Flo
- TheRamon
Hi, have just checked. there is no usescenes or loadscenes parameter. We would have to build this. I'll check this outAwst6000 wrote:I also tried the parameter usescenes, but still no luck.
Happy Christmas!
Yeah, you could use rooms to exclude devices. I personally have a room called HomeKit in Domoticz, roomID 2. I have added that room ID to my config.json of the plugin.Justinb81 wrote:I added a Netatmo Home Coach to domoticz, and now homebridge crashes:
Is there som way I can exclude something from homebridge? the homecoach is already a homekit device on it's own.
I also think you have a old version of the plugin, try updating the plugin and your homebridge. I think that will resolve your error.
Hi, there's no functionality for this YET. We're planning on building this, but there are no concrete steps yet.LaMax wrote:Hi, first of all thanks for the impressive work you made. it was very simple to get up and running all the system. I have various sensor and switch added in domoticz via OpenZ-wave (razberry 2 board) and seems that all work good. Now i want to know if it's possible to change the way that homebridge see a switch, i use one of them to open my door, anche from siri now i have to say "Turn on Principal Door" instead of "open Principal Door". Because Siri recognize the command open but she (it?) can't associate to a door opener actuator, i want to know if it's possible to change that switch to a door opener.![]()
I think this is an internal network issue. If you really want to restart Domoticz you'd have to build something yourself in linux. Maybe like a script that kills and starts Domoticz every x days.bing69 wrote:After about 3 days working reacts home on the iPhone anymore. Can not connect. Restart Domoticz solves the problem.
Hiya, this has already been built. Please see commit e5d1267, version 1.0.5.bdormael wrote:Hi there, are there any forthcoming plans for full bi-directional secpanel support? Today it's working only from domoticz to Home, not the other way round. It would be awesome that I can switch the secpanel from within Home
I'll check it out. So on the old branch everything was ok? I'll check that, too.fennec62 wrote: Ok sorry for the late answer...
To be honest, I didn't know there was a device limit. Why is there a limit? Do you know? We might be able to remove it now that we've improved the plugin so much.simon_rb wrote:Hi all, I am getting close to the 100 device limit within eDomoticz and wondered what the best way of moving forward is.. Can I add another eDomoticz platform to the config file and point that to a new room ID and add the new devices to that? With MQTT running would I just add same info as the first eDomoticz for MQTT.. I'm at 80 devices so got a while yet - just wondered how you guys have/would do it.
Cheers
NICE. I'll see what I can do.Nautilus wrote:Seems there is now support for "setcolbrightness" via mqtt (https://github.com/domoticz/domoticz/pull/1061) - could this be used to enhance the controlling of RGBW lights via homebridge-eDomoticz?
Hi, you probably did not add any MQTT hardware device in domoticz yet, but you configured "mqtt": 1 in your config.json file.Kerneldomoticz wrote:HEllo all,
I did option 2
Cheers,
Flo
You're required to have a MQTT hardware device in domoticz, otherwise you cannot use the MQTT support in the plugin either.
Please add a MQTT hardware device in domoticz under the Hardware tab. Keep default settings, choose localhost and 1883 for ip and port respectively. Also, don't forget to fill in a name.
- TheRamon
@fennec62:
I have just resolved your 'blinds' issue. It had something to do with caching.
Please update to the latest npm version 1.0.7. (npm update)
@Nautilus:
I have just pushed 'setcolbrightnessvalue over MQTT' to git. (no npm yet)
I'll try and see if it works. If it does, I'll update npm.
@Nautilus:
Great, thanks!TheRamon wrote: @Nautilus:
- TheRamon
Hehehe, alright. I have just reverted the setcolbrightnessvalue commit since it's not yet working 100%.. Does not have support for RGB values and such. I'll wait for Domoticz to implement that, too..Nautilus wrote:Great, thanks!TheRamon wrote: @Nautilus:
I'll try and see if it works. If it does, I'll update npm.I'm updating via npm (not sure how easy it would be to switch to git) so I'll test if/when it is there. Thanks again!
- TheRamon
Forgive me, this was indeed an error. Have just fixed this! Please update to the latest version in npm.TheRamon wrote:Yeah, you could use rooms to exclude devices. I personally have a room called HomeKit in Domoticz, roomID 2. I have added that room ID to my config.json of the plugin.Justinb81 wrote:I added a Netatmo Home Coach to domoticz, and now homebridge crashes:
Have just noticed that bidirectional support for the secpanel has been implemented, thx for this, working perfect
Thanks i try and i feedbackTheRamon wrote:@fennec62:
@Nautilus:
Fix ok
Thanks a lot TheRamon
