RFLink & WH5029 weather station
433Mhz opensource Receiver & Transmitter.
eSumo
Domoticz version: 4.9700
Post by eSumo »
Hello.
Anyone here uses WH5029 + RFLink + Domoticz?
Wind speed is in my opinion wrong.
Speed is always 0, gusts are small (1-8km/hod) ...
Other values are fine.
Domoticz latest stable (2022.2) on RPi 2 with MySensors GW (2.3.0), RFLink 433 R48 with NODO...
...and 42x 433MHz devices + 11x MySensors...
Test env.: latest Domoticz beta on Win10, home made RFLink 433 R48 with NRF for MySensors...
mrccore
Domoticz version: 3.5877
Re: RFLink & WH5029 weather station
Post by mrccore »
Hi.
Do you have the wind sensor in the correct postion to North? I don't have this meteo station you have i have an alecto ws-3500 and in the first day i had to do some ajusts to have the readings correctly... almost correctly....
But in my case my domoticz it's not giving me the reads off the wind from South.
you can see my posts over here http://www.domoticz.com/forum/viewtopic ... 49&t=15066 also i found out that when i was using the beta releases my data was not correct. Are you using the beta or stable release?
eSumo
Post by eSumo »
Hi.
Yes - my position is corect... My problem is elsewhere. about...
Probably is not WH5029 as WH5029. ;)
...and my configuration is in the signature...
