Hi All,
I have installed a rflinkgateway from nodoshop. It worked fine in the beginning. Then I cant learn any new devices but i could still use the installed devices. I tryed then to reinstall gateway inside domoticz, now I cant add more and rflink cant find any new either.
Any Ideas or do I have to reinstall whole domoticz?
Rflink gateway stopped working
- DewGew
- Domoticz version: V4.10618
- sincze
- Domoticz version: 2024.4
Re: RE: Rflink gateway stopped working
What does it do if you :DewGew wrote:Hi All,
Attach the rflink to a pc.
Start the firmware program.
Enable debug.
Do you see new devices flying by?
Sent from my SM-G925F using Tapatalk
Pass2php
USB: RFXCom, ZWave, Sonoff 3
MQTT: ZIgbee2MQTT,
ZWAVE: Zwave-JS-UI
Solar: Omnik, PVOutput
Sensors: You name it I got 1.
MQTT: ZIgbee2MQTT,
ZWAVE: Zwave-JS-UI
- DewGew
Thanks, I got it working now. I Enable debug and no devices was flying by. I figured out that i my soldering was bad.sincze wrote:What does it do if you :DewGew wrote:Hi All,
Enable debug.
Br Pierre
- sincze
Re: Rflink gateway stopped working
Nicely done
Pass2php
MQTT: ZIgbee2MQTT,
ZWAVE: Zwave-JS-UI
MQTT: ZIgbee2MQTT,
ZWAVE: Zwave-JS-UI
