Xml in domoticz?
edwin1234
Domoticz version: 2021.1
Xml in domoticz?
Post by edwin1234 »
How can i get the info out of an xml file and use it in domoticz?
So there be devices with the given info from the xml file in domoticz.
Example : CloseInBoiler status=on usage=0W
See my xml file:
<PlugwiseSource Version="1.0">
<Appliances>
<Appliance Id="13" Name="CloseInBoiler" Type="water_heater_vessel" PowerUsage="0,0000" TotalUsage="927,83" PowerState="on" Module="14" Image="/sysimg/32/water_heater_vessel_on.png"/>
<Appliance Id="9" Name="CV-ketel" Type="heater_central" PowerUsage="69,0000" TotalUsage="394,95" PowerState="on" Module="10" Image="/sysimg/32/heater_central_on_locked.png"/>
<Appliance Id="5" Name="Droger" Type="dryer" PowerUsage="0,0000" TotalUsage="1161,39" PowerState="on" Module="6" Image="/sysimg/32/dryer_on.png"/>
<Appliance Id="1" Name="HsProServer" Type="monitor" PowerUsage="0,0000" TotalUsage="49,03" PowerState="on" Module="2" Image="/sysimg/32/monitor_on_locked.png"/>
<Appliance Id="14" Name="Koelkast" Type="refrigerator" PowerUsage="0,0000" TotalUsage="700,04" PowerState="on" Module="15" Image="/sysimg/32/refrigerator_on.png"/>
<Appliance Id="8" Name="Magnetron" Type="oven_microwave" PowerUsage="1,0000" TotalUsage="56,97" PowerState="on" Module="9" Image="/sysimg/32/oven_microwave_on.png"/>
<Appliance Id="2" Name="MediaCenter" Type="hometheater" PowerUsage="0,0000" TotalUsage="206,49" PowerState="unknown" Module="3" Image="/sysimg/32/hometheater_unknown_locked.png"/>
<Appliance Id="3" Name="Multimedia" Type="hometheater" PowerUsage="36,0000" TotalUsage="433,33" PowerState="on" Module="4" Image="/sysimg/32/hometheater_on.png"/>
<Appliance Id="10" Name="ongebruikt" Type="zz_misc" PowerUsage="0,0000" TotalUsage="19,24" PowerState="unknown" Module="11" Image="/sysimg/32/zz_misc_unknown.png"/>
<Appliance Id="17" Name="Ongebruikt2" Type="zz_misc" PowerUsage="0,0000" TotalUsage="40,99" PowerState="unknown" Module="18" Image="/sysimg/32/zz_misc_unknown.png"/>
<Appliance Id="6" Name="PcEd" Type="computer_desktop" PowerUsage="0,0000" TotalUsage="4,59" PowerState="unknown" Module="7" Image="/sysimg/32/computer_desktop_unknown.png"/>
<Appliance Id="4" Name="Router" Type="router" PowerUsage="24,0000" TotalUsage="44,83" PowerState="on" Module="5" Image="/sysimg/32/router_on_locked.png"/>
<Appliance Id="11" Name="Senseo" Type="coffee_maker" PowerUsage="1,0000" TotalUsage="75,64" PowerState="on" Module="12" Image="/sysimg/32/coffee_maker_on.png"/>
<Appliance Id="16" Name="Televisie" Type="tv" PowerUsage="0,0000" TotalUsage="567,99" PowerState="on" Module="17" Image="/sysimg/32/tv_on.png"/>
<Appliance Id="12" Name="TvSlaapkamer" Type="tv" PowerUsage="0,0000" TotalUsage="61,55" PowerState="off" Module="13" Image="/sysimg/32/tv_off.png"/>
<Appliance Id="15" Name="VijverPomp" Type="pump_heater" PowerUsage="2,0000" TotalUsage="46,50" PowerState="unknown" Module="16" Image="/sysimg/32/pump_heater_unknown.png"/>
<Appliance Id="7" Name="Wasmachine" Type="washingmachine" PowerUsage="0,0000" TotalUsage="382,05" PowerState="on" Module="8" Image="/sysimg/32/washingmachine_on.png"/>
Could someone help me with this?
Edwin
Egregius
Domoticz version: v2024.7
Re: Xml in domoticz?
Post by Egregius »
Should be possible with PHP.
I use this command to get the status of a Denon receiver wich is also presented in XML format:
$denonmain=json_decode(json_encode(simplexml_load_string(file_get_contents($denon_address.'/goform/formMainZone_MainZoneXml.xml?_='.time(),false,$ctx))),TRUE);
Values are then available in a associated array, for ex:
$denonmain['ZonePower']['value']
the function file_get_contents can be url or local file.
Westcott
Post by Westcott »
It can also be done directly in Lua, just like JSON.
There's an XML.lua file available, and LuaRocks has at least one library.
edwin1234
Post by edwin1234 »
Thanks for your help
but Cant get it done in lua example.xml i get errors i do something wrong.
Can u please give me a filled in example? What to fill in at : s = request['content'];
sorry total new to scripting :-(
My xml is:
http://192.168.2.166:port/xml/appliances.xml
-- Example of XML parser handling data with the following structure
--<?xml version="1.0" encoding="UTF-8"?>
--<sensor>
-- <id>13</id>
-- <value>29.99</value>
--</sensor>
-- A test with curl would be : curl -X POST -d "@test.xml" 'http://192.168.1.17:8080/json.htm?type= ... le_xml.lua'
-- Retrieve the request content
-- Update some devices (index are here for this example)
local id = domoticz_applyXPath(s,'//id/text()')
local s = domoticz_applyXPath(s,'//value/text()')
domoticz_updateDevice(id,'',s)
edwin1234
Post by edwin1234 »
nobody?
Egregius
Post by Egregius »
You know it's very agressive to bump your topic with a comment like that?
I provided a way but you didn't even bother to try or respond on it.
Toulon7559
Domoticz version: <2025
Post by Toulon7559 »
Advise to first use (in future) the search-function in this forum, because at least 2 other, older threads which follow the line of your question, and may provide a solution:
http://www.domoticz.com/forum/viewtopic.php?f=28&t=1837
http://www.domoticz.com/forum/viewtopic ... 23&t=11472
edwin1234
Post by edwin1234 »
Sorry didnt ment it that way, i did try the xml.lua filled in my ip and the line of the xml
But i only get errors.
I told in my previous post that i dont have scripting experience or program skills , so its hard for me to understand the script. I search the internet for something simmulair but couldt find it.
Im very thankfull for your help and answer,
I Will wait for a solution that i understand
Edwin
Egregius
Post by Egregius »
The php solution is pretty simple and straight forward AND there's a HUGE userbase for php, so you'll find anything for it.
edwin1234
Post by edwin1234 »
Thanks monday for your php solution,
Can u tell me how i get the outcome in domoticz?
Edwin
Egregius
Post by Egregius »
Best way to go is first set up a PHP enabled webserver if you don't have that already.
Then create a PHP file with the function posted above and loop through the array until you have the desired values in variables.
Then put those variables in a json command to sent them to domoticz.
Toulon7559
For experimenting/learning to work with a PHP-enabled webserver looking for a small software package (of at least Apache/PHP/SQL) to run at one of the local 'leftover-PCs' with WindowsXP. Have been trying to install&configure Xitami+PHP5 and as alternative EasyPHPDevserver, but still meet problems. Xitami+PHP5 is rather small, but limited (e.g. no SQL_DB). EasyPHP-package is complete, but rather big for the available PCs.
Any other, simple & small & robust package recommended?
