Domoboard - General Discussions
Moderators: leecollings, wez3
Forum rules
Before posting here, make sure you are using the latest Beta or Stable version.
In order to fix issues or add features these have to be reported on the Domoboard Github pages.
This makes it possible to keep track of issues/features on a centralized place.
Refer to the issue of the github tracker when possible.
This subforum is meant to discuss issues and/or feature requests, or anything else related to Domoboard.
wez3
Re: Domoboard a New Dashboard using Domoticz as backend
@GreenSmart01
You did not install all requirements. Make sure to run the following command:
sudo easy_install flask flask-auth configobj gitpython simplejson bleach requests
@Lars65
Yes, it is no problem to run domoboard on a seperate RPi. Just config the domoticz server address and it should work (see general_settings) example.conf
@felix63
A cam can be added like this (example is a foscam):
[[camera]]
Camera = http://x.x.x.x:88/cgi-bin/CGIStream.cgi ... xx&pwd=xxx
@Lars65
@felix63
[[camera]]
- felix63
- Domoticz version: 2020.1
Thanks, that works! I do have some additional questions.
- I am now trying to add motion sensors and door contacts, any suggestion how I could do this
- having two blocks of switches can I change the title? see example below
- how can I add Buienradar and Traffic-info?
[woonkamer]
[[display_components]]
components = switches[1],switches[2]
[[switches]]
[[[1]]]
staande lamp = 10, dimmer
strip = 325, dimmer
[[[2]]]
iris = 11, rgb
kubus = 79, dimmer
schotel = 335, dimmer
spotjes = 506, dimmer
squandor
- Domoticz version: 3.5837
Hi felix63,felix63 wrote:Thanks, that works! I do have some additional questions.
[woonkamer] [[display_components]] components = switches[1],switches[2] [[switches]] [[[1]]] staande lamp = 10, dimmer strip = 325, dimmer [[[2]]] iris = 11, rgb kubus = 79, dimmer schotel = 335, dimmer spotjes = 506, dimmer
- The door contacts and motion sensors are a bit tricky to answer because can't test with them but if they work just as switches it should work
- At the moment it is not possible to change the title but that's a small fix which i will implement later today
- To add Buienradar and traffic-info you can do the following to you config:
[woonkamer]
components = switches[1],switches[2], buienradar, anwb
[[switches]]
[[[1]]]
strip = 325, dimmer
[[[2]]]
iris = 11, rgb
kubus = 79, dimmer
[[buienradar]]
[[anwb]]
zandhaas
- Domoticz version: V3.8805
Nice Dashboard.
Question,
When I install the ANWB plugin I get the below messesaage when I try to start domoboard:
Error occured during loading imports for the plugin anwb. Please check whether all dependecies are installed
I installed it both via the setting menu and via the manual method both eith the same result.
What am I missing?
Question,
What am I missing?
squandor
Just pushed the solution for you're title problem to the develop branch.felix63 wrote:Thanks, that works! I do have some additional questions.
If you use the following config in the future it will change the switch title when the new code has been pushed to master:
components = switches[Title 2],switches[Title 1]
[[switches]]
[[[Title 1]]]
strip = 325, dimmer
[[[Title 2]]]
iris = 11, rgb
kubus = 79, dimmer
squandor
hmm i think that we can work on the error messages. The ANWB plugin does use modules which are not default installed and i think that you don't have some of them.zandhaas wrote:Nice Dashboard.
Question,
What am I missing?
pip install geocoder natsort-
vmb
sudo apt-get install python-setuptoolsThx! That did the trick! Now installing...[/quote]
Installed and running. Tested some things, Will try to suit the dashboard according to my situation. Only one important question (at the moment
When I closed the terminal session after starting up Domoboard, Domoboard turned out to have shutdown. Can someone tell me how I can prevent that so it keeps running in the background?
zandhaas
Yup that did the trick except that I had to use "easy_install" instead of pip.squandor wrote:hmm i think that we can work on the error messages. The ANWB plugin does use modules which are not default installed and i think that you don't have some of them.zandhaas wrote:Nice Dashboard.
Question,
What am I missing?Code: Select all
wez3
Thx! That did the trick! Now installing...[/quote]vmb wrote:Code: Select all
When I closed the terminal session after starting up Domoboard, Domoboard turned out to have shutdown. Can someone tell me how I can prevent that so it keeps running in the background?[/quote]
This should do the trick:
sudo apt-get install screen
screen -S flask
Start domoboard in the screen
You can attach back to the screen with screen -d -r <number of screen>
jake
I'm not a Linux expert, but is this screen thing the right thing to do? Won't you loose your connection after a reboot of the Pi? For another program that needs to run all the time, I was advised (and now use) Supervisor to always start a certain program after reboot.wez3 wrote: This should do the trick:
screen -S flask
- felix63
Thanks for your prompt reply!squandor wrote: Just pushed the solution for you're title problem to the develop branch.
Regarding Motion Sensors and Contacts. For Motion Sensors using regular switches seems to work as the report 'On' or 'Off'. Contacts however report 'Open' or 'Closed'. The result is that when you use a switch the status is always reported as 'On' regardless off the true state of the switch (Open or Closes).
Holland
- Domoticz version: Beta Ch
@Jake
Just run Domoboard within PM2, then Domoboard runs on the background even without a SSH console
jump to the Domoboard directory, and issue;
Where settings.conf is the same file as example.conf, but with a different name
To make sure that the above is restarted at reboot;
1.
2.
pm2 start python server.py -- -c settings.confWhere settings.conf is the same file as example.conf, but with a different name
1.
pm2 startupCode: Select all
pm2 save-
GreenSmart01
- Domoticz version: 4.10856
@wez3wez3 wrote:@GreenSmart01
thanks for your comment,
But these commands are already executed
below its output:
pi@raspberrypi:~$ sudo easy_install flask flask-auth configobj gitpython simplejson bleach requests
Searching for flask
Best match: Flask 0.10.1
Flask 0.10.1 is already the active version in easy-install.pth
Using /usr/lib/python2.7/dist-packages
Processing dependencies for flask
Finished processing dependencies for flask
Searching for flask-auth
Best match: Flask-Auth 0.85
Processing Flask_Auth-0.85-py2.7.egg
Flask-Auth 0.85 is already the active version in easy-install.pth
Using /usr/local/lib/python2.7/dist-packages/Flask_Auth-0.85-py2.7.egg
Processing dependencies for flask-auth
Finished processing dependencies for flask-auth
Searching for configobj
Best match: configobj 5.0.6
Processing configobj-5.0.6-py2.7.egg
configobj 5.0.6 is already the active version in easy-install.pth
Using /usr/local/lib/python2.7/dist-packages/configobj-5.0.6-py2.7.egg
Processing dependencies for configobj
Finished processing dependencies for configobj
Searching for gitpython
Best match: GitPython 2.1.1
Processing GitPython-2.1.1-py2.7.egg
GitPython 2.1.1 is already the active version in easy-install.pth
Using /usr/local/lib/python2.7/dist-packages/GitPython-2.1.1-py2.7.egg
Processing dependencies for gitpython
Finished processing dependencies for gitpython
Searching for simplejson
Best match: simplejson 3.10.0
Processing simplejson-3.10.0-py2.7.egg
simplejson 3.10.0 is already the active version in easy-install.pth
Using /usr/local/lib/python2.7/dist-packages/simplejson-3.10.0-py2.7.egg
Processing dependencies for simplejson
Finished processing dependencies for simplejson
Searching for bleach
Best match: bleach 1.5.0
Processing bleach-1.5.0-py2.7.egg
bleach 1.5.0 is already the active version in easy-install.pth
Using /usr/local/lib/python2.7/dist-packages/bleach-1.5.0-py2.7.egg
Processing dependencies for bleach
Finished processing dependencies for bleach
Searching for requests
Best match: requests 2.4.3
requests 2.4.3 is already the active version in easy-install.pth
Processing dependencies for requests
Finished processing dependencies for requests
pi@raspberrypi:~$
squandor
@Greensmart01 does the console still have the same modules missing or has the error message changed after the last command?
GreenSmart01
Im now getting:
pi@raspberrypi:~$ sudo python -c server.py example.con
File "<string>", line 1, in <module>
NameError: name 'server' is not defined
squandor
this is because you put the parameters in the wrong order, what do you get when you run the code:GreenSmart01 wrote:Im now getting:
pi@raspberrypi:~$ sudo python -c server.py example.con Traceback (most recent call last): File "<string>", line 1, in <module> NameError: name 'server' is not defined
sudo python server.py -c example.conf
GreenSmart01
pi@raspberrypi:~/domoboard$ sudo python server.py -c example.conf
File "server.py", line 4, in <module>
from flaskext.auth import Auth, AuthUser, login_required, logout
ImportError: No module named auth
zandhaas
I have an other question about the ANWB plugin.
I was able to install it and added teh startPoint en endPoint values to the general tab in config file and also added a [anwb] section.
But when I start domoboard I get the below messages:
I think my entries in the config file are not correct but I can not find more deteail information on how it should be exactly.
Can you please give some more detailed information on how to add the right config file entries for this plugin.
[2017-01-02 16:16:08,204] ERROR in app: Exception on /api [POST]
File "/usr/local/lib/python2.7/dist-packages/Flask-0.12-py2.7.egg/flask/app.py", line 1982, in wsgi_app
response = self.full_dispatch_request()
File "/usr/local/lib/python2.7/dist-packages/Flask-0.12-py2.7.egg/flask/app.py", line 1614, in full_dispatch_request
rv = self.handle_user_exception(e)
File "/usr/local/lib/python2.7/dist-packages/Flask-0.12-py2.7.egg/flask/app.py", line 1517, in handle_user_exception
reraise(exc_type, exc_value, tb)
File "/usr/local/lib/python2.7/dist-packages/Flask-0.12-py2.7.egg/flask/app.py", line 1612, in full_dispatch_request
rv = self.dispatch_request()
File "/usr/local/lib/python2.7/dist-packages/Flask-0.12-py2.7.egg/flask/app.py", line 1598, in dispatch_request
return self.view_functions[rule.endpoint](**req.view_args)
File "/usr/local/lib/python2.7/dist-packages/Flask_Auth-0.85-py2.7.egg/flaskext/auth/auth.py", line 186, in decorator
return func(*args, **kwargs)
File "/domoboard/modules/api.py", line 87, in gateway
result = call(request.args)
File "/domoboard/plugins/anwb.py", line 169, in getData
setEndGeo(geocode(end))
File "/domoboard/plugins/anwb.py", line 23, in geocode
return list(g)[0]
IndexError: list index out of range
squandor
It seems like you're config settings aren't correct indeed. An format for the address could be:zandhaas wrote:Hello,
[2017-01-02 16:16:08,204] ERROR in app: Exception on /api [POST] Traceback (most recent call last): File "/usr/local/lib/python2.7/dist-packages/Flask-0.12-py2.7.egg/flask/app.py", line 1982, in wsgi_app response = self.full_dispatch_request() File "/usr/local/lib/python2.7/dist-packages/Flask-0.12-py2.7.egg/flask/app.py", line 1614, in full_dispatch_request rv = self.handle_user_exception(e) File "/usr/local/lib/python2.7/dist-packages/Flask-0.12-py2.7.egg/flask/app.py", line 1517, in handle_user_exception reraise(exc_type, exc_value, tb) File "/usr/local/lib/python2.7/dist-packages/Flask-0.12-py2.7.egg/flask/app.py", line 1612, in full_dispatch_request rv = self.dispatch_request() File "/usr/local/lib/python2.7/dist-packages/Flask-0.12-py2.7.egg/flask/app.py", line 1598, in dispatch_request return self.view_functions[rule.endpoint](**req.view_args) File "/usr/local/lib/python2.7/dist-packages/Flask_Auth-0.85-py2.7.egg/flaskext/auth/auth.py", line 186, in decorator return func(*args, **kwargs) File "/domoboard/modules/api.py", line 87, in gateway result = call(request.args) File "/domoboard/plugins/anwb.py", line 169, in getData setEndGeo(geocode(end)) File "/domoboard/plugins/anwb.py", line 23, in geocode return list(g)[0] IndexError: list index out of range
[[anwb]]
startPoint = "Korte minrebroederstraat 1, Utrecht"
endPoint = "Korte Nieuwstraat 6, Nijmegen"
These points are working on my test situation, so hopefully it will work at your's to.
wez3
Your right, better is to create a service of it. I would use systemd for this, however during development i mainly use screenjake wrote:I'm not a Linux expert, but is this screen thing the right thing to do? Won't you loose your connection after a reboot of the Pi? For another program that needs to run all the time, I was advised (and now use) Supervisor to always start a certain program after reboot.wez3 wrote: This should do the trick:
screen -S flask
