sdcard upgrade from v3.4834, login not possible Topic is solved
tchabot
Post by tchabot »
I have v3.4834 running nice on my rpi. Installed it by putting the downloaded image on the sdcard.
Now I want to upgrade to the latest version. I can't find any image that I can put on my sdcard. I only see that the upgrade can be done trough an command (sudo curl -L install.domoticz.com | bash). Therefore I have to log in on my rpi.
As far as I know that should be possible with the standard login 'pi' and password 'raspberry'. But it looks as if these are not valid. I didn't change the password after installing the image.
Anybody know how to log in in this case. I use Putty to connect to my rpi.
SweetPants
Re: sdcard upgrade from v3.4834, login not possible
Post by SweetPants »
Did you search the internet to reset the pi password?
Like http://www.mapledyne.com/ideas/2015/8/4 ... spberry-pi
tchabot
Post by tchabot »
I did search but didn't find anything usable. I didn't find your link.
I tried it. After the command "passwd pi" I was asked for the new password. I typed (twice) "raspberry" in order to get the default password again.
Reply was "Authentication token manipulation error" and "password unchanged". Tried it with a different password, same result.
So I am still stuck.
SweetPants
Did you read the last paragraph: ERROR WHEN CHANGING THE PASSWORD:
tchabot
Post by tchabot »
That error instruction was printed on the reverse side of the paper and I obviously overlooked it.
That worked fine.
The upgrade to the latest version of domoticz did work out perfect.
SweetPants
Your welcome, can you mark the topic solved?
Users browsing this forum: Amazon [Bot], Google [Bot] and 1 guest
