Dear All,
I'm currently looking at setting up Domoticz and connecting it to my Beckhoff PLC.
Is there any guidance on this?
I know there is a JavaScript Library for connection and automation purpose if that helps:
http://tomcx.github.io/tame4/
thanks in advance
Beckhoff Support
Re: Beckhoff Support
Not a lot of feedback so I guess this is not that easy
Hello Have you get to succes in your project ?
Is intersting for mine.
thank you
thank you
Beckhoff PLC runs windows?
is it possible to install domoticz on the Beckhoff PLC?
is it possible to access the IO of the Beckhoff PLC?
worst case, beckhoff works with mqtt? --> i would like to install domoticz on the windows of beckhoff, and then acces the IO with mqtt?
I dont know what is and what is not possible..
