does anyone try the ARILUX AL-LC01 (ESP8266 RGB led strip controller)
Everything about esp8266 and more.
n1c0l45
Domoticz version: V3.4834
Post by n1c0l45 »
Hi All
Does anyone tried the ARILUX® AL-LC01 ?
http://www.banggood.com/ARILUX-AL-LC01- ... ds=myorder
these an ESP 8266 inside
the Smartphone app is MagicHome
is there a way to communicate with domoticz?
remip67
Re: does anyone try the ARILUX AL-LC01 (ESP8266 RGB led strip controller)
Post by remip67 »
Very cheap ledstrip controlers. Would be nice if these could connect with domoticz...
ducseb
Post by ducseb »
I'm developing a Domoticz hardware module to manage Arilux AL-C0x Wifi Led Controller.
The first release will support the RGB AL-C01 controller.
AL-C02 will be supported but I need a little bit more time to implement and test it ( my Aliexpress order is on the way ;) ).
Command available: LedOn,LedOff,SetRgbColour,SetColorToWhite.
Development is about 70% complete.
remip67
Post by remip67 »
Wauw! Nice. Please keep us informed!
ledfreak3d
Domoticz version: 3.8025
Post by ledfreak3d »
already working just flash esp easy on it I can control both rgb and rgb+w with this controller no extra software or plugin needed
Unleashe the magic smoke ;)
ducseb
Post by ducseb »
ledfreak3d wrote:already working just flash esp easy on it I can control both rgb and rgb+w with this controller no extra software or plugin needed
Yes i have seen this option but i tried it, do you know where I can find a HowTo ?
Regarding the plugin, my intention is to bring an out of the box solution, whitout the flashing Arilux step.
By the way, the plugin is almost complete, pull request has been approved and next beta should come with the Arilux Al-C0x hardware support.
https://github.com/domoticz/domoticz/pull/1075
For now, Led On/Led Off and basic RGB functionnality is handled ( color sélection is buggy, fix is on the way)
ducseb
Post by ducseb »
EDIT: Fix accepted, next beta version will include fix for color/white/brightness.
ducseb
Post by ducseb »
Hardware plugin with rgb color OK is available, friday beta release included the fix.
n1c0l45
Post by n1c0l45 »
works nice! just a dimmer problem!
do you know how to send a json command to activate a specific color?
thanks
tripplesixer
Post by tripplesixer »
Hi, is there anything new regarding the Arilux~ESPEasy~and commands?
Cheers, Tripple
TigroEHOT
Post by TigroEHOT »
Hi everybody!
@ducseb Nice work!
Would it be hard to implement RGBW support? Like arilux al-C06.
Отправлено с моего Redmi 3S через Tapatalk
ledfreak3d
just flash easyesp on it
TigroEHOT
Post by TigroEHOT »
Well, it's not esp8266, it has something different.
