Domoticz and raspbmc
bnwgraaf
Post by bnwgraaf »
I have a raspberry pi 2b running for over a year now with the domoticz image.
It is only logging my energy and gas consumption.
I feel that I can do a lot more with it. I am interested in using the raspberry also as a mediacenter.
Is it possible to run domoticz and raspbmc together?
If yes, how can I install that? I am pretty new with raspberry.
Do I have to install raspbmc on the existing domoticz installation?
Or do I have to install raspbmc first and add domoticz?
Are there people who have running these two together?
trixwood
Re: Domoticz and raspbmc
Post by trixwood »
kodi and domoticz run very well together.
you should try it out on a separate sd card... then you can play and try out all you want!
installing domoticz: https://www.domoticz.com/wiki/Raspberry_Pi and meber to copy your db from the old to the new :-)
installing kodi, use a image or follow on of the many guides online... :-)
Have phun! you also might consider buying a pi zero (cheap) put your sd card in there (you can just swap um, but always backup anyway!) and use you pib2 as a mediacenter with both the standard images... saves a lot of time!
Egregius
Domoticz version: v2024.7
Post by Egregius »
For the cost of a Pi I prefer dedicated ones. One for Kodi, one for pihole, one for....
trixwood
Post by trixwood »
...and eight for cameras... and one just to play with :-)
Egregius
Post by Egregius »
Lol, you're worse than me :lol:
I only have 3 for camera's.
But to respond on topic:
Everybody want's his Domoticz to be as fast and stable as can be. Why risk that by adding a mediaplayer wich consumes a lot of a Pi?
Not to say anything about the config.txt, mine are totally different for kodi and camera against the one for pihole. Memory settings, overclock,... name it.
bnwgraaf
Post by bnwgraaf »
Tnx you all for your replies!
It sounds good to use separate raspberrys.
Can this also be a good board for domoticz, only for monitoring the P1 energymeter?
http://s.aliexpress.com/MNjIvaum
trixwood
Post by trixwood »
Divide and conquers, or together we will fall,
One failed (or cpu 100%) pi, will not bring down me or the rest at all :-)
If you want to do something nice to add to your pi and play with try adding a rtc or begin your quest in mysensors land with the cheapest controller of any sensors technology (less then 1 euro :-) viewtopic.php?t=14365#p105148 or add a very advanced camera solution: viewtopic.php?t=8390#p90233
bnwgraaf
Post by bnwgraaf »
Does anybody know if I can install Domoticz on this one:
https://nl.aliexpress.com/store/product ... 74493.html
and connect it to the P1 port of my smart energy meter?
I was not correct with the version I am using at the moment: it is not a Pi 2B, but a Pi B+
I did a little test and it worked with OSMC (without Domoticz). I know it is not the most powerful of the Raspberry's, but is the B+ okay, to start with mediacenters to learn about how they work and so on, or does the B+ will have real performance issues? I am mostly interested in playing music (MP3 on a USB drive), but would also like to play with movies.
Egregius
Post by Egregius »
Do yourself a favor for the holidays and buy a Pi 3 for mediaplayer and let the 'old' one continue Domoticz.
I even overclocked my Pi3 to the maximum to ensure perfect playback.
trixwood
Post by trixwood »
:-) I went for the cheap option for some reason, but you're right pi3
