Vocal announcement - Good Morning Script
timbiker
Re: Vocal announcement - Good Morning Script
Post by timbiker »
With a little bit of help and a lot of work I have now a working announcement !
It's teaching me LUA !
Thanks !
seblang
Post by seblang »
This script is a good idee :-)
I need your help, instead of send the result in a vocal command I want to update a virtual text switch !
Below my script :
local timeNow= os.date("*t")
local curl='C:\\curl\\9\\bin\\curl.exe' --METTRE ICI LE CHEMIN DE VOTRE CURL
local tts_idx =337				-- idx capteur texte pour le tts
-- #############  REMISE A ZERO DE LA VARIABLE "BONJOUR" ENTRE 6H et 7H (la variable doit être de type chaîne) #################
if (timeNow.hour >=5 and timeNow.hour <6) then
   commandArray['Variable:bonjour'] = tostring (0)
-- #############  CONDITIONS NECESSAIRES A L'EXECUTION DU SCRIPT  #################
if (otherdevices['agenda google'] == 'On' and
timeNow.hour >=6 and
uservariables["bonjour"] == '0')
then
local sentence="Bonjour ! Nous sommes le " ..(os.date("%A")).. " " ..(os.date("%d")).. " " .. os.date("%B")
-- #############  PASSAGE DU JOUR ET DU MOIS EN FRANCAIS  #################
local d = {
      ["Monday"] = " Lundi ",
      ["Tuesday"] = " Mardi ",
      ["Wednesday"] = " Mercredi ",
      ["Thursday"] = " Jeudi ",
      ["Friday"] = " Vendredi ",
      ["Saturday"] = " Samedi ",
      ["Sunday"] = " Dimanche ",
      ["01"] = " premier ",
      ["02"] = " deux ",
      ["03"] = " trois ",
      ["04"] = " quatre ",
      ["05"] = " cinq ",
      ["06"] = " six ",
      ["07"] = " sept ",
      ["08"] = " huit ",
      ["09"] = " neuf ",
      ["January"] = " Janvier ",
      ["February"] = " Février ",
      ["March"] = " Mars ",
      ["April"] = " Avril ",
      ["May"] = " Mai ",
      ["June"] = " Juin ",
      ["July"] = " Juillet ",
      ["August"] = " Août ",
      ["September"] = " Septembre ",
      ["October"] = " Octobre ",
      ["November"] = " Novembre ",
      ["December"] = " Décembre "   }
      for k, v in pairs (d) do
          sentence = string.gsub(sentence, k, v)
-- #############  PROGRAMME D'ENCODAGE DU TEXTE POUR LE TTS  #################
function url_encode(str)
  if (str) then
    str = string.gsub (str, "\n", "\r\n")
    str = string.gsub (str, "([^%w %-%_%.%~])",
        function (c) return string.format ("%%%02X", string.byte(c)) end)
    str = string.gsub (str, " ", "+")
  return str
-- #############  TEMPERATURE ET METEO  #################
if (otherdevices['meteo local'])  then --METTRE ICI VOTRE DEVICE DE TEMPERATURE
temperature1, hygro1, etat1= otherdevices_svalues['Température extérieure']:match("([^;]+);([^;]+)")
-- print("TEMP:"..temperature1);
-- print("HUM:"..hygro1);
   sentence=sentence..". La température extérieure est de "..temperature1.." degré et le taux d'humidité est de "..hygro1.." pourcent. "
   json = (loadfile "C:\\cURL\\9\\bin\\JSON.lua")() --METTRE ICI LE CHEMIN DU JSON
   local city = "flagey-rigney"
   local wuAPIkey = "XXXXXXXX"
   local file=assert(io.popen(curl.. 'http://api.wunderground.com/api/'..wuAPIkey..'/forecast/lang:FR/q/France/'..city..'.json'))
   local raw = file:read('*all')
   file:close()
   local jsonForecast = json:decode(raw)
   prevision=jsonForecast.forecast.txt_forecast.forecastday[1].fcttext_metric  -- Prévision complète
-- prevision=jsonForecast.forecast.simpleforecast.forecastday[1].conditions  -- Prévision rapide
 local t = {
      ["ºC"] = "degré",
      [" ENE "] = " Est Nord Est ",
      [" NNE "] = " Nord Nord Est ",
      [" NE "] = " Nord Est ",
      [" N "] = " Nord ",
      [" NNO "] = " Nord Nord Ouest ",
      [" NO "] = " Nord Ouest ",
      [" SSE "] = " Sud Sud Est ",
      [" SE "] = " Sud Est ",
      [" S "] = " Sud ",
      [" SSO "] = " Sud Sud Ouest ",
      [" SO "] = " Sud Ouest ",
      [" O "] = " Ouest ",
      [" E "] = " Est ",
      ["km/h"] = " kilomètre heure"   }
      for k, v in pairs (t) do
          prevision = string.gsub(prevision, k, v)
sentence=sentence.."Le temps de la journée sera "..prevision
-- #############  AJOUT RISQUE DE GIVRE  #################
 if (otherdevices_svalues['alerte givre'])=='Risque de givre' then
      sentence=sentence.." Il y a peut etre du givre, soyez prudent."
   elseif (otherdevices_svalues['Risque de givre'])=='Présence de givre !' then
      sentence=sentence.." Attention il y a du givre, soyez très prudent!"
-- #############  AJOUT JOUR DES POUBELLES #################
   month=tonumber(os.date("%m"))
   day=tonumber(os.date("%d"))
-- TRash day : Mardi poubelle jaune (impair) / mardi poubelle verte (pair)
   numOfWeek=tonumber(os.date("%V"))
   numOfDay=os.date("%w")
   if (numOfDay == '2')  then -- mardi
   if (numOfWeek % 2 ==0)  then
      sentence=sentence.."La poubelle verte est rammassé aujourd'hui."  --pair
      sentence=sentence.."La poubelle jaune est rammassé aujourd'hui."  --impair
-- #############  ENCODAGE DU TTS  #################
sentence = url_encode(sentence)
-- #############  SORTIE DU TEXTE  #################
--print (sentence)
commandArray['UpdateDevice']= tts_idx ..'|0|'.. tostring(sentence) -- Mise à jour capteur txt
-- #############  PASSAGE DE LA VARIABLE BONJOUR A 1 POUR N'AVOIR LE MESSAGE QU'UNE SEULE FOIS PAR JOUR  #################
commandArray['Variable:bonjour'] = tostring (1)
I have done this change
--print (sentence)
and I have following error :
[string "--[[ ..."]:169: 'end' expected (to close 'if' at line 23) near
tanks in advance
regards
aleguid
Domoticz version: 3.6653
Post by aleguid »
Hello to all,
Great work this script is trying on in my raspberry but even after several attempts of resolution, I can not figure out where I am wrong.
Do you know how to give me a hand?
Error: EventSystem: in Notification: [string "indexCommand=1 ..."]:6: attempt to index global 'devicechanged' (a nil value)
indexCommand=1
if devicechanged['test'] == 'On' and --Motion sensor Living Room     ManualLaunchScript
   timeNow.hour >=16   and
   string.sub(uservariables_lastupdate['goodMorning'], 9, 10) ~= os.date("%d") -- Only one time per day
then
   local sentence="Buongiorno, oggi è "..tonumber(os.date("%d"))  -- Good morning, today we are the ..
aleguid
Post by aleguid »
Everything solved ... at least I hope ... I have to put inside the lua editor of domoticz "UserVariable"
JuanUil
Domoticz version: 4.11083
Post by JuanUil »
This is great!! I would like to use this as well but i seem to not succeed in installing izsynth.
I did:
sudo apt-get update
sudo apt-get install -y sox lame mplayer curl espeak wget bsdmainutils file mawk coreutils
But then when I do the next I get a error
pi@raspberrypi ~/domoticz/scripts $ izsynth -e naturalreaders -v Peter -t "Welco                        me home, mr Stark"
-bash: izsynth: no such command
tried this but also no luck :(
pi@raspberrypi ~/domoticz/izsynth $ cd /usr/local/bin
pi@raspberrypi /usr/local/bin $ wget https://raw.githubusercontent.com/ugoviti/izsynth/master/izsynth -O izsynth && chmod 755 izsynth
izsynth: Access denied
Some help would be appriciated.
I am on a rpi2B
greetz
Jan
JuanUil
Post by JuanUil »
Nobody?
jvdz
Domoticz version: 4.107
Post by jvdz »
According the WiKi you should do:
cd /usr/local/bin
wget https://raw.githubusercontent.com/ugovi ... er/izsynth -O izsynth && chmod 755 izsynth
As you got access denied I assume you need to run that last command with sudo.
Jos
JuanUil
Post by JuanUil »
Thanks for your reply Jos,
but I still get the same errors
Jan
jvdz
Post by jvdz »
you mean access denied, even when using sudo?
Jos
JuanUil
Post by JuanUil »
That is right
using sudo and everything installed but when I want to access izsyntz i get access denied.
Jan
jvdz
Post by jvdz »
Ok so you got one step further and got the command installed.
Sorry for being persistent but that is even when you use sudo on that command?
Jos
JuanUil
Post by JuanUil »
Yes even on that
pi@raspberrypi ~ $ cd /usr/local/bin
pi@raspberrypi /usr/local/bin $ izsynth
-bash: /usr/local/bin/izsynth: Toegang geweigerd
pi@raspberrypi /usr/local/bin $ sudo izsynth
sudo: izsynth: command not found
and while installing
pi@raspberrypi /usr/local/bin $ sudo wget https://raw.githubusercontent.com/ugoviti/izsynth/master/izsynth -O izsynth && chmod 755 izsynth
--2017-09-15 17:16:01--  https://raw.githubusercontent.com/ugoviti/izsynth/master/izsynth
Herleiden van raw.githubusercontent.com (raw.githubusercontent.com)... 151.101.36.133
Verbinding maken met raw.githubusercontent.com (raw.githubusercontent.com)|151.101.36.133|:443... verbonden.
HTTP-verzoek is verzonden; wachten op antwoord... 200 OK
Lengte: 71866 (70K) [text/plain]
Wordt opgeslagen als: ‘izsynth’
100%[======================================>] 71.866      --.-K/s   in 0,02s
2017-09-15 17:16:03 (2,88 MB/s) - '‘izsynth’' opgeslagen [71866/71866]
chmod: veranderen van toegangsrechten van ‘izsynth’: Bewerking niet toegestaan
jvdz
Post by jvdz »
OK, so that means the chmod didn't work and needs to be done with sudo as well.
sudo chmod 755 izsynth
Jos
JuanUil
Post by JuanUil »
Hi Jos,
Thanx, this works!!
izsynth - TTS/Text To Speech synthesizer, background music overlay assembler and        audio file converter for PBX and Home Automation Systems
Written by Ugo Viti <[email protected]>
version: 4.8 released: 20170909
usage: /usr/local/bin/izsynth [options]
Option:  Argument:           Description:
Input/Output file management:
   -                         Synthesize using standard input
  -t     <text>              Text string to synthesize
  -i     <file or directory> Input txt/wav/mp3 file or directory to synthesize/c        onvert (this disable '-t' option)
  -o     <directory>         Output directory to save synthesized and assembled        files (current: /dev/shm)
TextToSpeech management:
  -e     <engine>            TTS voice engine (current: naturalreaders)
  -v     <voice>             TTS voice language (current: Peter)
  -T     <volume>            TTS volume (current: none) (use a number from 0.01        to 1)
  -L                         List usable TTS engines
  -l                         List usable TTS voices
Background music management:
  -m     <file>              Input mp3/wav audio file to use as background music
  -S     <seconds>           Start background music after specified time (curren        t: 0 sec)
  -p     <seconds>           Pad the begin of the TTS audio using the specified        time (current: 5 sec)
  -P     <seconds>           Pad the end of the TTS audio using the specified ti        me (current: 5 sec)
  -F     <seconds>           Fade the begin and the end of the wav music using t        he specified time (current: 5 sec)
  -M     <volume>            Background music volume (current: none) (use a numb        er from 0.01 to 1)
Soundcard audio playback options:
  -b                         Playback the generated files using the soundcard sp        eakers (current: yes)
  -B                         Playback in background detaching the izsynth comman        d (current: yes) (only if PLAYBACK=yes)
  -k                         Playback command (current: mplayer)
  -K                         Playback command options (current: none)
  -d                         Playback output device (current: default)
  -D                         List available playback output devices
  -W     <volume>            Change the playback soundcard output volume (curren        t: none) (use a number from 0 to 100)
  -r                         Remove synthesized file after playback (current: no        ) (no = keep the generated high quality audio file for later usage)
Output file options:
  -x                         Export the generated audio file into PBX formats (c        urrent: no) (yes = this will assume PLAYBACK=no and OUTPUT_OVERWRITE=yes)
  -X                         Export using the following audio formats (current:        "44khz.wav wav gsm ulaw alaw slin") (valid only if EXPORT_AUDIO=yes))
  -w                         Overwrite the synthesized file (current: no)
  -s                         Split destination audio files into audio formats su        b directories (current: yes) (valid only if EXPORT_AUDIO=yes)
Misc options:
  -C                         Write/Overwrite the config file using the command a        rguments or the default izsynth variables (file: /home/pi/.config/izsynth/izsynt        h.conf)
  -h                         Display this help menu
  -H                         Display the 'naturalreaders' TTS Engine help menu
  -E                         Display izsynth usage examples
  -V                         Display izsynth version
Start working on the implementation now...
Again many thnx for your help
Jan
