Timeout notification while using USB hub
Isane
Domoticz version: Stable
Post by Isane »
Hardware:
Aeon Labs Aeotec Gen 5 Z-Wave USB
Synology DS215J
Speedlink SNAPPY - Active USB Hub 4-Port (powered)
When I connect the Aeon Labs Aeotec Gen 5 Z-Wave USB directly in the USB2 port in de Synology NAS the device is working without any problems.
When I put the USB hub between it (Aeotec USB -> USB HUB -> Synology) the Aeotec USB is not working in Domoticz (the device is still blinking blue - orange - red)
Domoticz gives the following log:
2016-12-20 10:52:50.621 OpenZWave: Version: 1.4-2282-gc286b14-dirty
 2016-12-20 10:52:50.622 OpenZWave: using config in: /usr/local/domoticz/Config/
 2016-12-20 10:52:51.692 OpenZWave: Received timeout notification from HomeID: 0, NodeID: 255 (0xff)
 2016-12-20 10:52:52.702 OpenZWave: Received timeout notification from HomeID: 0, NodeID: 255 (0xff)
 2016-12-20 10:52:53.712 OpenZWave: Received timeout notification from HomeID: 0, NodeID: 255 (0xff)
 2016-12-20 10:52:58.747 OpenZWave: Received timeout notification from HomeID: 0, NodeID: 255 (0xff)
 2016-12-20 10:52:59.760 OpenZWave: Received timeout notification from HomeID: 0, NodeID: 255 (0xff
I dont understand why. Can somebody explain it?
Egregius
Domoticz version: v2024.7
Re: Timeout notification while using USB hub
Post by Egregius »
Stick not receiving enough power?
Is it a powered USB hub?
Why do you need a hub? I have 6 USB ports on my Syno.
Isane
Post by Isane »
Egregius wrote:Stick not receiving enough power?
Thanks for your response. Yes its a powered USB hub.
I need it because the P1 USB meter and the Zwave stick are not working on my USB3 port.
I think is a driver issue, ive posted that issue here: viewtopic.php?t=2620&p=109661#p109588
