Execute script.securitycam no longer working (lua)
cherowley
Hi!
Since the last few betas the following command in my lua script no longer seems to work:
-- show cctv on other kodi devices
if otherdevices['Lounge (Kodi)'] ~= "Off" then commandArray['Lounge (Kodi)']='Execute script.securitycam' end
if otherdevices['Bedroom (Kodi)'] ~= "Off" then commandArray['Bedroom (Kodi)']='Execute script.securitycam' end
if otherdevices['Study (Kodi)'] ~= "Off" then commandArray['Study (Kodi)']='Execute script.securitycam' end
The script is ran but does not show any errors in the log and the kodi boxes do not popup the cctv. Nothing has changed besides the domoticz version...
Anyone else having a similar problem?
Last working Version: 3.5877
Cheers!
Cheers!
- Dnpwwo
Re: Execute script.securitycam no longer working (lua)
Nothing has been changed in the plugin as far as I know.
Can you switch the device into debug mode by changing the port number to -9090 in the hardware page and post the output?
cherowley
hi, thanks for the quick response
I changed the port to -9090 for the study kodi instance in the hardware tab and triggered the script:
2016-12-13 12:42:25.331 Kodi: (Study (Kodi)) Connect to '192.168.2.110:9090' failed: (111) Connection refused
2016-12-13 12:42:26.333 Kodi: (Study (Kodi)) Connect to '192.168.2.110:9090' failed: (111) Connection refused
2016-12-13 12:42:26.934 User: Admin initiated a switch command (298/Front Door PIR/On)
2016-12-13 12:42:26.992 LUA: Front Door PIR alert..
2016-12-13 12:42:26.992 EventSystem: Fetching url...
2016-12-13 12:42:26.992 EventSystem: Script event triggered: Front Door PIR
2016-12-13 12:42:26.935 (Virtual) Light/Switch (Front Door PIR)
2016-12-13 12:42:27.334 Kodi: (Study (Kodi)) Connect to '192.168.2.110:9090' failed: (111) Connection refused
2016-12-13 12:42:28.336 Kodi: (Study (Kodi)) Connect to '192.168.2.110:9090' failed: (111) Connection refused
2016-12-13 12:42:28.936 (Virtual) Light/Switch (Front Door PIR)
2016-12-13 12:42:30.339 Kodi: (Study (Kodi)) Connect to '192.168.2.110:9090' failed: (111) Connection refused
2016-12-13 12:42:31.341 Kodi: (Study (Kodi)) Connect to '192.168.2.110:9090' failed: (111) Connection refused
2016-12-13 12:42:32.342 Kodi: (Study (Kodi)) Connect to '192.168.2.110:9090' failed: (111) Connection refused
- Dnpwwo
Looks like the connection to your Kodi isn't working at all anymore (it is refusing connections)
Has the IP address changed? Have you upgraded your Kodi recently? Have you tried turning it off and on again?
cherowley
Woops! Me being dumb! I forgot to reload kodi (this instance is running on windows, the others libreelec).
Sorry, here's the output with kodi actually running lol:
6-12-13 13:05:16.351 Kodi: (Study (Kodi)) Connected to '192.168.2.110:9090'.
2016-12-13 13:05:16.353 Kodi: (Study (Kodi)) Event: 'On'.
2016-12-13 13:05:16.418 Kodi: (Study (Kodi)) Sending data: '{"jsonrpc":"2.0","method":"System.GetProperties","params":{"properties":["canhibernate","cansuspend","canshutdown"]},"id":1007}'
2016-12-13 13:05:16.426 Kodi: (Study (Kodi)) Handling message: '{"id":1007,"jsonrpc":"2.0","result":{"canhibernate":true,"canshutdown":true,"cansuspend":true}}'.
2016-12-13 13:05:16.426 Kodi: (Study (Kodi)) Sending data: '{"jsonrpc":"2.0","method":"Player.GetActivePlayers","id":1005}'
2016-12-13 13:05:16.433 Kodi: (Study (Kodi)) Handling message: '{"id":1005,"jsonrpc":"2.0","result":[]}'.
2016-12-13 13:05:17.419 Kodi: (Study (Kodi)) Sending data: '{"jsonrpc":"2.0","method":"JSONRPC.Ping","id":1001}'
2016-12-13 13:05:17.420 Kodi: (Study (Kodi)) Handling message: '{"id":1001,"jsonrpc":"2.0","result":"pong"}'.
2016-12-13 13:05:27.420 Kodi: (Study (Kodi)) Sending data: '{"jsonrpc":"2.0","method":"JSONRPC.Ping","id":1001}'
2016-12-13 13:05:27.422 Kodi: (Study (Kodi)) Handling message: '{"id":1001,"jsonrpc":"2.0","result":"pong"}'.
2016-12-13 13:05:37.422 Kodi: (Study (Kodi)) Sending data: '{"jsonrpc":"2.0","method":"JSONRPC.Ping","id":1001}'
2016-12-13 13:05:37.423 Kodi: (Study (Kodi)) Handling message: '{"id":1001,"jsonrpc":"2.0","result":"pong"}'.
2016-12-13 13:05:47.423 Kodi: (Study (Kodi)) Sending data: '{"jsonrpc":"2.0","method":"JSONRPC.Ping","id":1001}'
2016-12-13 13:05:47.425 Kodi: (Study (Kodi)) Handling message: '{"id":1001,"jsonrpc":"2.0","result":"pong"}'.
2016-12-13 13:05:57.425 Kodi: (Study (Kodi)) Sending data: '{"jsonrpc":"2.0","method":"JSONRPC.Ping","id":1001}'
2016-12-13 13:05:57.428 Kodi: (Study (Kodi)) Handling message: '{"id":1001,"jsonrpc":"2.0","result":"pong"}'.
2016-12-13 13:06:00.918 User: Admin initiated a switch command (298/Front Door PIR/On)
2016-12-13 13:06:00.988 LUA: Front Door PIR alert..
2016-12-13 13:06:00.988 EventSystem: Fetching url...
2016-12-13 13:06:00.989 EventSystem: Script event triggered: Front Door PIR
2016-12-13 13:06:00.919 (Virtual) Light/Switch (Front Door PIR)
2016-12-13 13:06:02.935 (Virtual) Light/Switch (Front Door PIR)
2016-12-13 13:06:07.428 Kodi: (Study (Kodi)) Sending data: '{"jsonrpc":"2.0","method":"JSONRPC.Ping","id":1001}'
2016-12-13 13:06:07.429 Kodi: (Study (Kodi)) Handling message: '{"id":1001,"jsonrpc":"2.0","result":"pong"}'.
2016-12-13 13:06:17.429 Kodi: (Study (Kodi)) Sending data: '{"jsonrpc":"2.0","method":"JSONRPC.Ping","id":1001}'
2016-12-13 13:06:17.430 Kodi: (Study (Kodi)) Handling message: '{"id":1001,"jsonrpc":"2.0","result":"pong"}'.
2016-12-13 13:06:27.431 Kodi: (Study (Kodi)) Sending data: '{"jsonrpc":"2.0","method":"JSONRPC.Ping","id":1001}'
2016-12-13 13:06:27.432 Kodi: (Study (Kodi)) Handling message: '{"id":1001,"jsonrpc":"2.0","result":"pong"}'.
- Dnpwwo
Looks like the command isn't being seen by the plugin at all.
gizmocuz did some clean up that area a month or so ago. When was the last time you upgraded?
cherowley
That's weird I replied yesterday but its gone!
I hadn't upgraded since the last "stable" earlier this year.
It works fine on the latest "stable". Noticed that the buttons on the kodi remote popup work ok on the beta.
cherowley
Is this a domoticz fault or the kodi plugin fault then?
cherowley
Right so logged on git but told to come back here!
"Use the forum" lol
Can someone confirm this problem and then how will it get fixed if its not allowed to be logged on lol?!
"Use the forum" lol
cherowley
Still can't seem to execute scripts/addons in kodi in the latest beta.
Last worked on the stable but was advised to try the beta as the stable has problems, doh!
- sincze
- Domoticz version: 2024.4
Ai I must admit, at the moment I am cheating a bit using https://github.com/Egregius/LUA-Pass2PHP-for-Domoticz.
Domoticz triggers the device (doorbell) -> passes it to pass2php.php -> that file kicks my .php file to start the securitycam to show up on all active kodi devices.
So unfortunately I can not answer the question if this is still working from LUA.
As a temporary fix maybe use os.execute to execute a bash file ?
In this case if IP Camera and keuken is on... it will trigger the plugin.
# IPCAM SNAPSHOT to Keuken
if [ $snapshot -eq 1 ] && ping -c 1 $keuken > /dev/null ; then
(wget -O /dev/null "http://$keuken:$port/jsonrpc?request={%22jsonrpc%22:%222.0%22,%22method%22:%22Addons.ExecuteAddon%22,%22params%22:{%22addonid%22:%22script.securitycam%22},%22id%22:%221%22}}") &
Pass2php
USB: RFXCom, ZWave, Sonoff 3
MQTT: ZIgbee2MQTT,
ZWAVE: Zwave-JS-UI
Solar: Omnik, PVOutput
Sensors: You name it I got 1.
MQTT: ZIgbee2MQTT,
ZWAVE: Zwave-JS-UI
cherowley
ah ok sincze, thanks for the additional info
If you ever find yourself with nothing to do feel free to try the following in a lua script to verify if it works for you
* where 'Lounge (Kodi)' is the name of the kodi instance....
