Notification Windows Phone
Mankan
Hi!
Is there someone using a Windows Phone for Domoticz? Ive been looking for an notification app as Pushbullet for Windows Phone but i cant find any compability notificationapp for this Phone. Anyone out there that have a good suggestion how to get notification from Domoticz to an Windows Phone?
Skickat från min iPhone med Tapatalk
Number8
- Domoticz version: 2022.1
Re: Notification Windows Phone
I cannot say better. You'll have to use the bot platform: https://telegram.org/blog/bot-revolutionEgregius wrote:https://telegram.org/
Debian buster on NUC and three RPi with buster.
- Egregius
- Domoticz version: v2024.7
Indeed, and then a custom HTTP notification like:
https://api.telegram.org/bot123456789:ABCD-xCRhO-RBfUqICiJs8q9A_3YIr9irxI/sendMessage?chat_id=123456789&text=#MESSAGE- bbqkees
- Domoticz version: 4.1x
You can use Pushalot.
When I still had a Windows Phone I used that one. Worked pretty well.
Number8
I've been using pushalot as well, was working well. But I moved to Telegram in order to have the same system accros platforms. Seems to have much more capabilities in the long term.
- Egregius
Yes, Telegram runs an all platforms.
We use it on iOS, Android, macOS, Windows,... Synchronizes perfectly.
There's even a CLI tool available for Linux.
Mankan
Perfect, is it even possible to get a specific notification for a specific device? For exemple, switch on or temperature high? If yes, how do you set to get your device notification?
Mankan
- Egregius
You always post twice?
You can set notifications in Domoticz when you edit a switch etc.
Or sent notifications from a script, then you have full control over it.
In my pass2php script for example I sent notifications with sound when we're not a sleep, else just a silent message.
Number8
You could also setup several bots
Envoyé de mon iPad en utilisant Tapatalk
Number8
Mankan
Thanks for your tips, it works perfect!
Mankan
PeterHarrie
You can also try http://www.notifymydevice.com ... completely free.
It even works on your desktop computer since it is a UWP.
