RFLink - USB Gateway - Introduction
433Mhz opensource Receiver & Transmitter.
Nautilus
Re: RFLink - USB Gateway - Introduction
Post by Nautilus »
sincze wrote:Last time I ordered solder service rflink 433 mhz
Had a separate nrf in a drawer. :)
Attached it with jumper wires to the arduino. (see wiring scheme)
Flashed the firmware.
And the whole thing is controlling my milight and 433mhz devices from within domoticz nicely.
Thanks for this info. I also just now learned there should be a female header on the PCB. And male pins on the NRF? So 8 female-to-male jumper cables should do it? Yay :D
sincze
Domoticz version: 2024.4
Post by sincze »
I connected my nrf with male to female connectors directly to the arduino mega not to the rflink. Rflink sits directly on arduino (different pins) Because when I bought it rflink was not prepared for additional nrf chip that could be used for milight. That had to be a separate nrf.
Sent from my SM-G925F using Tapatalk
Pass2php
USB: RFXCom, ZWave, Sonoff 3
MQTT: ZIgbee2MQTT,
ZWAVE: Zwave-JS-UI
Solar: Omnik, PVOutput
Sensors: You name it I got 1.
sincze
Post by sincze »
Watch the separate antenna for my milight
Pass2php
MQTT: ZIgbee2MQTT,
ZWAVE: Zwave-JS-UI
Nautilus
Post by Nautilus »
Thanks, so not exactly as I imagined it but quite close...:)
sincze wrote:Watch the separate antenna for my milight
Now I'm again bit slow. Isn't there a built in antenna on the NRF-chip?
sincze
Post by sincze »
As you can see the NRF has an on board antenna. Works just fine for me.
Pass2php
MQTT: ZIgbee2MQTT,
ZWAVE: Zwave-JS-UI
Nautilus
Post by Nautilus »
sincze wrote:As you can see the NRF has an on board antenna. Works just fine for me.
Correct, as I understood. Was wondering what you meant with "Watch the separate antenna for my milight" :)
sincze
Re: RE: Re: RFLink - USB Gateway - Introduction
Post by sincze »
That would be follow the jumper wires :) to the separate nrf antenna/nrf pcb hahaha
Pass2php
MQTT: ZIgbee2MQTT,
ZWAVE: Zwave-JS-UI
Nautilus
Post by Nautilus »
Right, got it :)
Nautilus
Post by Nautilus »
Well, I received the unit now and understand a little bit better now what we were talking about...:) But still not fully clear what is meant by this:
http://www.nemcon.nl/blog2/faq wrote:Q: Can I use the NRF24L01 socket on the Nodo PCB for Milight signals?
A: That depends on the Nodo PCB version.
Version 1.1.3 and higher: Yes.
Versions below 1.1.3: No, the NodoNRF socket uses a software SPI solution while the NRF for Milight is using the hardware SPI pins.
So, as I now have v. 1.1.4 does it then mean I can connect NRF24L01 directly to the socket that is on the Nodo PCB and control MiLights (in my interpretation that is just what it says in above quote)? If for some reason this would not be the case, then I'm a bit lost as it seams the Nodo PCB cover up some of the needed pins mentioned here:
http://www.nemcon.nl/blog2/wiring wrote:Pin 1 = (Ground) = Ground
Pin 2 = (VCC) = VCC (3.3 volt) Warning: Max 3.6 volt, do NOT connect to 5 volt!
Pin 3 = (CE) = MEGA Pin 48
Pin 4 = (CS) = MEGA Pin 49
Pin 5 = (SCK) = MEGA Pin 52
Pin 6 = (MOSI) = MEGA Pin 51
Pin 7 = (MISO) = MEGA Pin 50
Pin 8 = (IRQ) = Not Connected
Can someone verify I can connect NRF24L01 directly to the socket that is on the Nodo PCB to control Milights?
sincze
Post by sincze »
Sorry don't have version 1.1.4
Pass2php
MQTT: ZIgbee2MQTT,
ZWAVE: Zwave-JS-UI
sdsi
Post by sdsi »
artip wrote:
I've also found that Domoticz is able to read only status of command sent by remote. Is it possible to send commands from Domoticz as an remote at all?
Elmes works with coding Keeloq, and I think the rflink can't send these codes.
What about this? https://github.com/domoticz/domoticz/co ... 699452e810
Stuntteam
Post by Stuntteam »
RFLink can only receive the Elmes (Keeloq) signals.
sdsi
Post by sdsi »
Stuntteam wrote:RFLink can only receive the Elmes (Keeloq) signals.
Thanks. So RFLink can works with Elmes sensors, isin't it?
Stuntteam
Post by Stuntteam »
Yes, if you have an Elmes door contact, RFLink can receive the signals and you can connect actions within Domoticz with that.
If you have an Elmes controlled garage door, RFLink can receive the signals and you can connect actions within Domoticz with that.
However, you can not control (open/close) the garage door with RFLink.
sdsi
Post by sdsi »
Thanks a lot.
What about other Elmes sensors e.g. http://www.elmes.pl/pl/produkty/bezprze ... ktor-ruchu ?
domoticzkar
Post by domoticzkar »
Could PLEASE tell me the name and/or model specification of the really nice piggy-back-antenna-card?
I have tried to search for it on AliExpress, and none of the names I tries does work?
sincze wrote:Image
sincze
Post by sincze »
domoticzkar wrote:Hi
sincze wrote:Image
The green one is RFLINK board. http://www.nemcon.nl/blog2/
The separate antennas are NRF24L01+ tha black one is used for 433 mhz.
Pass2php
MQTT: ZIgbee2MQTT,
ZWAVE: Zwave-JS-UI
Huubke80
Domoticz version: 3.6722
Post by Huubke80 »
Yesterday I build my RF link with the RF link PCB v1.1.4. Uploading the latest firmware went Ok. Only don't receive any 433Mhz signals in the RF loader application, while the debug mode is enabled. In the terminal screen appears the Rf45 version, so there is some king of communication to the arduino2560 Mega.
On the RF link board is a orange LED continuous on.
Someone any idea or tips?
Stuntteam
Post by Stuntteam »
What do you see in the rflink loader screen?
Huubke80
Post by Huubke80 »
Stuntteam wrote:What do you see in the rflink loader screen?
The following :
20;00;Nodo RadioFrequencyLink - RFLink Gateway V1.1 - R45;
10;version;
10;status;
10;rfdebug=on;
10;rfudebug=on;
and the following in apllication debug screen:
Debug mode activated
Serial Log mode:
Port COM3
Serial port open: 000001D4
Serial port status: 0
Get Startup message
Send version command
Read version command response
Send status command
Starting timer
Logging...
