If you are interested in testing the iconset, please let me know.
New iconset (work in progress)
osiris
I am currently designing a new iconset for Domoticz. The screenshot shows the icons within the OsiDark theme.
Checkout the OsiDark theme for Domoticz
l00pz
Re: New iconset (work in progress)
Looking forward for this Icon Pack
And I'm interested in testing these icons.
- galadril
- Domoticz version: latest
Looks great!
Looks great, I would like to test it too !
I just changed the colors of Domoticz and wanted to integrate flat icons :
osiris
Great! Please note that the icons are designed to work with the OsiDark theme, it could be that some icons won't work very well on a white background.pouniok wrote:Hello,
Quax1507
I am also interested in testing...
osiris wrote: Great! Please note that the icons are designed to work with the OsiDark theme, it could be that some icons won't work very well on a white background.
No worries, I can add a CSS colored circle behind it in that case!
osiris
Making some progress on the menu icons
Derik
- Domoticz version: BETA
whoowww..
Great,....
Please integrated it in Domoticz....
Much better then the other options..
Great,....
satanasinc
- Domoticz version: 4.9700
Hi!
Great job! I like it.
Clean and minimalistic.
Please share it!
Greetings from spain.
Please share it!
osiris
Making progress on the on/off switch-type icons
- galadril
Let me know if you want me to try themosiris wrote:Making progress on the on/off switch-type icons
I installed OsiDark theme, selected in settings, but it is still showing the classic theme.
- galadril
clear cache of your browserhpapagaj wrote:I installed OsiDark theme, selected in settings, but it is still showing the classic theme.
Ahh, found the problem styles.css was not downloaded properly:
On the GitHub page:
-o should be -O
On the GitHub page:
wget https://raw.githubusercontent.com/basvdijk/domoticz-osidark-theme/master/dist/OsiDark/custom.css -o www/styles/osi-dark/custom.css-
osiris
Thanks fixed the docshpapagaj wrote:Ahh, found the problem styles.css was not downloaded properly:
On the GitHub page:
-o should be -OCode: Select all
nieass4
- Domoticz version: 2024.7
Nice work osiris, I would like to test the icons if possible.
Using your theme also looks nice and clean.
arcidodo
- Domoticz version: Latest
very nice work!! can i test the icon set? thanks!
piokuc
galadril wrote:Looks great!
Looks very very great. @Galadril maybe you can use this icon in app Domoticz on Android ? And maybe we can use in app android more type icon or add to app feature to user can change icon for devices to custom icon ?
And maybe @Gizmocuz can implement this icon to default icon in Domoticz ?
BTW
@osiris i found one bug in your theme. Slider on switch dimmer RGBW is oversize
I'am interested in the icons,
How can i get this set.
Regards,
Kevin
Regards,
Kevin
Users browsing this forum: madpatrick and 1 guest
