MyDomoticz - Testers wanted!
mirasp
Domoticz version: 3.5877
Re: Testers wanted!
Post by mirasp »
Hi, recently I don't see anything
2016-12-13 18-12-55.jpg (21.25 KiB) Viewed 4868 times
the same after update do v.3.5877
Error: PROXY: StartThread(): Exception: resolve: Host not found (authoritative) in logs every time after domoticz reboot
API key in place, MyDomoticz enable and Apps Allowed disabled in settings
browser cache cleared
thanks in advance for help
chimit
Domoticz version: master
Re: Testers wanted!
Post by chimit »
mirasp wrote:Hi, recently I don't see anything
If you get that message in your logs, then probably you are using the latest stable version of Domoticz.
In order to use MyDomoticz you need to switch to beta channel updates.
Or just be patient for the new stable release.
mirasp
Re: Testers wanted!
Post by mirasp »
Ok, thanks
Rolfie
Re: Testers wanted!
Post by Rolfie »
chimit wrote:
Rolfie wrote:Hi,
Recently I installed Domoticz (D) and also created the MyDomoticz (MD) account. But the dashboard from my D is not showing up in MD. I do have an API key that shows up in my settings. I'm running the beta channel (fully updated) and my log entry just displays:
PROXY: Authenticate result: success.
I do have a different error in my log that I think started when I switched from stable to beta, but not sure if thats related:
Error: PluginSystem: Failed load 'libpython3.5.so', Python probably not installed on system.
Already tried clearing my cache and refreshing my browser. Do you might have an idea what the issue could be? Thanks.
Rolf
In case you created more than one account, the api key might be different from the one that you use to log in.
I'm just using one account.
chimit
Re: Testers wanted!
Post by chimit »
Rolfie wrote:
chimit wrote:
Rolfie wrote:Hi,
Rolf
If you PM me that account, I'll have a look for you.
chimit
Re: Testers wanted!
Post by chimit »
Thanks @Rolfie for reporting that the dashboard has issues with the some Firefox and Edge browsers.
We will look into the issue.
bbos
Re: Testers wanted!
Post by bbos »
Mydomoticz has stopped working 2 days ago (after working for a couple of weeks).
After logging I can see that my instance is red.
The only thing which changed on my setup is that my rooters are now cascaded (iso 2 rooters with each a hdcp server).
This is what I see in the log:
2016-12-29 19:47:36.493 Proxymanager started.
2016-12-29 19:47:51.673 PROXY: Authenticate result: IP not whitelisted.
2016-12-29 19:48:51.695 Error: PROXY: timeout occurred, reconnecting
after trying some things I am seeing:
2016-12-29 19:59:51.208 Error: PROXY: Error resolving domoproxy.domoticz.com: Host not found (authoritative)
any tips how I could solve this problem?
chimit
Re: Testers wanted!
Post by chimit »
bbos wrote:Hi,
In the settings of the Domoticz icon in your dashboard, check if the proper IP address of your Domoticz connection is listed.
When in doubt, just make it empty.
Possibly it can also be an ipv6 address.
== Rene
bbos
Re: Testers wanted!
Post by bbos »
chimit wrote:
bbos wrote:Hi,
== Rene
This fixed the problem! thank you very much!
desertdog
Domoticz version: 2020.1
Re: Testers wanted!
Post by desertdog »
" the settings of the Domoticz icon in your dashboard,"
where would that be. I can't find anywhere where i can change an ip address
chimit
Re: Testers wanted!
Post by chimit »
If you click on the name "My Domoticz" (by default) you will get the settings screen.
tontze
Domoticz version: Beta Ch
Re: Testers wanted!
Post by tontze »
I just made MD account, it just wont work :) API key is i its place and enabled from settings. Nothing appears, in wiki it says to look possible errors in logs, what logs and where ?
Smartthings
zigbee2mqtt
RFLink 433mhz / Nrf 2.4Ghz
Mi Light
esp8266MiLight Hub
chimit
Re: Testers wanted!
Post by chimit »
tontze wrote:I just made MD account, it just wont work :) API key is i its place and enabled from settings. Nothing appears, in wiki it says to look possible errors in logs, what logs and where ?
You can access the Domoticz logs from the settings menu in Domoticz.
What browser are you using?
tontze
Re: Testers wanted!
Post by tontze »
I'm using Chrome.
Smartthings
zigbee2mqtt
Mi Light
esp8266MiLight Hub
tontze
Re: Testers wanted!
Post by tontze »
I'm using Chrome.
2017-01-23 12:07:01.630 Error: PROXY: StartThread(): Exception: resolve: Host not found (authoritative)
This kind of error found from log
Smartthings
zigbee2mqtt
Mi Light
esp8266MiLight Hub
tontze
Re: Testers wanted!
Post by tontze »
tontze wrote:
I'm using Chrome.
Yeah, thought i was in beta channel, but i wasnt .. Sry for the trouble ...
Smartthings
zigbee2mqtt
Mi Light
esp8266MiLight Hub
BluesBro
Re: Testers wanted!
Post by BluesBro »
Is there a way to include user:password on the my.domoticz path for instant log in?
EXAMPLE:
https://my.domoticz.com/my/user:passwor ... /Dashboard
tontze
Re: Testers wanted!
Post by tontze »
mydomo is down ?
2017-01-26 21:57:45.758 Error: PROXY: timeout occurred, reconnecting
2017-01-26 21:57:45.759 Error: PROXY: Connect failed, reconnecting: Network is unreachable
Smartthings
zigbee2mqtt
Mi Light
esp8266MiLight Hub
bobvanoijen
Re: Testers wanted!
Post by bobvanoijen »
No connection here either:
2017-01-26 21:34:16.264 Error: PROXY: timeout occurred, reconnecting
2017-01-26 21:34:16.264 Error: PROXY: Handshake failed, reconnecting: Operation canceled
my.domoticz.com says:
Last seen: 26-01-2017 11:40:20
Last visited: 26-01-2017 15:01:56
berglund76
Domoticz version: 3.6496
Re: Testers wanted!
Post by berglund76 »
I have the same problem..
