Meaning...?Madgeni wrote:async callbacks via the API call
New kind of Amazon Dash button to start tasks
Re: RE: Re: New kind of Amazon Dash button to start tasks
probably in the context of making one device call, not much. but node is built for asynchronicity, so good practice to not let your code block
thanks!!
My Setup: Pi, RFXtrx433, HomeEasy: 13 Dimmers & 4 Sockets, 2 motion-sensors, 3 magnetic switches, 1 OWL Electricity Sensor, 3 Oregon Temp Sensor.
ok so next question.. I have set this up and is working... How do I get the program to launch on boot of the Pi?
I'm a bit of a noob when it comes to the pi
I have checked rc.local but I cant see where Domoticz is stating on boot to I assume this is the wrong place.
pi@raspberrypi:~/node_modules/node-dash-button $ sudo node node-dash.js
go it...
in the /etc/rc.local file I added the line. seems to have done the trick.
I did notice this created 2 processes:
Is this normal? do I need the sudo?
sudo node /home/pi/node_modules/node-dash-button/node-dash.js &
root 444 1 0 21:55 ? 00:00:00 sudo node /home/pi/node_modules/node-dash-button/node-dash.js
root 465 444 3 21:55 ? 00:00:04 node /home/pi/node_modules/node-dash-button/node-dash.js
- Domoticz version: V2022.2
I'm experiencing the same thing, i.e., 2 processes get created, one with sudo, one without:
I'm using @pdjm43's code (with my MAC addresses):
If I run this as
then the second process reverses the effect of the first, i.e., toggles the light back again!
root 27739 0.0 0.3 6184 3092 pts/0 T 23:02 0:00 sudo node node-dash.js
root 27743 3.7 3.9 110804 37352 pts/0 Tl 23:02 0:02 node node-dash.js
#!/usr/bin/env node
var dash_button = require('node-dash-button');
var dash = dash_button(["50:f5:da:38:e1:f0","ac:63:be:17:2f:4a"], null, null, 'arp'); //mac address from node-dash-button$
var requestify = require('requestify');
dash.on("detected", function (dash_id){
if (dash_id === "50:f5:da:38:e1:f0"){
console.log("Dash1");
requestify.get('http://127.0.0.1:8080/json.htm?type=command¶m=switchlight&idx=118&switchcmd=Toggle');
} else if (dash_id === "ac:63:be:17:2f:4a"){
console.log("Dash2");
requestify.get('http://127.0.0.1:8080/json.htm?type=command¶m=switchlight&idx=221&switchcmd=Toggle');
nohup sudo node node-dash.js &
Mike,
I'll post my script later but I was thinking as an improvement to the script I am thinking about creating a dummy button for each dash button. so then when I have set it up initially I don't need to edit the file. From that I can just use the json queries in the on and off actions on that dummy button to kick off the relevant activity.
So this way you can then use the Domoticz GUI to edit everything.
I suppose you could go one step further and read an array of values from the Domoticz variables and then the script would be independent from the mac addresses and the IDX values.
Thoughts?
Thoughts?
Yes, I can see that this would be useful, although it's no great hardship to edit the script and add the MAC addresses and IDX's - this is only a one-time activity.
BTW, I was initially concerned about these becoming useless once the battery dies (I bought 2 used on eBay), but I have managed to carefully score around the join, and there is a Duracell AAA battery inside (and I've put it back together again!).
- Domoticz version: v3.8975
They are £5 each at Amazon (or free if you make one order) so in my view no need to be concerned. In theory one can change them every year.MikeF wrote:BTW, I was initially concerned about these becoming useless once the battery dies (I bought 2 used on eBay)
Thought your investigation comes very useful. Thank you.
Nice one on the battery. I wouldn't have thought it was a AAA inside even though I did think the device was a bit large. It will be interesting to see how long these last. I suspect this will very much depend on usage
My code calling a bunch of dummy switches which in turn run a json command to perform the aciton I want. this way I know when its a dash button thats turned something on as it will show in the dummy switch log
I used a case statement instead of a if else
- Spoiler: show
Just bought two more of these on eBay - Andrex and Rimmel. Both registered OK with Amazon, but when I run findbutton and press the Rimmel button, I get
- also, the light glows yellow twice before the usual 5 sequences of red flashes. Is this a 'rogue' button, or do the yellow flashes mean low battery? (this is not mentioned on the Amazon help page: About the Indicator Light on Dash Button)
Separately, I've created a python routine using scapy, which seems to be simpler than the node.js version:
(Dash 2 runs a bash script which triggers a heating boost through my Hive Home Heating system.)
Possible dash hardware address detected: 34:d2:70:29:a3:2a Manufacturer: unknown Protocol: udp
Possible dash hardware address detected: 34:d2:70:29:a3:2a Manufacturer: unknown Protocol: arp
from scapy.all import *
import os
import requests
def arp_display(pkt):
if pkt[ARP].op == 1: #who-has (request)
if pkt[ARP].hwsrc == '50:f5:da:38:e1:f0': # ARP Probe
print "ARP Probe from: Dash 1 " + pkt[ARP].psrc
url = 'http://127.0.0.1:8080/json.htm?type=command¶m=switchlight&idx=136&switchcmd=Toggle'
r = requests.get(url)
if pkt[ARP].hwsrc == 'ac:63:be:17:2f:4a': # ARP Probe
print "ARP Probe from: Dash 2 " + pkt[ARP].psrc
os.system("bash /Users/mjf2708/HA/hive_boost.sh")
if pkt[ARP].hwsrc == 'ac:63:be:c8:84:93': # ARP Probe
print "ARP Probe from: Dash 3 " + pkt[ARP].psrc
# not yet allocated
if pkt[ARP].hwsrc == '34:d2:70:29:a3:2a': # ARP Probe
print "ARP Probe from: Dash 4 " + pkt[ARP].psrc
# not yet allocated
print sniff(prn=arp_display, filter="arp", store=0, count=0)
all you really care about is the MAC address so should work fine even if its a rogue button
Agreed. I just wondered if anyone knew the significance of the LED flashing yellow?
- Target OS: -
Hello guys. I am trying to set this up as a doorbell can anyone guide me with that process or share their method.
I see that most implementations in this thread focus on switch items on and off, so was wondering how to get it to lay a sound or tts when pushed.
