Scene Timers Read in LUA
TimH
- Domoticz version: 3.5877
it is possible to read out the Timers of a Scene in LUA and the Command(On/Off)?
TimH
TimH
- jvdz
- Domoticz version: 4.107
Re: Scene Timers Read in LUA
This is a way to do a JSON call and translate the returned data:
Jos
-- LUA to get GASMETER usage
-- Load necessary Lua libraries
http = require "socket.http";
socket = require "socket";
https = require "ssl.https";
JSON = require "JSON";
--~ --Get Scene Timers
local t, jresponse, status, decoded_response,idx
-- ### update the next 2 lines ##########################################
idx=9 -- IDX of the Scene
t = "http://192.168.xx.xx:8080/json.htm?type=scenetimers&idx="..tostring(idx)
jresponse, status = http.request(t)
decoded_response = JSON:decode(jresponse)
result = decoded_response["result"]
-- List all SceneTimers
if result == nil then
print(os.date("%X").." No scene timers found for IDX "..idx)
for i = 1, #result do
record = result[i]
if type(record) == "table" then
day = record["d"]
value = record["v"]
print(os.date("%X").." "..i..
" Active="..record["Active"]..
" Cmd="..record["Cmd"]..
" Date="..record["Date"]..
" Hue="..record["Hue"]..
" Level="..record["Level"]..
" Randomness="..record["Randomness"]..
" Time="..record["Time"]..
" Type="..record["Type"]..
" idx="..record["idx"]
TimH
Thank you. I will try it the next days.
TimH
i have tried your Script but i got some failure with the libraries.
I use a Synology Diskstation to run Domoticz and this don't have the libraries.
Searching the Internet don't look good for Synology Lua Libraries.
Have anybody the right libraries or a idea where i can fount them?
- jvdz
The libraries can be found here: https://www.domoticz.com/wiki/Remote_Co ... _Libraries
This is a description for a Raspberry Pi so might need tweaking.
Jos
Jos
TimH
thank you for the Link.
I tried to translate it to Synology but i get failure.
Where are defined the Folder, where the location of the Libraries?
- jvdz
I think the error message, you get about not being able to find the require("LIB"), is telling you in which directories it was looking for these functions? at least that is what I seem to remember happening for me on a raspberry.
Jos
Jos
TimH
HI.
error Message in domoticz:
I have unpack the Files as indicated in the instructions and in the existing LUA-Folder from the Diskstation.
But i Think i must change the locating Folder for the Library.
2016-12-14 08:14:03.753 Error: EventSystem: in READOUT: [string "-- LUA to get GASMETER usage..."]:3: module 'socket.http' not found:
no field package.preload['socket.http']
no file '/usr/local/share/lua/5.2/socket/http.lua'
no file '/usr/local/share/lua/5.2/socket/http/init.lua'
no file '/usr/local/lib/lua/5.2/socket/http.lua'
no file '/usr/local/lib/lua/5.2/socket/http/init.lua'
no file './socket/http.lua'
no file '/usr/local/lib/lua/5.2/socket/http.so'
no file '/usr/local/lib/lua/5.2/loadall.so'
no file './socket/http.so'
no file '/usr/local/lib/lua/5.2/socket.so'
no file './socket.so'
wervisser
- Domoticz version: 2020.1
Bump...
Did you by any chance got this fixed ?
niki_lauda
Did you fix it?TimH wrote: Wednesday 14 December 2016 18:38 HI.
error Message in domoticz:I have unpack the Files as indicated in the instructions and in the existing LUA-Folder from the Diskstation.Code: Select all
2016-12-14 08:14:03.753 Error: EventSystem: in READOUT: [string "-- LUA to get GASMETER usage..."]:3: module 'socket.http' not found: no field package.preload['socket.http'] no file '/usr/local/share/lua/5.2/socket/http.lua' no file '/usr/local/share/lua/5.2/socket/http/init.lua' no file '/usr/local/lib/lua/5.2/socket/http.lua' no file '/usr/local/lib/lua/5.2/socket/http/init.lua' no file './socket/http.lua' no file '/usr/local/lib/lua/5.2/socket/http.so' no file '/usr/local/lib/lua/5.2/loadall.so' no file './socket/http.so' no file '/usr/local/lib/lua/5.2/socket.so' no file '/usr/local/lib/lua/5.2/loadall.so' no file './socket.so'
niki_lauda
Did you fix it?
