Hardware: Raspberry Pi Model 2B / RFLink R45
OS: Linux Domoticz 4.4.21-v7+ #911 SMP Thu Sep 15 14:22:38 BST 2016 armv7l GNU/Linux
Domoticz branch: beta
Version number / build hash: V3.6081 / 777cb17
Bug/problem or a question: Bug
Occurs:Noticed it just now
Problem: Since updating from V3.6046 to V3.6081 this afternoon the blinds switches stopped working.
I'm using an event which opens and closes the blinds of my bedroom every day. This morning they opened as usual but early afternoon I updated Domoticz to V3.6081 and just now I noticed the bedroom blinds were still open. So I tried to manually close them from the Domoticz dashboard but the switches did not react at all. Then I looked up the remote which used to operate the switches and with that I was able to close the blinds. I also noticed that Domoticz registered the remote commands and indicates that the blinds are closed. Yet I still can not operate the blinds from Domoticz!
I also have a sunshade on the first floor which is operated by a blinds switch. That one is also not working from domoticz while it does work with the remote (and also that remote is registered by Domoticz!).
Steps already tried: I pressed the update button and updated to V3.6129 / d540e35 but that did not fix it. I don't know how to revert Domoticz back to V3.6046 otherwise I would have tried that!
I also updated RFLink from R44 to R45 but that did not change anything either!
Even though the lights one floor higher switches perfectly I tried moving around the antenna, just to make sure it's not a sudden signal problem. That also did not change anything.
Blinds switches not working since updating from V3.6046 to V3.6081.
IanPH
Re: Blinds switches not working since updating from V3.6046 to V3.6081.
I just successfully downgraded Domoticz to V3.5877 / 15b013c and now my blinds as well as my sunshade are working again!
To be sure that the problem is really there, I also updated from V3.5877 to V3.6129 and again the blinds switches stop working. So it's clearly a bug.
Just to be clear, the 'normal' light switches all work properly! It's only the blinds switches that break!
**EDIT**
When changing the switch type from "Blinds" to "On/Off" the blinds work! But when changed back to "Blinds" to do not work!
**EDIT**
