Write image Raspian Jessie Lite on sd-card.
1. sudo raspi-config
1.1 expand Filesystem
1.2 Change User Password
1.3 Change Timezone: set to appropriate timezone
1.4 Advanced Options: Option A3. Memory Split: Set to 16M since we don't need a graphical environment
1.5 Advanced Options: Option A0. Update
1.6 sudo reboot
2. sudo apt-get update
3. sudo apt-get upgrade
4. sudo reboot
5. sudo apt-get install rpi-update
6. sudo rpi-update
7. sudo nano /boot/config.txt
add to end of the file:
dtoverlay=pi3-disable-bt
8. removing 'console=serial0,115200' from cmdline.txt
sudo nano /boot/cmdline.txt
9. sudo systemctl disable hciuart
10. sudo stty -F /dev/ttyAMA0 9600
11. sudo reboot
12. sudo curl -L install.domoticz.com | bash
Yes I'm using RaZberry2, type OpenZWave USB with /dev/ttyAMA0 in Domoticz!
Good luck!
