Is Domoticz able to activate RGBW animation programs?
Derik
Re: Is Domoticz able to activate RGBW animation programs?
Post by Derik »
mmm thanks all
Works great!!
Is there perhaps a option to set a color on this way to?
Derik
Post by Derik »
Brutus wrote:To switch the animation program off you can use the following URL:
http://192.168.1.5:8080/json.htm?type=c ... tchcmd=Off
Change the IDX to the IDX of the RGBW switch in your installation.
This give a error by me...
Brutus
Post by Brutus »
Did you change the IP adress and the IDX to your RGBW color selector Dimmer switch?
1x Intel NUC8i5BEK (Windows 10 x64) Domoticz on Virtualbox with DietPi.
1x Aeon Labs USB Z-Stick S2
1x P1 Smart Meter USB
28x Fibaro Modules
SMA Solar System
Daikin Airco / Heating
Denon DHT-S716H & DSW-1H
Derik
Post by Derik »
@ Brurus..
Yes.
The scenes are working well so the IP cannot be the problem
Derik
Post by Derik »
Are ther not more options to for other scenes or colors mis a rolling color etc.
Brutus
Post by Brutus »
Derik wrote:@ Brurus..
Yes.
The scenes are activated though the interface. My command uses the JSON interface of Domoticz. You need to use your own Internal IP adres or use the localhost adres 127.0.0.1 when you run the browser on the same device as domoticz is running from.
28x Fibaro Modules
SMA Solar System
Derik
Post by Derik »
http://192.168.5.70:8080/json.htm?type=command&param=switchlight&idx=27&switchcmd=Off
this i my code
ERR
is what i get
stuiow
Domoticz version: 3.6857
Post by stuiow »
I've only discovered all this today, but i found that by using chrome, that Developer (F12) feature, I just turned off my RGBW in the Switches screen and the command that appeared when i did that, i copied that and used that as the HTTP command for turned off the RGBW controller.
I did note the IDX value was different for that command though from the pre-programmed programs
Very effective and handy tool that Chrome Developer.
My code is this to turn off my RGBW unit.
[code]http://192.168.1.106:8080/json.htm?type ... &passcode=[/code]
Now setup on a RPI3.
Also using Evohome HGI80, RFXTRX433E and a Aeotec Gen5 stick. Mainly a Gen5 Z-Wave system.
My weather (Davis vantage Pro2) data is obtained by weatherunderground
Now collecting rtl_433 data from Apollo Ultrasonic meter
Derik
Post by Derik »
still got it working...
Shame on me, different IDX...
Only 1 problem....
The ligt is not in the normal modus in Domoticz..
When i turn the light on in Domoticz, stil get the last scene i did activate..
astrapowerrr
Post by astrapowerrr »
Hi there,
reading this topic is triggering me to make this kind of setup.
but i have a question?
is it possible to set the speed of the colors to some lowspeed like maybe 2 minutes before changing it to the other color?
the Rainbow program looks good but its fast and not picking all colors??
Brutus
Post by Brutus »
astrapowerrr wrote:Hi there,
These programs a coded in to the Fibaro Modules. So I think it is not possible to adjust them.
28x Fibaro Modules
SMA Solar System
astrapowerrr
But when you would like to create this?
There is a script somewhere??
I think I'm not the first one with this question I think?
astrapowerrr
he guys,
thanks for guiding into the programs...
i want to level this up and go to through the full color set....
for example i want to use the tint numbers to set..
can you adjust this within domotics? and yes where do i set this
DanM
Post by DanM »
This worked wonderfully for me for a few weeks but just seems to have stopped. When I go to the relevant url I get
"status" : "OK",
"title" : "ApplyZWaveNodeConfig"
Which seems to imply It worked fine.. but nothing further happens.. anyone got any ideas?
astrapowerrr
same here not workin anymore and get the same ok code as you get :oops: :oops:
dre68
Domoticz version: latest
Post by dre68 »
Domoticz 4.9700 running over here, no problems, still able to run the rgbw programs
Brutus
Post by Brutus »
I have noticed also the programs aren't working anymore. After looking at the URL's I saw the problem:
For example this is the Rainbow url for me now:
http%3A//192.168.1.5%3A8080/json.htm%3Ftype%3Dcommand%26param%3Dapplyzwavenodeconfig%26idx%3D40%26valuelist%3D72_Nw%253D%253D
The link has some HTML encoding inserted that needs to be replaced by the original symbols. Example:
%3A = :
%3D = =
%3F = ?
%25 = %
%26 = &
Source: http://krypted.com/utilities/html-encoding-reference/
So when we correct this the new link is:
http://192.168.1.5:8080/json.htm?type=command&param=applyzwavenodeconfig&idx=40&valuelist=72_OA%3D%3D
Now my programs are working again in the selector switch.
28x Fibaro Modules
SMA Solar System
hestia
Domoticz version: 2022.1
Post by hestia »
I've tried this, without success :-(
I don't have any error in the log, but nothing change.
FIBARO System FGRGBWM441 RGBW Controller
Version: 4.11503
Any idea?
hestia
Post by hestia »
solved with
../json.htm?type=command&param=applyzwavenodeconfig&idx=10&valuelist=7_RG9vciBiZWxsIG11c2lj%3D
would change it to 'Door bell music' (because 'RG9vciBiZWxsIG11c2lj' is the result of Base64 encoding 'Door bell music'). Note: Any '%3D' and such in the plist are the result of URI encoding an '=' or other non-alphanumeric character.
The easiest way to learn about this is to change a zwave device parameter manually using your browser while you have developer tools enabled (hit 'ctrl-shift-i' in Chrome). Look under the network tab at the JSON sent back by the browser to Domoticz when you click on 'Apply Configuration for This Device'.
in https://www.domoticz.com/wiki/Domoticz_API/JSON_URL%27s
I didn't have the right idx (still don't why this value, but I found it with ctrl-shift-i' in Chrome)
