Lua script for uploading energy values to PVoutput
markk
Re: Lua script for uploading energy values to PVoutput
Thanks for your help.
Re your first point, I don't know what you mean by "print PVO_URL". Sorry for being so stupid.
EDIT: Re your second point. Yes, I had the api and sid the wrong way around. The script now runs and connects to PVOutput but no energy generation is uploaded. It is just uploading a value of 0kwh.
markk
I've amended the script slightly to upload my energy used data and, although the daily used total is uploading ok, the Power isn't. This is just showing 0w all the time. My generation is currently being uploaded by PVuploader so power generation is showing on this. I'd love to know how to get the power to show so that I can use Lua for both.
I've attached the sample to show what is being shown and the script i'm using. I'd be grateful if someone could help please.
balans
- Domoticz version: stable
Hi i`m having difficulty when following the wiki
i use the script_device_calculate_consumption.lua wich looks doing ok on the dashboard doiing its calculations from my solarpanels and p1 meter
the script_time_upload_to_PVoutput.lua however does nothing and gives a error in the log
Error: EventSystem: in /home/pi/domoticz/scripts/lua/script_time_upload_to_PVoutput.lua: .../domoticz/scripts/lua/script_time_upload_to_PVoutput.lua:90: attempt to index field '?' (a nil value)
when i run the script manual using
pi@minibian:~/domoticz/scripts/lua$ lua script_time_upload_to_PVoutput.lua
lua: script_time_upload_to_PVoutput.lua:83: attempt to index global 'otherdevices_svalues' (a nil value)
stack traceback:
script_time_upload_to_PVoutput.lua:83: in main chunk
[C]: in ?
this same sort of error is also there in
pi@minibian:~/domoticz/scripts/lua$ lua script_device_calculate_consumption.lua
lua: script_device_calculate_consumption.lua:51: attempt to index global 'otherdevices_svalues' (a nil value)
stack traceback:
script_device_calculate_consumption.lua:51: in main chunk
[C]: in ?
i copied the scripting files multiple times with notepad ++ from the wiki just to make sure i didn`t made a copy failure
but i just cant seem to figure this one out with my skills
maybe some package missing
stack traceback:
[C]: in ?
stack traceback:
[C]: in ?
-- /home/pi/domoticz/scripts/lua/script_device_calculate_consumption.lua
-- This script collects the values below from Domoticz
-- * The Power and energy values (import and export) from a smartmeter
-- * The Power and energy values from a Solar power inverter
-- It then calculates the consumed power and energy from the values above with the formula's
-- * EnergyConsumption = EnergyGeneration + EnergyImport - EnergyExport
-- * PowerConsumption = PowerGeneration + PowerImport - PowerExport
-- It then updates a virtual device which displays the consumed power and energy in Domoticz
-- Domoticz IDX and names of the needed devices
local GenerationDeviceName = "Zonnenpanelen" -- Device name of the Generated energy
local EnergyDeviceName = "Power" -- Name of the energy device that shows imported and exported energy
local ConsumptionIDX = 15 -- IDX of the energy device that shows calculated Consumption
local ConsumptionDeviceName = "consumption" -- Name of the energy device that shows calculated Consumption
-- Require parameters
local http = require("socket.http")
-- Script parameters
EnergyImportLow = 0 -- in Watt hours
EnergyImportHigh = 0 -- in Watt hours
EnergyExportLow = 0 -- in Watt hours
EnergyExportHigh = 0 -- in Watt hours
EnergyGeneration = 0 -- in Watt hours
PowerGeneration = 0 -- in Watts
EnergyImport = 0 -- in Watt hours
PowerImport = 0 -- in Watts
EnergyConsumption = 0 -- in Watt hours
PowerConsumption = 0 -- in Watts
Debug = "NO" -- Turn debugging on ("YES") or off ("NO")
-- Lua Functions
function update(device, id, power, energy, index)
commandArray[index] = {['UpdateDevice'] = id .. "|0|" .. power .. ";" .. energy}
-- CommandArray
-- Generated
PowerGeneration, EnergyGeneration = otherdevices_svalues[GenerationDeviceName]:match("([^;]+);([^;]+)")
if Debug=="YES" then
print(" ----- PowerGeneration = " .. PowerGeneration .. " W");
print(" ----- EnergyGeneration = " .. EnergyGeneration .. " Wh");
-- Imported Exported
EnergyImportLow, EnergyImportHigh, EnergyExportLow, EnergyExportHigh, PowerImport, PowerExport = otherdevices_svalues[EnergyDeviceName]:match("([^;]+);([^;]+);([^;]+);([^;]+);([^;]+);([^;]+)")
EnergyImport = EnergyImportLow + EnergyImportHigh
EnergyExport = EnergyExportLow + EnergyExportHigh
print(" ----- PowerImport = " .. PowerImport .. " W");
print(" ----- EnergyImportLow = " .. EnergyImportLow .. " Wh");
print(" ----- EnergyImportHigh = " .. EnergyImportHigh .. " Wh");
print(" ----- EnergyImport = " .. EnergyImport .. " Wh");
print(" ----- PowerExport = " .. PowerExport .. " W");
print(" ----- EnergyExportLow = " .. EnergyExportLow .. " Wh");
print(" ----- EnergyExportHigh = " .. EnergyExportHigh .. " Wh");
print(" ----- EnergyExport = " .. EnergyExport .. " Wh");
-- Calculate consumption
print(" ----- PowerConsumption = " .. PowerConsumption .. " W");
print(" ----- EnergyConsumption = " .. EnergyConsumption .. " Wh");
-- Update comsumption device in Domoticz
if devicechanged[EnergyDeviceName] then
update(ConsumptionDeviceName, ConsumptionIDX, PowerConsumption, EnergyConsumption, 1)
return commandArrayCode: Select all
-- /home/pi/domoticz/scripts/lua/script_time_upload_to_PVoutput.lua
-- * The Power generation, energy generation and voltage from a Solar power inverter
-- * The temperature from a outside temperature sensor
-- * The Power consumption and energy consumption which is calculated in another Lua script
-- And uploads all of the values to a PVoutput account.
-- For more information about PVoutput, see their user documentation on http://www.pvoutput.org/help.html
-- Domoticz IDX of devices
local VoltageDeviceName = "Volt uac1" -- Name of the voltage device that shows voltage of the inverter
local TemperatureDeviceName = "Temperature SMA" -- Name of the temperature device that shows outside temperature
-- PVoutput parameters
local PVoutputApi = "xxxxx" -- Your PVoutput api key
local PVoutputSystemID = "xx" -- Your PVoutput System ID
local PVoutputPostInterval = 5 -- The number of minutes between posts to PVoutput (normal is 5 but when in donation mode it's max 1)
local PVoutputURL = '://pvoutput.org/service/r2/addstatus.jsp?key=' -- The URL to the PVoutput Service
EnergyGeneration = 0 -- v1 in Watt hours
PowerGeneration = 0 -- v2 in Watts
EnergyConsumption = 0 -- v3 in Watt hours
PowerConsumption = 0 -- v4 in Watts
CurrentTemp = 0 -- v5 in celcius
Voltage = 0 -- v6 in volts
c1 = 1 -- c1 = 0 when v1 is today's energy. c1 = 1 when v1 is lifetime energy.
-- Lua Functions
function UploadToPVoutput(self)
b, c, h = http.request("http" .. PVoutputURL .. PVoutputApi .. "&sid=".. PVoutputSystemID .. "&d=" .. os.date("%Y%m%d") .. "&t=" .. os.date("%H:%M") ..
"&v1=" .. EnergyGeneration .. "&v2=" .. PowerGeneration .. "&v3=" .. EnergyConsumption .. "&v4=" .. PowerConsumption .. "&v5=" .. CurrentTemp .. "&v6=" .. Voltage .. "&c1=" .. c1 )
if b=="OK 200: Added Status" then
print(" -- Current status successfully uploaded to PVoutput.")
print(" -- " ..b)
print(" -- Energy generation (v1) = ".. EnergyGeneration .. " Wh")
print(" -- Power generation (v2) = " .. PowerGeneration .. " W")
print(" -- Energy consumption (v3) = " .. EnergyConsumption .. " Wh")
print(" -- Power consumption (v4) = " .. PowerConsumption .. " W")
print(" -- Current temperature (v5) = " .. CurrentTemp .. " C")
print(" -- Voltage (v6) = " .. Voltage .. "V")
print(" -- Cumulative Flag (c1) = " .. c1 .. "")
-- CommandArray
time = os.date("*t")
if PVoutputPostInterval>1 then
TimeToGo = PVoutputPostInterval - (time.min % PVoutputPostInterval)
print('Time to go before upload to PVoutput: ' ..TimeToGo.. " minutes")
if((time.min % PVoutputPostInterval)==0)then
-- Generated
print(" ---- The total generated energy is " .. EnergyGeneration .. " Wh");
print(" ---- The current generated power is " .. PowerGeneration .. " W");
-- Voltage
Voltage = otherdevices_svalues[VoltageDeviceName] :match("([^;]+)")
print(" ---- The voltage of the inverter is " .. Voltage .. " V");
-- Temperature
CurrentTemp = otherdevices_svalues[TemperatureDeviceName]:match("([^;]+)")
print(" ---- The outside temperature is " .. CurrentTemp .. " C.");
-- Consumption
PowerConsumption, EnergyConsumption = otherdevices_svalues[ConsumptionDeviceName]:match("([^;]+);([^;]+)")
print(" ---- The total consumed energy is " .. EnergyConsumption .. " Wh");
print(" ---- The current consumed power is " .. PowerConsumption .. " W");
-- Upload data to PVoutput
UploadToPVoutput()
return commandArraybut i just cant seem to figure this one out with my skills
balans
Just to reply to myself , ifinally found it out it was a IDX of devices i renamed and forgot what it was the Volt uac1 was renamed by myself to Voltuac1SMA and Temparature SMA to TemparatureSMA.
Stupid to overlook but sometimes it is best to step away from it and step in fresh after a walk with the dog
balans
Ha i spoke to soon the upload thing is working but when i run the calculation script there still is this error
stack traceback:
[C]: in ?
-- Generated
it`s the line with -> PowerGeneration, EnergyGeneration..........
wich what i think is connected to
wich i think is correct so i`m open for suggestions
ps here my link to pv
http://pvoutput.org/intraday.jsp?id=51272&sid=46635
stack traceback:
[C]: in ?
-- Generated
Derik
- Domoticz version: BETA
mmm
Strange thing happend...
I use the simple script to upload my winddelen tot pvo:
Works good...
Only i will try to upload my gasmeter from domoticz [p1 ] with this script.
Strange but only this is not working.
Why is the P1 [ just the same counter in domoicz ] not upload the data?
print ("Winddelen naar P.V.O.")
date = os.date("*t")
if (date.min % 10 == 0) then
solar = otherdevices_svalues[' 3x Jonge Held']
now, total = solar:match("(%d+);(%d+)")
-- print(solar..' '..now..' '..total)
-- Upload data to PVoutput every 10 mins
baseURL = "http://pvoutput.org/service/r2/addstatus.jsp?"
SID = "15962"
API = "c53c834f1af40035b0ea535"
PVO_URL = baseURL .. "sid=" .. SID .. "&key=" .. API .. "&d=" .. os.date("%Y%m%d") .. "&t=" .. os.date("%H:%M")
PVO_URL = PVO_URL .. "&v1=" .. total .. "&v2=" .. now .. "&c1=1"
--print(PVO_URL)
commandArray['OpenURL'] = PVO_URL
Derik
Other thing...
I use the P1 usb....
Can i use the code: http://www.domoticz.com/wiki/Upload_ene ... m_Domoticz
Because there are two devices.
Import and export... devices Only when i use the usb i do have only 1 IDX.....
Derik
bump please....
I am searching for a simple script to upload my P1 meter in seperate data to Pvo [ PVO i have multile sids ]
So a day /night use script
a day / night deliver script
and the gas ...
Is there some that have this simple script working
and the gas ...
Derik
please??
There is something strange with the lua script with the P1 smart meter.
When i replace the script setting then i mis the Pvouput api...?
So i do not get this cript working..
Some one have a working P1 example for me....
Derik
nobody....
I am realy stuck with this script there are things that are not correct... [ i think ]+
Not to find in the code:
And more of this problems...
simple read the P1 wit generation and use in 1 sid
as a option the gas... other sid
Please...
Replace
-- Imported
PowerImport, EnergyImport = otherdevices_svalues[ImportedDeviceName]:match("([^;]+);([^;]+)")
-- Exported
PowerExport, EnergyExport = otherdevices_svalues[ExportedDeviceName]:match("([^;]+);([^;]+)")
endCode: Select all
-- Generated
-- Voltage
-- Temperature
-- Consumption
UploadToPVoutput()
return commandArraysimple read the P1 wit generation and use in 1 sid
Please...
videodrome
i edited the first script "script_device_calculate_consumption.lua" with notpad + and charged in the scripts/lua of Domoticz, but it gives me a message in the log
9: unexpected symbol near char(194)
what's wrong in my script?
- jvdz
- Domoticz version: 4.107
Did you change the encoding of the file with your editor?
Jos
Jos
videodrome
i saved the file as lua script. Now i tried to use Luaedit 2010 and make a debug. No more "unexpected symbol" message, but:jvdz wrote:Did you change the encoding of the file with your editor?
Jos
22: module 'socket.http' not found:
no field package.preload['socket.http']
no file '/usr/local/share/lua/5.2/socket/http.lua'
no file '/usr/local/share/lua/5.2/socket/http/init.lua'
no file '/usr/local/lib/lua/5.2/socket/http.lua'
no file '/usr/local/lib/lua/5.2/socket/http/init.lua'
no file './socket/http.lua'
no file '/usr/local/lib/lua/5.2/socket/http.so'
no file '/usr/local/lib/lua/5.2/loadall.so'
no file './socket/http.so'
no file '/usr/local/lib/lua/5.2/socket.so'
no file './socket.so' -
videodrome
anyone?videodrome wrote:i saved the file as lua script. Now i tried to use Luaedit 2010 and make a debug. No more "unexpected symbol" message, but:jvdz wrote:Did you change the encoding of the file with your editor?
Jos
I have installed Lua 5.1.5Code: Select all
22: module 'socket.http' not found: no field package.preload['socket.http'] no file '/usr/local/share/lua/5.2/socket/http.lua' no file '/usr/local/share/lua/5.2/socket/http/init.lua' no file '/usr/local/lib/lua/5.2/socket/http.lua' no file '/usr/local/lib/lua/5.2/socket/http/init.lua' no file './socket/http.lua' no file '/usr/local/lib/lua/5.2/socket/http.so' no file '/usr/local/lib/lua/5.2/loadall.so' no file './socket/http.so' no file '/usr/local/lib/lua/5.2/socket.so' no file '/usr/local/lib/lua/5.2/loadall.so' no file './socket.so'
- jvdz
You need to install these LUA libraries. They are also used by DTGBOT and can find them here: http://www.domoticz.com/forum/viewtopic.php?f=21&t=7279
Jos
Jos
videodrome
Installed the libraries. Now the problem is:jvdz wrote:You need to install these LUA libraries. They are also used by DTGBOT and can find them here: http://www.domoticz.com/forum/viewtopic.php?f=21&t=7279
Jos
568 Error: EventSystem: in /home/pi/domoticz/scripts/lua/script_device_calculate_consumption.lua: ...ticz/scripts/lua/script_device_calculate_consumption.lua:68: attempt to perform arithmetic on global 'PowerImport' (a nil value) The line 68 is
local GenerationDeviceName = "Produzione Fv istantanea" -- Device name of the Generated energy
local ImportedDeviceName = "Energia Prelevata" -- Name of the energy device that shows imported energy
local ExportedDeviceName = "Energia Immessa" -- Name of the energy device that shows exported energy
local ConsumptionIDX = 46 -- IDX of the energy device that shows calculated Consumption
local ConsumptionDeviceName = "Autoconsumo" -- Name of the energy device that shows calculated Consumption
-- Lua Functions
-- CommandArray
-- Generated
-- Imported
-- Exported
if devicechanged[ImportedDeviceName] then
Last edited by videodrome on Thursday 08 December 2016 22:59, edited 1 time in total.
- jvdz
Seems a nil is returned for ImportedDeviceName = "Energia Prelevata" by this line:
Is the devices name correct?
It could also help to set debug to yes so some information is shown while testing.
Jos
-- Imported
Jos
videodrome
As you see in the image the name sensor n. 40 is "Energia Prelevata" the same in the script. The sensor read the data in Kwh and the script is in watt....jvdz wrote:Seems a nil is returned for ImportedDeviceName = "Energia Prelevata" by this line:Is the devices name correct?Code: Select all
-- Imported PowerImport, EnergyImport = otherdevices_svalues[ImportedDeviceName]:match("([^;]+);([^;]+)")
Jos
How can i set the debug?
- jvdz
Ah yes, I see the device in the image. I also see that it has only one value and think that statement expect 2 values separated by a semicolon (;). Hope somebody can help that knows what should be expected here as I do not know the device.
Debugging is set by changing the value of the variable debug at the top to "YES":
Jos
Debug = "NO" -- Turn debugging on ("YES") or off ("NO")-
R0yk3
I hope somebody can help me.
I read the complete forum post, but i'm fairly a newbie.
i get this error
where i have in the script:
if i change the generation device to my pv, he values change to:
Where am i misreading the lott..??
i get this error
2017-05-06 00:42:18.998 LUA: ----- PowerGeneration = 0 W
2017-05-06 00:42:18.998 LUA: ----- EnergyGeneration = 0.0 Wh
2017-05-06 00:42:18.998 Error: EventSystem: in /home/pi/domoticz/scripts/lua/script_device_calculate_consumption.lua: ...ticz/scripts/lua/script_device_calculate_consumption.lua:58: attempt to perform arithmetic on global 'EnergyImportLow' (a nil value)Code: Select all
local GenerationDeviceName = "Elektra" -- My P1 output
local EnergyDeviceName = "Elektra" -- My p1 output
local ConsumptionIDX = "198" -- IDX of the dummy switch
local ConsumptionDeviceName = "Elektra_verbruik" -- Name of the dummy switch
2017-05-06 00:40:24.136 LUA: ----- PowerGeneration = 0.000 W
2017-05-06 00:40:24.136 LUA: ----- EnergyGeneration = 0.000 WhRaspberry PI 3, raspbian, ZwaveMe, RFLink
