Execute a script only once an hour
Noudje
Post by Noudje »
I am new to Domoticz. And I want not only to monitor the energy consumption/production of my house, but also want to monitor the free space on the discs from my NAS. I mounted the discs from my NAS, created a LUA script (script_device_FreeSpace.lua) to calculated the free space for each disc, and created Dummy devices. It works great!
But what I see in the Log, is that this script is executed each second, or more frequently(?):
2016-01-25 23:31:02.028 EventSystem: Script event triggered: /home/pi/domoticz/scripts/lua/script_device_FreeSpace.lua
2016-01-25 23:31:02.077 EventSystem: Script event triggered: /home/pi/domoticz/scripts/lua/script_device_FreeSpace.lua
2016-01-25 23:31:02.125 EventSystem: Script event triggered: /home/pi/domoticz/scripts/lua/script_device_FreeSpace.lua
Is there a way that this script is only executed e.g. every hour/day?
malarcy
Re: Execute a script only once an hour
Post by malarcy »
The scheduling is fixed in domoticz.
ALL "device" scripts (scripts with "device" in their name) run everytime ANY device status changes
ALL "time" scripts (scripts with "time" in their name) run every MINUTE.
It looks like you have a device changing value regularly - that is triggering your script.
I don't use the LUA scripting myself - so I can't suggest a "better" way of doing what you need - but this might at least help you understand whats happening - perhaps others can pitch in with some advice
Hope this helps a bit
nayr
Domoticz version: github
Post by nayr »
yep rename your script to: script_time_FreeSpace.lua and do something like this:
function timedifference (s)
	year = string.sub(s, 1, 4)
	month = string.sub(s, 6, 7)
	day = string.sub(s, 9, 10)
	hour = string.sub(s, 12, 13)
	t1 = os.time()
	difference = os.difftime (t1, t2)
	return difference
if (timedifference(otherdevices_lastupdate['Free Space']) > 3600) then
        -- calculate and update free space here.
simonrg
Domoticz version: 3.8807
Post by simonrg »
If you have a read through the wiki then you will see lots of examples of using time scripts, which is what you want to use, as others have said.
Something simple like this would work, you don't need to track the time differnce time scripts are only called once a minute:
--~/domoticz/scripts/lua/script_time_check.lua
time = os.date("*t")
-- Only operates when minutes is 0 i.e. on the hour
-- Time scripts are only called every minute, so this script will only operate once an hour
if time.min == 0 then
-- Do what you want to do inside here
Raspberry Pi 2 B - 2A@5V PSU - Raspbian + Domoticz + RFXtrx(89), LightwaveRF House(dimmers, sockets, wireless/mood switches), Owl CM113, 4 LaCross Temp / Humidity Sensors, 4 Siemens PIR, Smappee, Solaredge, ESP8266
jannl
Domoticz version: 2026.1.x
Post by jannl »
Or create a shell script, update Domoricz via json and fire the script via crontab
Noudje
Post by Noudje »
Thnx for all the replies!!!
I will rename my LUA file and test it.
Raspberry Pi 2 with latest beta version
1x Aeon Labs USB Z-Stick S2
5x Fibaro Modules
javed222pi
Domoticz version: 3.4834
Post by javed222pi »
Thanks simnrg!
how i must to do, if i need wait 20seconds?
Thanks!!
simonrg wrote:If you have a read through the wiki then you will see lots of examples of using time scripts, which is what you want to use, as others have said.
Egregius
Domoticz version: v2024.7
Post by Egregius »
Use cron as a sheduler, much more options than lua.
#!/bin/bash
while :
do
	SECOND=$(date +%S)
	if [ $SECOND -eq 20 ]
	then
		#Do your stuff
	fi
sleep 0.9
This will do your stuff at exactly the 20th second.
javed222pi
Thanks man, but Im new in lua...
I post in script board my problem with all the code that i must modify.
dannybloe
Post by dannybloe »
Just create a dzVents timer script and set it to run once every hour:
    active = true,
       ['timer'] = 'every hour'
    execute = function(domoticz)
        -- do your stuff here
BakSeeDaa
Post by BakSeeDaa »
It can be done in a lot of ways. Below is how I did it on my system:
script_time_misc.lua
-- script_time_misc.lua
local function bathroomHum()
	-- Do something here
local function warnComputerTimeExceeded()
local m = os.date('%M')
if (m % 5 == 0) then
	--print('The 5 minute script interval reached')
	-- Call your function here that shall run every 5 minutes
	bathroomHum()
if (m % 10 == 0) then
	-- print('The 10 minute script interval reached')
	-- Call your function here that shall run every 10 minutes
if (m % 30 == 0) then
	-- print('The 30 minute script interval reached')
	-- Call your function here that shall run every 30 minutes
if (m % 60 == 0) then
	-- print('The 60 minute script interval reached')
	-- Put your script code here that shall run every 60 minutes
bertbigb
Post by bertbigb »
I have a question about these kind of scripts and I hope someone can help me
This situation is true for 1 complete minute what can mean it runs your function several times
How to run a script just 1 time every 10 seconds for instance?
I hope someone can answer that question and many thanks in advance.
Best regards Bert
Synology DS1517+ - DSM 6.2
Nautilus
Post by Nautilus »
bertbigb wrote:Hi,
In Domoticz the time scripts run once every minute and these type of conditions are used with them to specify a longer interval between the runs. So there is no danger of them being run for more than once during each minute.
There might have been some discussion here on the forum on how to have a shorter than one minute interval, you can check if the search brings up anything. But in general you'd have to write e.g. a bash script that you can trigger with a Domoticz time script (or with crontab if on Linux platform) once every minute. In the bash script you'd then have a for loop which would run for six times with a 10 second sleep at the end of each round...
Egregius
Post by Egregius »
You can trigger scripts easy by updating a (dummy) device, like a solar sensor.
At least that's how I trigger my script to run every minute, exactly at the minute:
#!/bin/bash
while :
do
	SECOND=$(date +%S)
	if [ $SECOND -eq 0 ]
	then
		DOMOTICZ=`curl -s --connect-timeout 2 --max-time 5 "http://127.0.0.1:8084/json.htm?type=command&param=udevice&idx=6&nvalue=0&svalue=0"`
#Other stuff removed here...
	fi
	sleep 0.8
done
To run every then seconds that could be something like:
#!/bin/bash
for i in {1..6}:
do
        sleep 9.95
done
But, why every 10 seconds? This will cause all your device scripts to be executed every 10 seconds.
bertbigb
Post by bertbigb »
Hi first of all thanks for the answers. I will try the bash script.
Furthermore
I have the following code:
    iswhite = "false"
    hue = "48" --warmish yellow
    idx = otherdevices_idx["Hue color plafond lamp WK"] -- name lamp
    brightness = uservariables['brightness']
    state = uservariables['state']
    if otherdevices['WakeUp2LivingRoom'] == 'On' then    --device that triggers the action now for testing
        if uservariables['state'] == 0 then
            state = state + 1
            commandArray['Variable:state'] = tostring(state)
            commandArray['Variable:brightness'] = tostring(100)   				    -- see that lamp in On
        elseif uservariables['state'] == 1 then
            if (time.sec % 10 == 0) then							                --ticks every 10 seconds
    			brightness = brightness - 1							                --lower the brightness
    			commandArray['Variable:brightness']= tostring(brightness)
    			if brightness <= 0 then
                    state = state + 1
                    commandArray['Variable:state'] = tostring(state)				--if brightness = 0 then raise the state
        elseif uservariables['state'] ==2 then
            commandArray['Hue color plafond lamp WK'] = 'Off'
            commandArray['Variable:state'] = tostring(0)
            commandArray['WakeUp2LivingRoom'] = 'Off'
		url = 'http://127.0.0.1:8084/json.htm?type=command&param=setcolbrightnessvalue&idx=' .. idx .. '&hue=' .. hue .. '&brightness=' .. brightness ..'&iswhite=' .. iswhite
        commandArray['OpenURL']= url
        print('url send   ' .. url..' state = ' .. state.. ' brightness = '..brightness .. ' difference = '..difference)
With this code I want a lamp to dim fluent. I want to make a wakeup and go to bed light.
And yes, it will trigger the device script every 10 second, but with all the sensors I have (temperature, PIR, door ans window sensors) these scripts get fired almost every second anyhow at the moment. And I don't know how to prevent this since I need very often the devicechanged command in my scripts.
So if you have suggestions I'm really open to that.
Thanks everyone for your good help
Best regards Bert
Egregius
Post by Egregius »
My suggestion: Pass2php :P
bertbigb
Post by bertbigb »
I have had a look at it on your webside and found a whole lot of code. Can you help me a little bit where to find more explanation and what to do to port it to my own environment?
I like Domoticz very much but this timing problem and everytime evaluating of the software when only one sensors changes makes me want to have a closer look at this php thing.
Best regards Bert
Egregius
Post by Egregius »
