In the last few weeks i've installed configured and used Domoticz to control and acquire data from sensor in my home and all works very well.
I have a motorized sunshade succesfully paired with RfxCom using RFXmngr unfortunatly in domoticz seems not to exist the possibility to define parameter for this remote.
it use SEAV TXS4 and afther pairing in RFXmngr is programmed for send T1 and T2 (UP and DOWN)
following the dump
Fan command
Packettype = Fan
subtype = SEAV TXS4
Sequence nbr = 35
Switches = J1=open, SW1=Off, SW2=Off
ID = 10A SW1 1=Off, 2=Off, 3=Off, 4=Off, 5=Off, 6=Off, 7=On, 8=Off, 9=Off, 10=Off
Command = T1
Signal level = 0 -120dBm
Packettype = Receiver/Transmitter Message
subtype = Transmitter Response
Sequence nbr = 35
response = ACK, data correct transmitted
thanks
Marco
