Remote shutdown Retropie via Domoticz
nosehook
Post by nosehook »
Since I got my RetroPie setup with a HS100 plug from TP-Link I want to do the following with a dummy switch:
On: switch the HS100 on (and RetroPie will boot automatically).
Off: remote shutdown RetroPie and when it is off, switch off the HS100.
The problem is the remote shutdown.
I know how to log in with Putty and send the shutdown command, however, I do not know how to write a script to have my Domoticz Raspberry pi ogin and shut it down and what additional packages might be needed for that.
Can some-one please tell me how this should be done?
Thanks,
Freek
Pi3 Domoticz | RFXcom 433E | KAKU/COCO |Harmony Hub | Samsung TV | HS100 | HS110| HUE | Tradfri | Tado| Xiaomi |sensors | scripts| Pi3 Node Red | Pi2 SDS_011 + MH-Z19B | PiAware (zero) | Pi2 breadboard with Node red and Domoticz
emme
Domoticz version: latest
Re: Remote shutdown Retropie via Domoticz
Post by emme »
you can try a remote ssh session with no password and issue the shutdown command
have a look to this site about how to connect via ssh and with no password
http://www.linuxproblem.org/art_9.html
"We always done this way"
Egregius
Domoticz version: v2024.7
Post by Egregius »
Isn't there a auto shutdown option in retropie?
Otherwise I have a script that detects when a network device is offline and switches it's power off. I use it for a Libreelec-Pi.
nosehook
Post by nosehook »
Egregius wrote:Isn't there a auto shutdown option in retropie?
If there is an auto shutdown I can not find it...
Could you share your script please?
Egregius
Post by Egregius »
Sure, part of my pass2php script:
if($s['kodi']=='On'&&strtotime($t['kodi'])<time-298)
            $devcheck='Kodi';
            if(pingDomain('192.168.2.7',1597)==1)
                $prevcheck=cget('check'.$devcheck);
                if($prevcheck>0)
                    cset('check'.$devcheck,0);
                $check=cget('check'.$devcheck)+1;
                if($check>0)
                    cset('check'.$devcheck,$check);
                if($check>=5)
                    sw($i['kodi'],'Off','kodi');
 function pingDomain($domain,$port)
    $file=fsockopen($domain,$port,$errno,$errstr,10);
    $status=0;
    if(!$file)
        $status=-1;
        fclose($file);
        $status=1;
    return $status;
If my Kodi isn't listening anymore, for 5 runs I shutdown it's power.
The 5 runs is in there to enable updates of Libreelec, otherwise power is killed during update... Can't be good.
