zwave controlling a nexa device
Flopp
Post by Flopp »
I have tried to find a way to turn on a Nexa device, or other Tellstick device, when I double click or triple click on a Zwave device but I can't find a way.
Is this possible?
Or maybe it is possible to create a virtual Zwave device then I could sync this virtual device with a Nexa device.
Flopp
Re: zwave controlling a nexa device
Post by Flopp »
Anyone know a workaround or a way to actually do it?
bjacobse
Post by bjacobse »
hi,
Using Blockly it might be possible to create a globale variable that get incremented when you click on your zwave device, and when variable = 3 then var=0 and then switch on NEXA switch
https://www.domoticz.com/wiki/User_variables
Flopp
Post by Flopp »
bjacobse wrote:hi,
Thanks for reply.
I have not tested it yet, but do you know if you get any signal from zwave when you double/triple click?
I need to get any signal from zwave that someone double clicked on the device.
If that is possible then I can create a virtual device which will be controlled by the signal from zwave.
bjacobse
Post by bjacobse »
Flopp wrote:
bjacobse wrote:hi,
Thanks for reply.
which device? is you zwave device? You can use a example qubino relay or other zwave switch, when you double click, you actually toggle from off to on to off, so every time you receives off from zwave then toogle telldus/Nexa device
Flopp
Post by Flopp »
I tried with double click but there is no signal telling that you have double clicked.
I have Fibaro and want to turn ON/OFF other device which is not Zwave.
If had been able to create a virtual Zwave device, I could listen to that virtual device to control my Nexa(433mhz)
