Error when trying a update
gennapium
Domoticz version: Stable
Post by gennapium »
Hi I am trying to update Domoticza on my Ubuntu 14 server. I get this error:
-- Using builtin Mosquitto library
-- Compiling Revision #6013
-- Boost version: 1.54.0
-- Found the following Boost libraries:
-- thread
-- date_time
-- system
-- Linking against boost static libraries
CMake Error at CMakeLists.txt:458 (message):
Found libBoost version 105400, 105500 or newer required
-- Configuring incomplete, errors occurred!
See also "/home/domoticz/domoticz/CMakeFiles/CMakeOutput.log".
See also "/home/domoticz/domoticz/CMakeFiles/CMakeError.log".
make: *** [cmake_check_build_system] Error
How van i update libBoost ?
Ubuntu server, Raspberry Pi, PiFace 2, RFXCom, Z-wave Stick, Kaku, Sensor
gennapium
Re: Error when trying a update
Post by gennapium »
Solved !!
Found it in the Wiki of Domoticz. Update to latest beat worked.
juankar
Domoticz version: 4.
Post by juankar »
Could you write detailed info abut the fix? For instance the link to wiki where explain this fix.
kubrik
Post by kubrik »
juankar wrote:Could you write detailed info abut the fix? For instance the link to wiki where explain this fix.
https://www.domoticz.com/wiki/Installin ... _Libraries
Ubuntu 20.04 on ACEPC AK1 (previously RPi3b+)
Z-Stick Gen5, RFXtrx433E, Philips HUE Bridge, Yeelight, ESP8266 NodeMCU, Broadlink RM
dZvents, bash, php, Node-RED
