Dear all,
Starting with domoticz i am looking a way to control my VM201 card.
Its connected on my network via its own lan connection and has its own Http web acces..
It can also controlled via protocol.. https://www.velleman.eu/downloads/0/inf ... _vm201.pdf
But my knolledge is limited and i'am stuck...
I am thinking creating virtual switched and making scripts to combine the protocol or should does this makes it to difficult....
Please help...
Benno
Velleman VM201Ethernet Relay Card
Re: Velleman VM201Ethernet Relay Card
Make under hardware a dummy, make under the dummy virtuele sensors with sensor type "switch" (on/off)
Bij switches you see your new made switches.
Now you can use the on and off action with a http rule.
http://user:pasword@ipadres/cgi/leds.cgi?led=0 (Relai 1 and led 1 are going on) with the same rule you send the off action.
Relai 1 to 8 = 0 to 7 in this line.
From your explorer you can use this line also but now without user and pasword.
Example
From explorer : http://192.168.1.222/cgi/leds.cgi?led=3 (put relai 4 and led 4 on if there are off, toggle)
From explorer : http://192.168.1.222/cgi/leds.cgi?led=3 (put relai 4 and led 4 off if there are on, toggle)
From Domoticz : http://gebruiker:[email protected]/c ... .cgi?led=3 (put relai 4 and led 4 off if there are on, toggle)
From Domoticz : http://gebruiker:[email protected]/c ... .cgi?led=3 (put relai 4 and led 4 on if there are off, toggle)
Succes
Example
Succes
plantjes
- Domoticz version: 3.5877
Well that works OK...
Is er nog een manier om de status beter terug te krijgen??
Nu kan het gebeuren dat de relay kaart aan staat en domoticz lamp staat uit.
Is there any way to get the status reply in domoticz as well...
On my browser i get back succes =1 or succes 0...
Now its posible i get a light on in domoticz and the relay still off when it misses 1 switch......
