hi guys and domoticz team
i want know when come in next version of domoticz? and in this version will add my sensors "ir send/receive" ?
This is an important module for control air conditioning and television , audio. . .
when come in next version of domoticz ?
- emme
- Domoticz version: latest
Re: when come in next version of domoticz ?
there are several way to contro the same...
I use 2 IR tranceivers to do the same by using nodeJS
of course they are external script links with the specific command, and I do not have the status back, but I can command TV, DVR, Air Conditioner ad averything in range
ciao
M
ciao
M
"We always done this way"
pvm
- Domoticz version: 4.10538
Reza, are you able to make these changes in Domoticz yourself? In that case I expect in can be in the next beta soon
reza
- Domoticz version: 2024.4
hi thank you for answer me.emme wrote:there are several way to contro the same...
ciao
M
in mysensors there is a sketch for learn ir codes and send ... i am use a mysensors gateway and mysensors device. is this your device a mysensors device ? can you help me for control TV and Air Conditioner with domoticz? i need this
reza
i can not change but i can compile the source , if there is a source for support ir sender/receiver my sensorspvm wrote:Reza, are you able to make these changes in Domoticz yourself? In that case I expect in can be in the next beta soon
