Domoticz RPC for NIBE Uplink
- Domoticz version: 5877
Re: Domoticz RPC for NIBE Uplink
Yeah, I can see the values are the same now. Thing is Nibe don't display when the numbers were updated as Domoticz do. Nibe also had some maintenance when I wrote the first post, it is fine now though.
Another question; Does any of you guys know what benefit a premium account could bring from a Domoticz perspective?
Once again, awesome work!
Thank You "A" for supporting this project by your generous donation.
New issue;
Since my 1255 uses Smart Price Adaption I get the current cost for electricity, I thought it could be interesting to also have that data in Domoticz. I ran:
to add the feature. When I did it I get the following response:
python /home/pi/domoticz/scripts/NibeUplink/nibeuplink.pyc --redefine -v
When I check config.json it looks like this:Found a new Nibe Uplink resource: 'Nibe F1255 Price Of Electricity Se3'
Shall I enable it and create a Domoticz Virtual Device for it? : Y/N [N]:y
Unknown Domoticz type: 'öre/kWh'
Updated the config file at /home/pi/domoticz/scripts/NibeUplink/config.json
Any ideas?{
"domoticzIdx":0,
"domoticzSensorType":0,
"enabled":false,
"nibeCategoryName":"smart price adaption",
"nibeDesignation":"SE3",
"nibeParameterId":10069,
"nibeSystemId":21490,
"nibeTitle":"price of electricity",
"valueFactor":0.001
I've added support for "Smart Price Adaption" in version 1.0.3. Please download the latest version and redefine that device again. I haven't been able to test it here but I believe it will work and after some time you should have a nice graph covering the Nordpool Spot energy price. Please let me know if it works. Thanks!Leonard wrote:New issue;
Works fantastic as always.
Great work!
Great work!
I'm glad to hear that!Leonard wrote:Works fantastic as always.
Great work!
Hi!
First off, awesome idea to make this!
Got a small problem thou, the search paths seem to be "hard coded" in the script and to the user pi. (ie. /home/pi/domoticz/scripts/...) Since I am using an install on an ubuntu dist I have a username other than pi (/home/_myusername_/domoticz/scripts...). Is there anyway I can install this? Got a error message when I run the file. Can you update the script with removed paths? If it's ran in the same directory the search paths in the python file may not be necessary, right?
Thanks again for a great contribution!
Ludde
Ludde
BR / Ludde
BR / Ludde
Ludde, Let me have a look at that.Ludde wrote:Hi!
Ludde
There should be no "hard coded" paths or usernames in the script. Can you quote the exact command that you are issuing together with the error message that you receive? Thanks!Ludde wrote:Hi!
Ludde
/domoticz/scripts/NibeUplink$ python /home/ludvig/domoticz/scripts/NibeUplink/nibeuplink2.pyc
File "/home/pi/domoticz/scripts/NibeUplink/nibeuplink.py", line 13, in <module>
ImportError: No module named requests
When looking inside the file with a text editor I can see a reference to: home/pi/domoticz/scripts/NibeUplink/nibeuplink.pyt
Thank you for your help! Really want to have my VP in Domoticz.
BR / Ludde
BR / Ludde
Did you install the requests module as described in initial post?Ludde wrote: ImportError: No module named requests
Yepp, I believe so, installed python-pip and the update.
BR / Ludde
BR / Ludde
What is the result if you runLudde wrote:Yepp, I believe so, installed python-pip and the update.
pip install requests
That solved it nicely!! Now it's working fine!
This is the output:
Collecting requests
Downloading requests-2.12.3-py2.py3-none-any.whl (575kB)
100% |████████████████████████████████| 583kB 789kB/s
Installing collected packages: requests
Successfully installed requests-2.12.3
You are using pip version 8.1.1, however version 9.0.1 is available.
You should consider upgrading via the 'pip install --upgrade pip' command.
Did not have to do the actual update, worked anyway.
Thanks!!!
This is the output:
Collecting requests
Thanks!!!
BR / Ludde
BR / Ludde
Hi, thanks for a nice script - for me it worked one time - direct after installation - but it did not continue to supply data to my domoticz.
I'm running a Qnap 4.3.1 with python 2.7.12 running Domoticz V3.5985
Running the script: python /domoticz/scripts/NibeUplink/nibeuplink.pyc -v generates this:
The thing that i can see is the "/home/pi/domoticz/scripts/NibeUplink/nibeuplink.py" doesnt exist.
I have the files at: /share/CACHEDEV1_DATA/.qpkg/domoticz/scripts/NibeUplink/nibeuplink.pyc
Any thoughts?
Any thoughts?
Domoticz RPC for NIBE Uplink Version 1.0.3 running on TTY console...
Number of systems: 1
Product Name: NIBE F1255
Serial number: 06540016046003
System ID: 25798
Has alarmed: False
File "/home/pi/domoticz/scripts/NibeUplink/nibeuplink.py", line 785, in <module>
File "/home/pi/domoticz/scripts/NibeUplink/nibeuplink.py", line 781, in main
File "/home/pi/domoticz/scripts/NibeUplink/nibeuplink.py", line 710, in list_systems
File "/home/pi/domoticz/scripts/NibeUplink/nibeuplink.py", line 469, in updateDomoDevice
KeyError: 'result'
Hi there! I'm not sure what's going on in this case but I will try to add some better debugging info. It looks like the script was unable to list a specific domoticz device. If You have the time, you can check the file config.json and check the field "domoticzIdx". It should contain valid domoticz id:s. Did You by any chance manually delete some devices in Domoticz after setting up Domoticz RPC for NIBE Uplink? I will have a better look at the code very soon.MrBastard wrote:Hi, thanks for a nice script - for me it worked one time - direct after installation - but it did not continue to supply data to my domoticz.
Any thoughts?
Domoticz RPC for NIBE Uplink Version 1.0.3 running on TTY console... Number of systems: 1 Product Name: NIBE F1255 Serial number: 06540016046003 System ID: 25798 Has alarmed: False Traceback (most recent call last): File "/home/pi/domoticz/scripts/NibeUplink/nibeuplink.py", line 785, in <module> File "/home/pi/domoticz/scripts/NibeUplink/nibeuplink.py", line 781, in main File "/home/pi/domoticz/scripts/NibeUplink/nibeuplink.py", line 710, in list_systems File "/home/pi/domoticz/scripts/NibeUplink/nibeuplink.py", line 469, in updateDomoDevice KeyError: 'result' [~] #
Thank you for your quick return - However - last night i did remove the config.json file and redid a new one and got everything up and running.BakSeeDaa wrote: Hi there! I'm not sure what's going on in this case but I will try to add some better debugging info. It looks like the script was unable to list a specific domoticz device. If You have the time, you can check the file config.json and check the field "domoticzIdx". It should contain valid domoticz id:s. Did You by any chance manually delete some devices in Domoticz after setting up Domoticz RPC for NIBE Uplink? I will have a better look at the code very soon.
I dont recall, but it might be as you said - i only removed them in domoticz and not using the script and therefore generating this problem.
And as we say here, GOD JUL!
Hi! I'm happy to hear that everything works fine now. Wishing You a merry Christmas!MrBastard wrote:Thank you for your quick return - However - last night i did remove the config.json file and redid a new one and got everything up and running.
Version 1.0.4 (The Christmas version) Released 2016-12-24
- Added additional error checking to be sure that Domoticz has responded with accurate device data upon request.
This solution looks great! How can I get access to it?
