Update status without triggering
Melissen
Post by Melissen »
I want to update some status of devices without triggering them.
I can get it to work, but only 1 switch at a time.
this is a part of the script:
-- Woonkamer alles
if (devicechanged['Woonkamer -alles']=='On') then
commandArray['UpdateDevice']='64|1|1'
commandArray['UpdateDevice']='65|1|1'
-- commandArray['UpdateDevice']='66|1|1'
-- commandArray['UpdateDevice']='70|1|1'
-- commandArray['UpdateDevice']='72|1|1'
if (devicechanged['Woonkamer -alles']=='Off') then
commandArray['UpdateDevice']='64|0|0'
-- commandArray['UpdateDevice']='65|0|0'
-- commandArray['UpdateDevice']='66|0|0'
-- commandArray['UpdateDevice']='70|0|0'
-- commandArray['UpdateDevice']='72|0|0'
In this case when switching ON, only nr65 is switched to ON, nr 64 stays OFF (66,70,72 are turned off, --)
When I switch OFF, nr 64 is switched OFF. (because 65,66,70,72 are turned off, --)
When I remove all -- in the commandlines, in both On or OFF only nr 72 switches.
So my conclusion is: only the last commandline is working.
How to get all commandlines working???
Thanks,
Hein
RFXcom433e ver1009,Raspberry Pi,Domoticz v3.5877
KaKu:16c remote,dimmer,wall-sockets,sunscreenswitch
Promax:wall sockets Elro:wall sockets Somfy:RFY screens
TFA:weather station Chinese temperature sensors, smoke detectors, power switches
SweetPants
Re: Update status without triggering
Post by SweetPants »
Melissen wrote:So my conclusion is: only the last commandline is working.
That is right.
Did you check the wiki? https://www.domoticz.com/wiki/LUA_comma ... n_one_pass
Melissen
Post by Melissen »
I saw this wiki-page.. but when i try to use this in the IF-THEN it doesn't work..
Even when I remove the commandArray = {} and return commandArray in the THEN-section, it doesn't work
Script I used:
-- Woonkamer alles
local function update(idx, value1, value2)
local cmd = string.format("%d|0|%.2f;%.2f", idx, value1, value2)
table.insert (commandArray, { ['UpdateDevice'] = cmd } )
update (64, 1, 1)
update (65, 1, 1)
update (66, 1, 1)
update (70, 1, 1)
update (72, 1, 1)
LUA is great, but the tutorials on Google aren't that great... Not a simple explanation, but only explaining a specific problem. So when you want to use a command in a different way, you get stuck very fast,
Westcott
Post by Westcott »
Hi Melissen,
Are you saying that if you update a device in this way (e.g. commandArray['UpdateDevice']='64|1|1') it doesn't trigger a devicechanged['MyDeviceIdx64'] ?
SweetPants
You can't have two "commandArray = {} and return commandArray" instructions.
This script works in my setup
if (devicechanged['Lamp 3']=='On') then
	update (110, 11, 0)
	update (111, 22, 0)
	update (112, 33, 0)
Melissen
Post by Melissen »
Hi Westcott. Indeed. When you use that command the switch will turn ON in your dashboard. But the device itself (lamp example) will not turn on.
Westcott
Post by Westcott »
Wow, thanks Melissen.
So an nValue of 1 (value1 in SweetPants' example) means 'On' ?
Melissen
Post by Melissen »
Yeah... it works... After changing the string format to %d %d %d.....
Script is now:
local cmd = string.format("%d|%d|%d", idx, value1, value2)
-- Woonkamer -alles
update(64,1,1)
update(65,1,1)
update(66,1,1)
update(70,1,1)
update(72,1,1)
update(64,0,0)
update(65,0,0)
update(66,0,0)
update(70,0,0)
update(72,0,0)
Thanks everybody for helping me.... very happy with you !!!!
Hein.
Melissen
Post by Melissen »
Hi Westcott.... yes for a switch you should use (idx,1,1)
See my script...
Melissen
Post by Melissen »
Problem solved again...... and for all other switches is this a very easy script...
