Then pushbutton has a auto off, so when I push it, it turns on.
But it dont seem to work, can you see what is wrong?
function remoteslapen(){global $a,$s,$i;
if($a=="On"){
$kamer=filter_var($s['kamer'],FILTER_SANITIZE_NUMBER_INT);
if($s['slapen']=='Off'&&$kamer!=16)sl($i['kamer'],17);
elseif($s['slapen']=='Off'&&$kamer==16){sl($i['kamer'],13);minihall1s();}
elseif($s['slapen']=='On'&&$kamer==12){sl($i['kamer'],11);cset('dimmerkamer',1);}
}else minihall3s();}
Egregius wrote:This s possible with a script.
I use a remote in the bedroom:
First press = dimmer to 17%
Second press = dimmer to 13 % and set home to sleep mode
Third press = dimmer to 10% and slowly dim to off, each minute a percent darker.
function remoteslapen(){global $a,$s,$i; if($a=="On"){ $kamer=filter_var($s['kamer'],FILTER_SANITIZE_NUMBER_INT); if($s['slapen']=='Off'&&$kamer!=16)sl($i['kamer'],17); elseif($s['slapen']=='Off'&&$kamer==16){sl($i['kamer'],13);minihall1s();} elseif($s['slapen']=='On'&&$kamer==12){sl($i['kamer'],11);cset('dimmerkamer',1);} }else minihall3s();}
If A == On and B == Off and 'var C' == 0
Do Set B = level (%) 90
Set 'var C' = 90
Elseif A == On and B != Off and 'var C' == 90
Do Set B = level (%) 10
Set 'var C' = 10
Elseif A == On and B != Off and 'var C' == 10
Do Set B = Off
Set 'var C' = 0
Search for lua pass2phpDerik wrote:
mmm New feature for me...
Please a short how to?
Lua?
Or?
How to activate?
THANKS!!
Button = ‘Test 4 Tryk_Knap_1’;
Dimmer = ‘TV_Stue_RGBW_Højre Højtaler’;
if devicechanged[Button] then
if(devicechanged[Button]==‘On’) and (devicechanged[Dimmer]==‘0’) then
commandArray[‘Dimmer’]=’90’;
if(devicechanged[Button]==‘On’) and (devicechanged[Dimmer]==‘90’) then
commandArray[‘Dimmer’]=’10’;
if(devicechanged[Button]==‘On’) and (devicechanged[Dimmer]==‘10’) then
commandArray[‘Dimmer’]=’0’;
