Kerui D026
Kerui D026
Hello!
I am new to domoticz with an raspberry pi 3 and a RFXTRX433E
On aliexpress i bought some KERUI D026 door sensors
http://www.aliexpress.com/item/32590916 ... 16896.html
But they are not recognized by RFXTRX433E and Domoticz. Is there ant way to make them work?
- Target OS: -
Re: Kerui D026
Check with RFXmngr on a Windows system and Lighting4 enabled
RFXtrx433, RFXtrx433E, RFXtrx433XL, RFX433XL, RFX868XL
Re: Kerui D026
Thank you for your reply! I checked today with RFXmngr with Lighting 4 enabled.
CLOSE
Packettype = Lighting4
subtype = PT2262
Sequence nbr = 154
Code = 424087 decimal:4341895
S1- S24 = 0100 0010 0100 0000 1000 0111
Pulse = 317 usec
Signal level = 8 -56dBm
OPEN
subtype = PT2262
Sequence nbr = 155
Code = 42408E decimal:4341902
S1- S24 = 0100 0010 0100 0000 1000 1110
Pulse = 317 usec
CLOSE
subtype = PT2262
Sequence nbr = 154
Pulse = 317 usec
OPEN
subtype = PT2262
Sequence nbr = 155
Pulse = 317 usec
Re: Kerui D026
PANIC
subtype = PT2262
Sequence nbr = 234
Code = 42408B decimal:4341899
S1- S24 = 0100 0010 0100 0000 1000 1011
Pulse = 315 usec
subtype = PT2262
Sequence nbr = 234
Pulse = 315 usec
Re: Kerui D026
Is there a way to add thus sensor ?
Re: Kerui D026
I have also some Kerui D026 sensors and they working with Domoticz. I'm running SW version 1009, you can download it from the RFXcom website, you can only reload the firmware/SW version via the windows program (not via Domoticz). You have to selected lighting4 (modus instellen)...
- Domoticz version: latest
Re: Kerui D026
Dear friend,robertje221 wrote:Is there a way to add thus sensor ?
I bought a Kerui D026 sensor and I made it work with my RFLINK gateway as easy as 1-2-3. The only problem is that the ON means closed and OFF means opened, and I want to swap it but cannot find the solution.. But the sensor is working flawless!
Re: Kerui D026
Thanks for your reply. I know that these sensors are supported with the RFlink. But I have a RFXTRX433E / RFXCOM and i wonder if it is possible to make them work with that unit.
- Domoticz version: BETA
Re: Kerui D026
Make a DummyTacticalLeader wrote:Dear friend,robertje221 wrote:Is there a way to add thus sensor ?
Make Blockley
When open cloe the the dummy
When close open the dummy..
Re: Kerui D026
I will have 17 dummys for reversing and 17*2 switches for nothing. It's not too elegant.Derik wrote:Make a DummyTacticalLeader wrote:Dear friend,robertje221 wrote:Is there a way to add thus sensor ?
Make Blockley
Re: Kerui D026
ok ....
Only it is a solution... [ did not now you have 17 contact.. ]
And Domoticz can run with the dummy no problem..
Think i do have 100+ dummy timer active etc etc ..
Re: Kerui D026
By the way, the solution is working and do the reversing. Maybe, if there will be a solution to hide selected switches or other devices Now the switches menu is crowded, like a christmas market.Derik wrote:ok ....
- Target OS: -
Re: Kerui D026
On request a beta version Ext2 (for the RFXtrx433E) is available. This firmware reports Kerui sensors as one security sensor.
Re: Kerui D026
Should this work with RFXcom433E (ver1011)? And does this one have ON and OFF switch? So I can see of the door is closed or opened?
It's not really Kerui, but does have the same D026 code.... Chinese sellers aren't always sincere in their ads.
https://www.aliexpress.com/item/High-gr ... 2167&tpp=1
Or should I go for a real Kerui D026?
UPDATE 23/12: Device works great... Gonna buy some more:)
RFXcom433e ver1009,Raspberry Pi,Domoticz v3.5877
KaKu:16c remote,dimmer,wall-sockets,sunscreenswitch
Promax:wall sockets Elro:wall sockets Somfy:RFY screens
TFA:weather station Chinese temperature sensors, smoke detectors, power switches
Re: Kerui D026
Updated the firmware of my RFXcom433E to ver1012.
The Kerui D026 is now a proper security sensor with three states (normal, alarm and alarm+tamper).
Unfortunately only 3 of 5 identical Kerui D026 sensors are successfully added to Domoticz.
The other two won't even show up in the RFXcom manager log.
They do seem to work; the led blinks and signal sending is audible.
Any suggestions?
Any suggestions?
- Target OS: -
Re: Kerui D026
Please contact support rfxcom.com as this is not a Domoticz problem!
Re: Kerui D026
No need to shout. Thank you for your reply, I will contact support at rfxcom.
Re: Kerui D026
The two sensors are indeed working. I have collected undecoded ARC for both sensors and contacted RFXcom with the information.
Re: Kerui D026
Hi Boxel, also I have some Kerui, 4 units are not responding in RFXcom, how did you manage to get them working?
Re: Kerui D026
Problem with the Kerui sensors is: the look the same, but they have different protocols.
Also if you have Rubicson enabled, the most sensors won't respond.
They are working on a fix (new firmware), but it's not perfect yet.
At least, I've got mine working with a lot of support. (thx Bert)
