Danfoss Living Connect LC03 with Aeon Z-Stick Gen5
L2v2P
Re: Danfoss Living Connect LC03 with Aeon Z-Stick Gen5
Hi Guys,
Ik have the same Z-Stick connected to a Danfoss Living Connect LC-13. Once I have the LC-13 paired it starts submitting messages to the Z-Stick/Controller at a rate of about once every second:
After fifteen minutes or so the LC-13 freezes: it doesn't respond to any button presses, the screen remains off and it stops sending messages to the controller. If I take out the battery and put it back it starts working again, but only for approximately 15 minutes. A factory reset of both the LC-13 and Z-stick do not make it any better. I've seen the exact same behavior in Indigo by the way.
Any suggestions as to what might be the problem?
2016-11-17 06:40:59.175 (Z-stick) Thermostat (Verwarming keuken - klein)\
2016-11-17 06:41:00.226 (Z-stick) Thermostat (Verwarming keuken - klein)\
2016-11-17 06:41:01.454 (Z-stick) Thermostat (Verwarming keuken - klein)\
2016-11-17 06:41:02.694 (Z-stick) Thermostat (Verwarming keuken - klein)\
2016-11-17 06:41:03.563 (P1) P1 Smart Meter (Elektriciteit)\
2016-11-17 06:41:03.924 (Z-stick) Thermostat (Verwarming keuken - klein)\
2016-11-17 06:41:05.164 (Z-stick) Thermostat (Verwarming keuken - klein)\
2016-11-17 06:41:06.394 (Z-stick) Thermostat (Verwarming keuken - klein)\
2016-11-17 06:41:07.634 (Z-stick) Thermostat (Verwarming keuken - klein)\
2016-11-17 06:41:08.864 (Z-stick) Thermostat (Verwarming keuken - klein)\
2016-11-17 06:41:10.094 (Z-stick) Thermostat (Verwarming keuken - klein)\
2016-11-17 06:41:11.334 (Z-stick) Thermostat (Verwarming keuken - klein)\
2016-11-17 06:41:12.567 (Z-stick) Thermostat (Verwarming keuken - klein)\
2016-11-17 06:41:13.663 (P1) P1 Smart Meter (Elektriciteit)\
2016-11-17 06:41:13.804 (Z-stick) Thermostat (Verwarming keuken - klein)\
2016-11-17 06:41:15.034 (Z-stick) Thermostat (Verwarming keuken - klein)\
2016-11-17 06:41:16.274 (Z-stick) Thermostat (Verwarming keuken - klein)\
L2v2P
Also, when I enable debug logging I continuously get this:
It seems that the LC-13 continuously sends its settings (setpoint for example) to the controller for some odd reason. Is the LC-13 malfunctioning?
2016-11-17 20:09:44.617 Detail, Node002, Received: 0x01, 0x09, 0x00, 0x04, 0x00, 0x02, 0x03, 0x80, 0x03, 0x3a, 0x4a
2016-11-17 20:09:44.617 Info, Node002, Received Battery report from node 2: level=58
2016-11-17 20:09:44.617 Detail, Node002, Refreshed Value: old value=58, new value=58, type=byte
2016-11-17 20:09:44.617 Detail, Node002, Changes to this value are not verified
2016-11-17 20:09:44.617 Detail, Node002, Notification: ValueChanged
2016-11-17 20:09:44.638 Detail, Node002, Received: 0x01, 0x0c, 0x00, 0x04, 0x00, 0x02, 0x06, 0x43, 0x03, 0x01, 0x42, 0x08, 0x34, 0xcc
2016-11-17 20:09:44.638 Detail, Node002, Refreshed Value: old value=21.00, new value=21.00, type=decimal
2016-11-17 20:09:44.638 Detail, Node002, Changes to this value are not verified
2016-11-17 20:09:44.638 Info, Node002, Received thermostat setpoint report: Setpoint Heating 1 = 21.00C
2016-11-17 20:09:44.638 Detail, Node002, Notification: ValueChanged
2016-11-17 20:09:44.639 (Controller) Thermostat (Heating 1)
2016-11-17 20:09:44.659 Detail, Node002, Received: 0x01, 0x0a, 0x00, 0x04, 0x00, 0x02, 0x04, 0x46, 0x08, 0x00, 0x7f, 0xc6
2016-11-17 20:09:44.659 Info, Node002, Received climate control schedule override report:
2016-11-17 20:09:44.659 Info, Node002, Override State: None:
2016-11-17 20:09:44.659 Detail, Node002, Refreshed Value: old value=0, new value=0, type=list
2016-11-17 20:09:44.659 Detail, Node002, Changes to this value are not verified
2016-11-17 20:09:44.659 Detail, Node002, Refreshed Value: old value=127, new value=127, type=byte
2016-11-17 20:09:44.659 Detail, Node002, Notification: ValueChanged
2016-11-17 20:09:44.679 Detail, Node002, Received: 0x01, 0x08, 0x00, 0x04, 0x00, 0x02, 0x02, 0x84, 0x07, 0x70
2016-11-17 20:09:44.679 Info, Node002, Received Wakeup Notification from node 2
2016-11-17 20:09:44.679 Info, Node002, Node 2 has been marked as awake
2016-11-17 20:09:44.679 Detail, Node002, Queuing (WakeUp) WakeUpCmd_NoMoreInformation (Node=2): 0x01, 0x09, 0x00, 0x13, 0x02, 0x02, 0x84, 0x08, 0x25, 0xaa, 0xe6
2016-11-17 20:09:44.679 Detail, Node002, Notification: Notification - Node Awake
2016-11-17 20:09:44.679 Info, Node002, Sending (WakeUp) message (Callback ID=0xaa, Expected Reply=0x13) - WakeUpCmd_NoMoreInformation (Node=2): 0x01, 0x09, 0x00, 0x13, 0x02, 0x02, 0x84, 0x08, 0x25, 0xaa, 0xe6
2016-11-17 20:09:44.687 Detail, Node002, Received: 0x01, 0x04, 0x01, 0x13, 0x01, 0xe8
2016-11-17 20:09:44.687 Detail, Node002, ZW_SEND_DATA delivered to Z-Wave stack
2016-11-17 20:09:44.705 Detail, Node002, Received: 0x01, 0x07, 0x00, 0x13, 0xaa, 0x00, 0x00, 0x02, 0x43
2016-11-17 20:09:44.705 Detail, Node002, ZW_SEND_DATA Request with callback ID 0xaa received (expected 0xaa)
2016-11-17 20:09:44.705 Info, Node002, Request RTT 26 Average Request RTT 26
2016-11-17 20:09:44.705 Info, Node002, Node 2 has been marked as asleep
2016-11-17 20:09:44.705 Detail, Expected callbackId was received
2016-11-17 20:09:44.705 Detail, Expected reply was received
2016-11-17 20:09:44.705 Detail, Message transaction complete
2016-11-17 20:09:44.705 Detail, Node002, Removing current message
2016-11-17 20:09:44.705 Detail, Node002, Notification: Notification - Node Asleep
2016-11-17 20:09:45.720 Detail, Node002, Received: 0x01, 0x09, 0x00, 0x04, 0x00, 0x02, 0x03, 0x80, 0x03, 0x3a, 0x4a
2016-11-17 20:09:45.721 Detail,
antares
Has there been any progress with regards of not being able to set temperature from Blockly scripts directly to the thermostat? Do we still have to use the URL calls?
L2v2P
It has been implemented in the current beta:
Source: https://github.com/domoticz/domoticz/bl ... istory.txt
Version 3.xxxx (December xth 2016)
- Implemented: Blockly/Lua Set SetPoint option
L2v2P
It turned out the unit was defective; I returned it and got a new one.L2v2P wrote: It seems that the LC-13 continuously sends its settings (setpoint for example) to the controller for some odd reason. Is the LC-13 malfunctioning?
antares
Hmmm.... running current beta haven't seen that option, yet in Blockly. I'll have a look whether I can find it. Thanks for the hint!L2v2P wrote:It has been implemented in the current beta:
Source: https://github.com/domoticz/domoticz/bl ... istory.txtCode: Select all
Version 3.xxxx (December xth 2016) [...] - Implemented: Blockly/Lua Set SetPoint option [...]
Olfer
Try to look at it via MyDomoticz. I found it there, but not via my local Webview :/
If you use that feature in MyDomoticz, you wont be able to edit it on you local view... Unfortunately
Domoticz on RPi3 with Aeontec Z-Stick gen5. Beta.
Z-Wave, Zigbee, WiFi and MQTT (mainly Tasmota), Neo Cool Cam, Devolo, Fibaro, Shelly, Hue, Osram, Blitzwolf, TP-Link, Alexa. Latest: Somfy IO integration
bickel
Although this is an older thread..i have the same issue.
I already have 7 danfoss living connects working and i had 2 extra in stock which i want to use now to replace a defected one.
But the inclusion will not succeed for both.
Got the Aeotec Z-Stick S2.
Both devices had never been included, but i also tried to factory reset them without success.
Procedures i tried:
1-
Stop domoticz
Take z-stick to the mounted danfoss
danfoss is in normal operator mode
enable inclusion mode on stick
press shortly the inclusion button on danfoss.
Normally you would see a change of the blinking light but nothing.
If i try the exlusion mode the stick is responding so communication seems to work.
2-enabled 'allow new hardware' in a running domoticz and pressed the inclusion button.
Both methods seems to fail on both devices.
Any ideas how i can troubleshoot this?
Gr,
Ronald
Procedures i tried:
1-
Stop domoticz
Gr,
Ronald
