[SOLVED] mini GPIO Topic is solved
433Mhz opensource Receiver & Transmitter.
Neutrino
Domoticz version: 2021.1
[SOLVED] mini GPIO
Post by Neutrino »
Hi !
Since the last stable release, i'm unable to use GPIO on Rapsberry.
How can we use the RFLink miniGPIO in domoticz ?
deennoo
Re: mini GPIO
Post by deennoo »
Best source is here : http://www.nemcon.nl/blog2/faq
As i'm your friend :
Q: What GPIO pins can I use and how do I use them?
A: The following pins are available:
Pin 26, 27, 28, 29 are input pins.
RFlink will report the status of these pins as if you are using a RF switch device.
When you short any of these 4 pins to ground a message of a state change is reported.
When you undo the short a new status message is send.
For example:
20;1A;GPIOset;ID=0;SWITCH=0;CMD=ON;
20;1B;GPIOset;ID=0;SWITCH=0;CMD=OFF;
You can use this for example for a wired doorbell switch.
Pin 30, 31, 32, 33 are output pins.
The following manual commands are used to control the pin status. 10;GPIOset;30;0;ON; 10;GPIOset;30;0;OFF;
10;GPIOset;31;0;ON; 10;GPIOset;31;0;OFF;
10;GPIOset;32;0;ON; 10;GPIOset;32;0;OFF;
10;GPIOset;33;0;ON; 10;GPIOset;33;0;OFF;
Setting a PIN to ON will put 5 volts on the pin. You can use this to drive a relais or so.
Using rflink create device tab.
http://domo-attitude.fr
Neutrino
Re: mini GPIO
Post by Neutrino »
deennoo wrote: Using rflink create device tab.
Thank you Deennoo, but I already seen this FAQ :mrgreen:
But your last sentence will very help me !
To add the GPIO 26 (input)
It creates a On/Off switch in device => OK :D
But
10;GPIOset;31;0;ON;
do nothing. :(
just a line in log.
2016-11-02 20:20:28.012 User: initiated a RFLink Device Create command: 10;GPIOset;31;0;ON;
deennoo
Re: mini GPIO
Post by deennoo »
Have you enable discover new device (as your an older user i'm sure yes but...)
Neutrino
Re: mini GPIO
Post by Neutrino »
As an older user, yes :D
Actually, it's always enable since the 1-wire hardware need this every reboot.
2016-11-02 21:29:45.865 User: initiated a RFLink Device Create command: 20;1C;GPIOset;ID=0;SWITCH=0;CMD=ON;
2016-11-02 21:29:45.956 (RFLink) Light/Switch (MiniGPIO 26)
2016-11-02 21:29:57.276 User: initiated a RFLink Device Create command: 20;1A;GPIOset;ID=0;SWITCH=0;CMD=ON;
2016-11-02 21:29:57.351 (RFLink) Light/Switch (MiniGPIO 26)
2 commands via Hardware tabs => Same result, only one switch :|
And when I short to the ground the pins (26-27-28-29), nothing appends.
Neutrino
Re: mini GPIO
Post by Neutrino »
Thanks to the Stuntteam to have solved my problem.
1st, you need to enable the GPIO.
In the "Create RFLink Devices" popup, enter the command :
10;setgpio=on
With "Accept new Hardware Devices" enabled, just short to ground the pins 26 27 28 and 29, the devices will be create in devices tab.
To create an output device, in the same popup, entrer the following command :
20;01;GPIOset;ID=30;SWITCH=0;CMD=ON;
Congratulations, you can control the pin 30 ! :mrgreen:
Do the same with 31 32 and 33 :)
Stuntteam
Re: [SOLVED] mini GPIO
Post by Stuntteam »
You can also enable gpio within rflink loader after flashing the Arduino..
adampr1
Post by adampr1 »
Hi, I've RFlink 44.8 and configured like in this post. All inputs works ok , but from all four outputs only one (GPIO30) is switched OK.
Even if Domoticz send command:
User: Admin initiated a switch command (223/GPIO_31/On)
RFLink Sending: 10;GPIOset;000031;0;ON
(RFLink) Light/Switch (GPIO_31)
that will turn on GPIO30 (if was previous Off)
Any from GPIO 30..33 switch on/off command switch only GPIO30.
Any sugestion ?
Domoticz Beta release on OrangePI PC,
Domoticz Beta release on BananaPI,
2x RFLink 45.4 (test version),
ESPEasy (different configurations),
MySensors (different configurations),
2x MiLight RGBW (over RFLink)
and others things :)
Stuntteam
Post by Stuntteam »
PM send..
adampr1
Post by adampr1 »
working like a charm with test version RFLink v45.4. Thank You.
Users browsing this forum: Google [Bot] and 0 guests
