Hi!
What's the best way to send http control command to devices in lua scripts?
I'm currently using "openurl"
My devices often are unreachable (bad wifi, chip crash etc)
I think this eventually is making domoticz unstable.
There must be a way for domoticz to control devices that doesn't lead it to eventually crash when those devices are unreachable surely?
(By crash I mean the web ui stops responding, the error log then starts showing domoticz folders as missing etc)
Example of scripts:
commandArray = {};
IP = '192.168.2.170';
Port = '80';
GPIO = 3; -- r=0,g=1,b=2,w=3
DomDevice = 'Bathroom Ceiling Lamp'
if devicechanged[DomDevice] then
if(devicechanged[DomDevice]=='Off') then
print("Turning OFF with openurl " .. DomDevice)
commandArray['OpenURL']="http://" .. IP .. ":" .. Port .. "/control?cmd=PWMFADE," .. tostring(GPIO) .. ",0,1"
elseif (devicechanged[DomDevice]=='On') then
print("Turning On with openurl value : " .. tostring(uservariables[DomDevice]))
otherdevices_svalues[DomDevice] = tostring(uservariables[DomDevice])
commandArray['OpenURL']="http://" .. IP .. ":" .. Port .. "/control?cmd=PWMFADE," .. tostring(GPIO) .. "," .. tostring(tostring(uservariables[DomDevice]*10+0)) .. ",1" -- new dimmers now do 0-100!
print("Value openurl sent from domoticz is : " .. otherdevices_svalues[DomDevice])
uservariables[DomDevice] = otherdevices_svalues[DomDevice]
commandArray['Variable:'..DomDevice] = uservariables[DomDevice]
end;
commandArray = {};
DomDevice = 'House Thermostat';
IP = '192.168.2.180'
Port = '80'
function send(msg)
runcommand = "echo "..string.char(34).."POST "..msg.. " HTTP/1.1"..string.char(13)..string.char(10)..string.char(13)..string.char(10)..string.char(34).."| telnet "..IP.." "..Port.." "
print (runcommand)
os.execute(runcommand)
commandArray['OpenURL']="http://" .. IP .. ":" .. Port .. "/control?cmd=thermoset," .. tostring(otherdevices_svalues[DomDevice])
print("Thermoset Rads Set :" .. tostring(otherdevices_svalues[DomDevice]))
Cheers for any ideas!
Best way to control devices
- Egregius
- Domoticz version: v2024.7
Re: Best way to control devices
I would think you need to set a timeout for the requests and act upon that.
Don't know about lua, in PHP you can set that for either file_get_contents and curl:
But complaining that folders are missing shouldn't have anything to do with it.
function curl($url){
$headers=array('Content-Type: application/json');
$ch=curl_init();
curl_setopt($ch,CURLOPT_URL,$url);
curl_setopt($ch,CURLOPT_HTTPHEADER,$headers);
curl_setopt($ch,CURLOPT_RETURNTRANSFER,1);
curl_setopt($ch,CURLOPT_FRESH_CONNECT,TRUE);
curl_setopt($ch,CURLOPT_TIMEOUT,5);
$data=curl_exec($ch);
curl_close($ch);
return $data;
$ctx=stream_context_create(array('http'=>array('timeout' => 7)));
//usage:
curl('urltoget');
file_get_contents('urltoget',false,$ctx);
