zwave: trouble including devices
Thelure
Post by Thelure »
Hello!
I've spent a few evenings trying to get zwave to work on a pi3 using a RaZberry2 board on the GPIO pins. I've got communication going from domoticz to the zwave module but I've not been able to include the three different devices I have been trying to include. I have enabled the debug mode and am looking in the logs in the OpenZWave Control panel. It looks like the controller is receiving communications from the nodes but no matter what the nodes reply the controller seems to think it's a bad reply and the node is not included. It does not matter if I use secure or not or if I try to exclude the nodes first.
Can someone tell this newbie what I'm doing wrong here?
Is there some issue with the serial connection or is the controller bad? (the LEDs on the RaZberry board behave as they should based on the manual)
log:
2016-11-16 21:39:52.838 Detail, Queuing (Controller) Add Device
2016-11-16 21:39:52.839 Info, Add Device
2016-11-16 21:39:52.839 Detail, contrlr, Queuing (Command) ControllerCommand_AddDevice: 0x01, 0x05, 0x00, 0x4a, 0xc1, 0x17, 0x66
2016-11-16 21:39:52.839 Detail, Notification: ControllerCommand - Starting
2016-11-16 21:39:52.839 Info, contrlr, Sending (Command) message (Callback ID=0x17, Expected Reply=0x4a) - ControllerCommand_AddDevice: 0x01, 0x05, 0x00, 0x4a, 0xc1, 0x17, 0x66
2016-11-16 21:39:52.842 Detail, contrlr, Received: 0x01, 0x07, 0x00, 0x4a, 0x17, 0x01, 0x00, 0x00, 0xa4
2016-11-16 21:39:52.843 Detail,
2016-11-16 21:39:52.843 Info, contrlr, FUNC_ID_ZW_ADD_NODE_TO_NETWORK:
2016-11-16 21:39:52.843 Info, contrlr, ADD_NODE_STATUS_LEARN_READY
2016-11-16 21:39:52.843 Detail, Node001, Expected callbackId was received
2016-11-16 21:39:52.843 Detail, Node001, Expected reply was received
2016-11-16 21:39:52.843 Detail, Node001, Message transaction complete
2016-11-16 21:39:52.843 Detail, contrlr, Removing current message
2016-11-16 21:39:52.843 Detail, Notification: ControllerCommand - Waiting
2016-11-16 21:39:55.374 Detail, Received: 0x01, 0x07, 0x00, 0x4a, 0x17, 0x02, 0x00, 0x00, 0xa7
2016-11-16 21:39:55.374 Info, FUNC_ID_ZW_ADD_NODE_TO_NETWORK:
2016-11-16 21:39:55.374 Info, ADD_NODE_STATUS_NODE_FOUND
2016-11-16 21:39:55.374 Detail, Notification: ControllerCommand - InProgress
2016-11-16 21:39:58.559 Detail, Received: 0x01, 0x07, 0x00, 0x4a, 0x17, 0x07, 0x00, 0x00, 0xa2
2016-11-16 21:39:58.559 Info, FUNC_ID_ZW_ADD_NODE_TO_NETWORK:
2016-11-16 21:39:58.559 Info, ADD_NODE_STATUS_FAILED
2016-11-16 21:39:58.559 Detail, Removing current message
2016-11-16 21:39:58.559 Detail, contrlr, Queuing (Command) Add Node Stop: 0x01, 0x04, 0x00, 0x4a, 0x05, 0xb4
2016-11-16 21:39:58.559 Detail, Notification: ControllerCommand - Failed
2016-11-16 21:39:58.559 Info, contrlr, Sending (Command) message (Callback ID=0x00, Expected Reply=0x4a) - Add Node Stop: 0x01, 0x04, 0x00, 0x4a, 0x05, 0xb4
2016-11-16 21:39:58.669 Detail, contrlr, Received: 0x01, 0x07, 0x00, 0x4a, 0x17, 0x06, 0x00, 0x00, 0xa3
2016-11-16 21:39:58.669 Info, contrlr, FUNC_ID_ZW_ADD_NODE_TO_NETWORK:
2016-11-16 21:39:58.669 Detail, Node006, Expected reply was received
2016-11-16 21:39:58.669 Detail, Node006, Message transaction complete
2016-11-16 21:39:58.669 Detail, contrlr, Removing current message
2016-11-16 21:39:58.669 Detail, Notification: ControllerCommand - Completed
2016-11-16 21:40:18.746 Detail, Queuing (Controller) Add Device
2016-11-16 21:40:18.746 Info, Add Device
2016-11-16 21:40:18.746 Detail, contrlr, Queuing (Command) ControllerCommand_AddDevice: 0x01, 0x05, 0x00, 0x4a, 0xc1, 0x18, 0x69
2016-11-16 21:40:18.746 Detail, Notification: ControllerCommand - Starting
2016-11-16 21:40:18.746 Info, contrlr, Sending (Command) message (Callback ID=0x18, Expected Reply=0x4a) - ControllerCommand_AddDevice: 0x01, 0x05, 0x00, 0x4a, 0xc1, 0x18, 0x69
2016-11-16 21:40:18.749 Detail, contrlr, Received: 0x01, 0x07, 0x00, 0x4a, 0x18, 0x01, 0x00, 0x00, 0xab
2016-11-16 21:40:18.750 Detail,
2016-11-16 21:40:18.750 Info, contrlr, FUNC_ID_ZW_ADD_NODE_TO_NETWORK:
2016-11-16 21:40:18.750 Info, contrlr, ADD_NODE_STATUS_LEARN_READY
2016-11-16 21:40:18.750 Detail, Node001, Expected callbackId was received
2016-11-16 21:40:18.750 Detail, Node001, Expected reply was received
2016-11-16 21:40:18.750 Detail, Node001, Message transaction complete
2016-11-16 21:40:18.750 Detail, contrlr, Removing current message
2016-11-16 21:40:18.750 Detail, Notification: ControllerCommand - Waiting
2016-11-16 21:41:41.650 Detail, Received: 0x01, 0x07, 0x00, 0x4a, 0x18, 0x02, 0x00, 0x00, 0xa8
2016-11-16 21:41:41.650 Info, FUNC_ID_ZW_ADD_NODE_TO_NETWORK:
2016-11-16 21:41:41.650 Info, ADD_NODE_STATUS_NODE_FOUND
2016-11-16 21:41:41.651 Detail, Notification: ControllerCommand - InProgress
2016-11-16 21:41:45.169 Detail, Received: 0x01, 0x07, 0x00, 0x4a, 0x18, 0x07, 0x00, 0x00, 0xad
2016-11-16 21:41:45.169 Info, FUNC_ID_ZW_ADD_NODE_TO_NETWORK:
2016-11-16 21:41:45.169 Info, ADD_NODE_STATUS_FAILED
2016-11-16 21:41:45.169 Detail, Removing current message
2016-11-16 21:41:45.169 Detail, contrlr, Queuing (Command) Add Node Stop: 0x01, 0x04, 0x00, 0x4a, 0x05, 0xb4
2016-11-16 21:41:45.169 Detail, Notification: ControllerCommand - Failed
2016-11-16 21:41:45.170 Detail,
2016-11-16 21:41:45.170 Info, contrlr, Sending (Command) message (Callback ID=0x00, Expected Reply=0x4a) - Add Node Stop: 0x01, 0x04, 0x00, 0x4a, 0x05, 0xb4
2016-11-16 21:41:45.279 Detail, contrlr, Received: 0x01, 0x07, 0x00, 0x4a, 0x18, 0x06, 0x00, 0x00, 0xac
2016-11-16 21:41:45.279 Info, contrlr, FUNC_ID_ZW_ADD_NODE_TO_NETWORK:
2016-11-16 21:41:45.279 Detail, Node006, Expected reply was received
2016-11-16 21:41:45.279 Detail, Node006, Message transaction complete
2016-11-16 21:41:45.279 Detail, contrlr, Removing current message
2016-11-16 21:41:45.279 Detail, Notification: ControllerCommand - Completed
2016-11-16 21:42:44.117 Detail, Queuing (Controller) Add Device
2016-11-16 21:42:44.117 Info, Add Device
2016-11-16 21:42:44.118 Detail, contrlr, Queuing (Command) ControllerCommand_AddDevice: 0x01, 0x05, 0x00, 0x4a, 0xc1, 0x19, 0x68
2016-11-16 21:42:44.118 Detail, Notification: ControllerCommand - Starting
2016-11-16 21:42:44.118 Info, contrlr, Sending (Command) message (Callback ID=0x19, Expected Reply=0x4a) - ControllerCommand_AddDevice: 0x01, 0x05, 0x00, 0x4a, 0xc1, 0x19, 0x68
2016-11-16 21:42:44.121 Detail, contrlr, Received: 0x01, 0x07, 0x00, 0x4a, 0x19, 0x01, 0x00, 0x00, 0xaa
2016-11-16 21:42:44.121 Info, contrlr, FUNC_ID_ZW_ADD_NODE_TO_NETWORK:
2016-11-16 21:42:44.121 Info, contrlr, ADD_NODE_STATUS_LEARN_READY
2016-11-16 21:42:44.121 Detail, Node001, Expected callbackId was received
2016-11-16 21:42:44.121 Detail, Node001, Expected reply was received
2016-11-16 21:42:44.121 Detail, Node001, Message transaction complete
2016-11-16 21:42:44.122 Detail,
2016-11-16 21:42:44.122 Detail, contrlr, Removing current message
2016-11-16 21:42:44.122 Detail, Notification: ControllerCommand - Waiting
2016-11-16 21:42:57.234 Detail, Received: 0x01, 0x07, 0x00, 0x4a, 0x19, 0x02, 0x00, 0x00, 0xa9
2016-11-16 21:42:57.235 Info, FUNC_ID_ZW_ADD_NODE_TO_NETWORK:
2016-11-16 21:42:57.235 Info, ADD_NODE_STATUS_NODE_FOUND
2016-11-16 21:42:57.235 Detail, Notification: ControllerCommand - InProgress
2016-11-16 21:43:00.542 Detail, Received: 0x01, 0x07, 0x00, 0x4a, 0x19, 0x07, 0x00, 0x00, 0xac
2016-11-16 21:43:00.546 Detail,
2016-11-16 21:43:00.546 Info, FUNC_ID_ZW_ADD_NODE_TO_NETWORK:
2016-11-16 21:43:00.546 Info, ADD_NODE_STATUS_FAILED
2016-11-16 21:43:00.546 Detail, Removing current message
2016-11-16 21:43:00.546 Detail, contrlr, Queuing (Command) Add Node Stop: 0x01, 0x04, 0x00, 0x4a, 0x05, 0xb4
2016-11-16 21:43:00.546 Detail, Notification: ControllerCommand - Failed
2016-11-16 21:43:00.546 Info, contrlr, Sending (Command) message (Callback ID=0x00, Expected Reply=0x4a) - Add Node Stop: 0x01, 0x04, 0x00, 0x4a, 0x05, 0xb4
2016-11-16 21:43:00.655 Detail, contrlr, Received: 0x01, 0x07, 0x00, 0x4a, 0x19, 0x06, 0x00, 0x00, 0xad
2016-11-16 21:43:00.656 Detail,
2016-11-16 21:43:00.656 Info, contrlr, FUNC_ID_ZW_ADD_NODE_TO_NETWORK:
2016-11-16 21:43:00.656 Detail, Node006, Expected reply was received
2016-11-16 21:43:00.656 Detail, Node006, Message transaction complete
2016-11-16 21:43:00.656 Detail, contrlr, Removing current message
2016-11-16 21:43:00.656 Detail, Notification: ControllerCommand - Completed
2016-11-16 21:43:58.941 Detail, Queuing (Controller) Add Device
2016-11-16 21:43:58.945 Info, Add Device
2016-11-16 21:43:58.945 Detail, contrlr, Queuing (Command) ControllerCommand_AddDevice: 0x01, 0x05, 0x00, 0x4a, 0xc1, 0x1a, 0x6b
2016-11-16 21:43:58.946 Detail, Notification: ControllerCommand - Starting
2016-11-16 21:43:58.946 Info, contrlr, Sending (Command) message (Callback ID=0x1a, Expected Reply=0x4a) - ControllerCommand_AddDevice: 0x01, 0x05, 0x00, 0x4a, 0xc1, 0x1a, 0x6b
2016-11-16 21:43:58.949 Detail, contrlr, Received: 0x01, 0x07, 0x00, 0x4a, 0x1a, 0x01, 0x00, 0x00, 0xa9
2016-11-16 21:43:58.949 Info, contrlr, FUNC_ID_ZW_ADD_NODE_TO_NETWORK:
2016-11-16 21:43:58.949 Info, contrlr, ADD_NODE_STATUS_LEARN_READY
2016-11-16 21:43:58.949 Detail, Node001, Expected callbackId was received
2016-11-16 21:43:58.949 Detail, Node001, Expected reply was received
2016-11-16 21:43:58.949 Detail, Node001, Message transaction complete
2016-11-16 21:43:58.950 Detail,
2016-11-16 21:43:58.950 Detail, contrlr, Removing current message
2016-11-16 21:43:58.950 Detail, Notification: ControllerCommand - Waiting
2016-11-16 21:44:09.642 Detail, Received: 0x01, 0x07, 0x00, 0x4a, 0x1a, 0x02, 0x00, 0x00, 0xaa
2016-11-16 21:44:09.642 Info, FUNC_ID_ZW_ADD_NODE_TO_NETWORK:
2016-11-16 21:44:09.642 Info, ADD_NODE_STATUS_NODE_FOUND
2016-11-16 21:44:09.642 Detail, Notification: ControllerCommand - InProgress
2016-11-16 21:44:12.916 Detail, Received: 0x01, 0x07, 0x00, 0x4a, 0x1a, 0x07, 0x00, 0x00, 0xaf
2016-11-16 21:44:12.916 Info, FUNC_ID_ZW_ADD_NODE_TO_NETWORK:
2016-11-16 21:44:12.916 Info, ADD_NODE_STATUS_FAILED
2016-11-16 21:44:12.916 Detail, Removing current message
2016-11-16 21:44:12.916 Detail, contrlr, Queuing (Command) Add Node Stop: 0x01, 0x04, 0x00, 0x4a, 0x05, 0xb4
2016-11-16 21:44:12.916 Detail, Notification: ControllerCommand - Failed
2016-11-16 21:44:12.916 Info, contrlr, Sending (Command) message (Callback ID=0x00, Expected Reply=0x4a) - Add Node Stop: 0x01, 0x04, 0x00, 0x4a, 0x05, 0xb4
2016-11-16 21:44:13.026 Detail, contrlr, Received: 0x01, 0x07, 0x00, 0x4a, 0x1a, 0x06, 0x00, 0x00, 0xae
2016-11-16 21:44:13.026 Info, contrlr, FUNC_ID_ZW_ADD_NODE_TO_NETWORK:
2016-11-16 21:44:13.026 Detail, Node006, Expected reply was received
2016-11-16 21:44:13.026 Detail, Node006, Message transaction complete
2016-11-16 21:44:13.026 Detail, contrlr, Removing current message
2016-11-16 21:44:13.026 Detail, Notification: ControllerCommand - Completed
2016-11-16 21:44:23.197 Detail, Queuing (Controller) Remove Device
2016-11-16 21:44:23.197 Info, Remove Device
2016-11-16 21:44:23.197 Detail, contrlr, Queuing (Command) ControllerCommand_RemoveDevice: 0x01, 0x05, 0x00, 0x4b, 0x81, 0x1b, 0x2b
2016-11-16 21:44:23.198 Detail, Notification: ControllerCommand - Starting
2016-11-16 21:44:23.198 Info, contrlr, Sending (Command) message (Callback ID=0x1b, Expected Reply=0x4b) - ControllerCommand_RemoveDevice: 0x01, 0x05, 0x00, 0x4b, 0x81, 0x1b, 0x2b
2016-11-16 21:44:23.201 Detail, contrlr, Received: 0x01, 0x07, 0x00, 0x4b, 0x1b, 0x01, 0x00, 0x00, 0xa9
2016-11-16 21:44:23.201 Info, FUNC_ID_ZW_REMOVE_NODE_FROM_NETWORK:
2016-11-16 21:44:23.201 Info, REMOVE_NODE_STATUS_LEARN_READY
2016-11-16 21:44:23.201 Detail, Node001, Expected callbackId was received
2016-11-16 21:44:23.201 Detail, Node001, Expected reply was received
2016-11-16 21:44:23.201 Detail, Node001, Message transaction complete
2016-11-16 21:44:23.201 Detail, contrlr, Removing current message
2016-11-16 21:44:23.202 Detail, Notification: ControllerCommand - Waiting
2016-11-16 21:44:27.001 Detail, Received: 0x01, 0x07, 0x00, 0x4b, 0x1b, 0x02, 0x00, 0x00, 0xaa
2016-11-16 21:44:27.002 Info, FUNC_ID_ZW_REMOVE_NODE_FROM_NETWORK:
2016-11-16 21:44:27.002 Info, REMOVE_NODE_STATUS_NODE_FOUND
2016-11-16 21:44:27.002 Detail, Notification: ControllerCommand - InProgress
2016-11-16 21:44:28.100 Detail, Received: 0x01, 0x18, 0x00, 0x4b, 0x1b, 0x03, 0x00, 0x11, 0x04, 0x07, 0x01, 0x5e, 0x5a, 0x7a, 0x85, 0x8e, 0x59, 0x70, 0x80, 0x72, 0x71, 0x73, 0x30, 0x86, 0x84, 0x39
2016-11-16 21:44:28.100 Info, FUNC_ID_ZW_REMOVE_NODE_FROM_NETWORK:
2016-11-16 21:44:28.100 Info, REMOVE_NODE_STATUS_REMOVING_SLAVE
2016-11-16 21:44:28.100 Warning, Remove Node Failed - NodeID 0 Returned
2016-11-16 21:44:28.100 Detail, Notification: ControllerCommand - Failed
2016-11-16 21:44:28.103 Detail, Received: 0x01, 0x18, 0x00, 0x4b, 0x1b, 0x06, 0x00, 0x11, 0x04, 0x07, 0x01, 0x5e, 0x5a, 0x7a, 0x85, 0x8e, 0x59, 0x70, 0x80, 0x72, 0x71, 0x73, 0x30, 0x86, 0x84, 0x3c
2016-11-16 21:44:41.350 Detail, Queuing (Controller) Remove Device
2016-11-16 21:44:41.350 Info, Remove Device
2016-11-16 21:44:41.350 Detail, contrlr, Queuing (Command) ControllerCommand_RemoveDevice: 0x01, 0x05, 0x00, 0x4b, 0x81, 0x1c, 0x2c
2016-11-16 21:44:41.350 Detail, Notification: ControllerCommand - Starting
2016-11-16 21:44:41.351 Detail,
2016-11-16 21:44:41.351 Info, contrlr, Sending (Command) message (Callback ID=0x1c, Expected Reply=0x4b) - ControllerCommand_RemoveDevice: 0x01, 0x05, 0x00, 0x4b, 0x81, 0x1c, 0x2c
2016-11-16 21:44:41.354 Detail, contrlr, Received: 0x01, 0x07, 0x00, 0x4b, 0x1c, 0x01, 0x00, 0x00, 0xae
2016-11-16 21:44:41.354 Info, FUNC_ID_ZW_REMOVE_NODE_FROM_NETWORK:
2016-11-16 21:44:41.354 Info, REMOVE_NODE_STATUS_LEARN_READY
2016-11-16 21:44:41.354 Detail, Node001, Expected callbackId was received
2016-11-16 21:44:41.354 Detail, Node001, Expected reply was received
2016-11-16 21:44:41.354 Detail, Node001, Message transaction complete
2016-11-16 21:44:41.354 Detail, contrlr, Removing current message
2016-11-16 21:44:41.354 Detail, Notification: ControllerCommand - Waiting
2016-11-16 21:44:46.431 Detail, Received: 0x01, 0x07, 0x00, 0x4b, 0x1c, 0x02, 0x00, 0x00, 0xad
2016-11-16 21:44:46.435 Detail,
2016-11-16 21:44:46.435 Info, FUNC_ID_ZW_REMOVE_NODE_FROM_NETWORK:
2016-11-16 21:44:46.435 Info, REMOVE_NODE_STATUS_NODE_FOUND
2016-11-16 21:44:46.436 Detail, Notification: ControllerCommand - InProgress
2016-11-16 21:44:47.410 Detail, Received: 0x01, 0x18, 0x00, 0x4b, 0x1c, 0x03, 0x00, 0x11, 0x04, 0x07, 0x01, 0x5e, 0x5a, 0x7a, 0x85, 0x8e, 0x59, 0x70, 0x80, 0x72, 0x71, 0x73, 0x30, 0x86, 0x84, 0x3e
2016-11-16 21:44:47.410 Info, FUNC_ID_ZW_REMOVE_NODE_FROM_NETWORK:
2016-11-16 21:44:47.410 Info, REMOVE_NODE_STATUS_REMOVING_SLAVE
2016-11-16 21:44:47.410 Warning, Remove Node Failed - NodeID 0 Returned
2016-11-16 21:44:47.410 Detail, Notification: ControllerCommand - Failed
2016-11-16 21:44:47.413 Detail, Received: 0x01, 0x18, 0x00, 0x4b, 0x1c, 0x06, 0x00, 0x11, 0x04, 0x07, 0x01, 0x5e, 0x5a, 0x7a, 0x85, 0x8e, 0x59, 0x70, 0x80, 0x72, 0x71, 0x73, 0x30, 0x86, 0x84, 0x3b
2016-11-16 21:45:05.486 Detail, Queuing (Controller) Remove Device
2016-11-16 21:45:05.486 Info, Remove Device
2016-11-16 21:45:05.486 Detail, contrlr, Queuing (Command) ControllerCommand_RemoveDevice: 0x01, 0x05, 0x00, 0x4b, 0x81, 0x1d, 0x2d
2016-11-16 21:45:05.486 Detail, Notification: ControllerCommand - Starting
2016-11-16 21:45:05.486 Info, contrlr, Sending (Command) message (Callback ID=0x1d, Expected Reply=0x4b) - ControllerCommand_RemoveDevice: 0x01, 0x05, 0x00, 0x4b, 0x81, 0x1d, 0x2d
2016-11-16 21:45:05.489 Detail, contrlr, Received: 0x01, 0x07, 0x00, 0x4b, 0x1d, 0x01, 0x00, 0x00, 0xaf
2016-11-16 21:45:05.490 Detail,
2016-11-16 21:45:05.490 Info, FUNC_ID_ZW_REMOVE_NODE_FROM_NETWORK:
2016-11-16 21:45:05.490 Info, REMOVE_NODE_STATUS_LEARN_READY
2016-11-16 21:45:05.490 Detail, Node001, Expected callbackId was received
2016-11-16 21:45:05.490 Detail, Node001, Expected reply was received
2016-11-16 21:45:05.490 Detail, Node001, Message transaction complete
2016-11-16 21:45:05.490 Detail, contrlr, Removing current message
2016-11-16 21:45:05.490 Detail, Notification: ControllerCommand - Waiting
2016-11-16 21:45:35.123 Detail, Received: 0x01, 0x07, 0x00, 0x4b, 0x1d, 0x02, 0x00, 0x00, 0xac
2016-11-16 21:45:35.123 Info, FUNC_ID_ZW_REMOVE_NODE_FROM_NETWORK:
2016-11-16 21:45:35.123 Info, REMOVE_NODE_STATUS_NODE_FOUND
2016-11-16 21:45:35.123 Detail, Notification: ControllerCommand - InProgress
2016-11-16 21:45:35.862 Detail, Received: 0x01, 0x18, 0x00, 0x4b, 0x1d, 0x03, 0x00, 0x11, 0x04, 0x07, 0x01, 0x5e, 0x5a, 0x7a, 0x85, 0x8e, 0x59, 0x70, 0x80, 0x72, 0x71, 0x73, 0x30, 0x86, 0x84, 0x3f
2016-11-16 21:45:35.862 Info, FUNC_ID_ZW_REMOVE_NODE_FROM_NETWORK:
2016-11-16 21:45:35.862 Info, REMOVE_NODE_STATUS_REMOVING_SLAVE
2016-11-16 21:45:35.862 Warning, Remove Node Failed - NodeID 0 Returned
2016-11-16 21:45:35.862 Detail, Notification: ControllerCommand - Failed
2016-11-16 21:45:35.865 Detail, Received: 0x01, 0x18, 0x00, 0x4b, 0x1d, 0x06, 0x00, 0x11, 0x04, 0x07, 0x01, 0x5e, 0x5a, 0x7a, 0x85, 0x8e, 0x59, 0x70, 0x80, 0x72, 0x71, 0x73, 0x30, 0x86, 0x84, 0x3a
2016-11-16 21:46:00.990 Detail, Node001, AdvanceQueries queryPending=0 queryRetries=0 queryStage=ProtocolInfo live=1
2016-11-16 21:46:00.990 Detail, Node001, QueryStage_Probe
2016-11-16 21:46:00.990 Detail, Node001, QueryStage_WakeUp
2016-11-16 21:46:00.990 Detail, Node001, QueryStage_ManufacturerSpecific1
2016-11-16 21:46:00.990 Detail, Node001, Load Controller Manufacturer Specific Config
2016-11-16 21:46:00.991 Detail, Node001, QueryStage_NodePlusInfo
2016-11-16 21:46:00.991 Detail, Node001, QueryStage_SecurityReport
2016-11-16 21:46:00.991 Detail, Node001, QueryStage_ManufacturerSpecific2
2016-11-16 21:46:00.991 Detail, Node001, QueryStage_Versions
2016-11-16 21:46:00.991 Detail, Node001, QueryStage_Instances
2016-11-16 21:46:00.991 Info, Node001, Essential node queries are complete
2016-11-16 21:46:00.991 Detail, Node001, Notification: EssentialNodeQueriesComplete
2016-11-16 21:46:00.991 Detail, Node001, QueryStage_Static
2016-11-16 21:46:00.991 Detail, Node001, QueryStage_Associations
2016-11-16 21:46:00.991 Detail, Node001, QueryStage_Neighbors
2016-11-16 21:46:00.991 Detail, Requesting routing info (neighbor list) for Node 1
2016-11-16 21:46:00.992 Detail, Node001, Queuing (Command) Get Routing Info (Node=1): 0x01, 0x07, 0x00, 0x80, 0x01, 0x00, 0x00, 0x03, 0x7a
2016-11-16 21:46:00.992 Detail, Node001, Queuing (Query) Query Stage Complete (Neighbors)
2016-11-16 21:46:00.993 Info, mgr, Manager::WriteConfig completed for driver with home ID of 0xe80d278e
2016-11-16 21:46:00.994 Detail,
2016-11-16 21:46:00.994 Info, Node001, Sending (Command) message (Callback ID=0x00, Expected Reply=0x80) - Get Routing Info (Node=1): 0x01, 0x07, 0x00, 0x80, 0x01, 0x00, 0x00, 0x03, 0x7a
2016-11-16 21:46:00.999 Detail, Node001, Received: 0x01, 0x20, 0x01, 0x80, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x5e
2016-11-16 21:46:01.000 Detail,
2016-11-16 21:46:01.000 Info, Node001, Received reply to FUNC_ID_ZW_GET_ROUTING_INFO
2016-11-16 21:46:01.000 Info, Node001, Neighbors of this node are:
2016-11-16 21:46:01.000 Info, Node001, (none reported)
2016-11-16 21:46:01.000 Detail, Expected reply was received
2016-11-16 21:46:01.000 Detail, Message transaction complete
2016-11-16 21:46:01.000 Detail, Node001, Removing current message
2016-11-16 21:46:01.000 Detail, Node001, Query Stage Complete (Neighbors)
2016-11-16 21:46:01.000 Detail, Node001, AdvanceQueries queryPending=0 queryRetries=0 queryStage=Session live=1
2016-11-16 21:46:01.000 Detail, Node001, QueryStage_Session
2016-11-16 21:46:01.000 Detail, Node001, QueryStage_Dynamic
2016-11-16 21:46:01.001 Detail, Node001, QueryStage_Configuration
2016-11-16 21:46:01.001 Detail, Node001, QueryStage_Complete
2016-11-16 21:46:01.001 Warning, CheckCompletedNodeQueries m_allNodesQueried=1 m_awakeNodesQueried=1
2016-11-16 21:46:01.001 Detail, Node001, Notification: NodeQueriesComplete
2016-11-16 21:46:11.206 Detail, Queuing (Controller) Add Device
2016-11-16 21:46:11.206 Info, Add Device
2016-11-16 21:46:11.207 Detail, contrlr, Queuing (Command) ControllerCommand_AddDevice: 0x01, 0x05, 0x00, 0x4a, 0xc1, 0x1e, 0x6f
2016-11-16 21:46:11.207 Detail, Notification: ControllerCommand - Starting
2016-11-16 21:46:11.207 Info, contrlr, Sending (Command) message (Callback ID=0x1e, Expected Reply=0x4a) - ControllerCommand_AddDevice: 0x01, 0x05, 0x00, 0x4a, 0xc1, 0x1e, 0x6f
2016-11-16 21:46:11.210 Detail, contrlr, Received: 0x01, 0x07, 0x00, 0x4a, 0x1e, 0x01, 0x00, 0x00, 0xad
2016-11-16 21:46:11.210 Info, contrlr, FUNC_ID_ZW_ADD_NODE_TO_NETWORK:
2016-11-16 21:46:11.210 Info, contrlr, ADD_NODE_STATUS_LEARN_READY
2016-11-16 21:46:11.210 Detail, Node001, Expected callbackId was received
2016-11-16 21:46:11.211 Detail, Node001, Expected reply was received
2016-11-16 21:46:11.211 Detail, Node001, Message transaction complete
2016-11-16 21:46:11.211 Detail, contrlr, Removing current message
2016-11-16 21:46:11.211 Detail, Notification: ControllerCommand - Waiting
2016-11-16 21:46:17.191 Detail, Received: 0x01, 0x07, 0x00, 0x4a, 0x1e, 0x02, 0x00, 0x00, 0xae
2016-11-16 21:46:17.191 Info, FUNC_ID_ZW_ADD_NODE_TO_NETWORK:
2016-11-16 21:46:17.191 Info, ADD_NODE_STATUS_NODE_FOUND
2016-11-16 21:46:17.191 Detail, Notification: ControllerCommand - InProgress
2016-11-16 21:46:20.645 Detail, Received: 0x01, 0x07, 0x00, 0x4a, 0x1e, 0x07, 0x00, 0x00, 0xab
2016-11-16 21:46:20.645 Info, FUNC_ID_ZW_ADD_NODE_TO_NETWORK:
2016-11-16 21:46:20.645 Info, ADD_NODE_STATUS_FAILED
2016-11-16 21:46:20.646 Detail, Removing current message
2016-11-16 21:46:20.646 Detail, contrlr, Queuing (Command) Add Node Stop: 0x01, 0x04, 0x00, 0x4a, 0x05, 0xb4
2016-11-16 21:46:20.646 Detail, Notification: ControllerCommand - Failed
2016-11-16 21:46:20.646 Info, contrlr, Sending (Command) message (Callback ID=0x00, Expected Reply=0x4a) - Add Node Stop: 0x01, 0x04, 0x00, 0x4a, 0x05, 0xb4
2016-11-16 21:46:20.755 Detail, contrlr, Received: 0x01, 0x07, 0x00, 0x4a, 0x1e, 0x06, 0x00, 0x00, 0xaa
2016-11-16 21:46:20.756 Detail,
2016-11-16 21:46:20.756 Info, contrlr, FUNC_ID_ZW_ADD_NODE_TO_NETWORK:
2016-11-16 21:46:20.756 Detail, Node006, Expected reply was received
2016-11-16 21:46:20.756 Detail, Node006, Message transaction complete
2016-11-16 21:46:20.756 Detail, contrlr, Removing current message
2016-11-16 21:46:20.756 Detail, Notification: ControllerCommand - Completed
2016-11-16 21:47:07.494 Detail, Queuing (Controller) Add Device
2016-11-16 21:47:07.495 Info, Add Device
2016-11-16 21:47:07.495 Detail, contrlr, Queuing (Command) ControllerCommand_AddDevice: 0x01, 0x05, 0x00, 0x4a, 0xc1, 0x1f, 0x6e
2016-11-16 21:47:07.495 Detail, Notification: ControllerCommand - Starting
2016-11-16 21:47:07.495 Info, contrlr, Sending (Command) message (Callback ID=0x1f, Expected Reply=0x4a) - ControllerCommand_AddDevice: 0x01, 0x05, 0x00, 0x4a, 0xc1, 0x1f, 0x6e
2016-11-16 21:47:07.498 Detail, contrlr, Received: 0x01, 0x07, 0x00, 0x4a, 0x1f, 0x01, 0x00, 0x00, 0xac
2016-11-16 21:47:07.499 Info, contrlr, FUNC_ID_ZW_ADD_NODE_TO_NETWORK:
2016-11-16 21:47:07.499 Info, contrlr, ADD_NODE_STATUS_LEARN_READY
2016-11-16 21:47:07.499 Detail, Node001, Expected callbackId was received
2016-11-16 21:47:07.499 Detail, Node001, Expected reply was received
2016-11-16 21:47:07.499 Detail, Node001, Message transaction complete
2016-11-16 21:47:07.499 Detail, contrlr, Removing current message
2016-11-16 21:47:07.499 Detail, Notification: ControllerCommand - Waiting
2016-11-16 21:47:20.015 Detail, Received: 0x01, 0x07, 0x00, 0x4a, 0x1f, 0x02, 0x00, 0x00, 0xaf
2016-11-16 21:47:20.015 Info, FUNC_ID_ZW_ADD_NODE_TO_NETWORK:
2016-11-16 21:47:20.015 Info, ADD_NODE_STATUS_NODE_FOUND
2016-11-16 21:47:20.015 Detail, Notification: ControllerCommand - InProgress
2016-11-16 21:47:23.288 Detail, Received: 0x01, 0x07, 0x00, 0x4a, 0x1f, 0x07, 0x00, 0x00, 0xaa
2016-11-16 21:47:23.288 Info, FUNC_ID_ZW_ADD_NODE_TO_NETWORK:
2016-11-16 21:47:23.288 Info, ADD_NODE_STATUS_FAILED
2016-11-16 21:47:23.288 Detail, Removing current message
2016-11-16 21:47:23.288 Detail, contrlr, Queuing (Command) Add Node Stop: 0x01, 0x04, 0x00, 0x4a, 0x05, 0xb4
2016-11-16 21:47:23.288 Detail, Notification: ControllerCommand - Failed
2016-11-16 21:47:23.288 Info, contrlr, Sending (Command) message (Callback ID=0x00, Expected Reply=0x4a) - Add Node Stop: 0x01, 0x04, 0x00, 0x4a, 0x05, 0xb4
2016-11-16 21:47:23.398 Detail, contrlr, Received: 0x01, 0x07, 0x00, 0x4a, 0x1f, 0x06, 0x00, 0x00, 0xab
2016-11-16 21:47:23.398 Info, contrlr, FUNC_ID_ZW_ADD_NODE_TO_NETWORK:
2016-11-16 21:47:23.398 Detail, Node006, Expected reply was received
2016-11-16 21:47:23.398 Detail, Node006, Message transaction complete
2016-11-16 21:47:23.398 Detail, contrlr, Removing current message
2016-11-16 21:47:23.398 Detail, Notification: ControllerCommand - Completed
2016-11-16 21:47:41.535 Detail, Queuing (Controller) Remove Device
2016-11-16 21:47:41.535 Info, Remove Device
2016-11-16 21:47:41.536 Detail, contrlr, Queuing (Command) ControllerCommand_RemoveDevice: 0x01, 0x05, 0x00, 0x4b, 0x81, 0x20, 0x10
2016-11-16 21:47:41.536 Detail, Notification: ControllerCommand - Starting
2016-11-16 21:47:41.536 Info, contrlr, Sending (Command) message (Callback ID=0x20, Expected Reply=0x4b) - ControllerCommand_RemoveDevice: 0x01, 0x05, 0x00, 0x4b, 0x81, 0x20, 0x10
2016-11-16 21:47:41.539 Detail, contrlr, Received: 0x01, 0x07, 0x00, 0x4b, 0x20, 0x01, 0x00, 0x00, 0x92
2016-11-16 21:47:41.539 Info, FUNC_ID_ZW_REMOVE_NODE_FROM_NETWORK:
2016-11-16 21:47:41.539 Info, REMOVE_NODE_STATUS_LEARN_READY
2016-11-16 21:47:41.539 Detail, Node001, Expected callbackId was received
2016-11-16 21:47:41.539 Detail, Node001, Expected reply was received
2016-11-16 21:47:41.540 Detail, Node001, Message transaction complete
2016-11-16 21:47:41.540 Detail, contrlr, Removing current message
2016-11-16 21:47:41.540 Detail, Notification: ControllerCommand - Waiting
2016-11-16 21:47:47.655 Detail, Received: 0x01, 0x07, 0x00, 0x4b, 0x20, 0x02, 0x00, 0x00, 0x91
2016-11-16 21:47:47.655 Info, FUNC_ID_ZW_REMOVE_NODE_FROM_NETWORK:
2016-11-16 21:47:47.655 Info, REMOVE_NODE_STATUS_NODE_FOUND
2016-11-16 21:47:47.655 Detail, Notification: ControllerCommand - InProgress
2016-11-16 21:47:48.514 Detail, Received: 0x01, 0x1a, 0x00, 0x4b, 0x20, 0x03, 0x00, 0x13, 0x04, 0x07, 0x01, 0x5e, 0x20, 0x25, 0x30, 0x71, 0x70, 0x85, 0x80, 0x5a, 0x59, 0x73, 0x98, 0x86, 0x72, 0xef, 0x20, 0x20
2016-11-16 21:47:48.514 Info, FUNC_ID_ZW_REMOVE_NODE_FROM_NETWORK:
2016-11-16 21:47:48.514 Info, REMOVE_NODE_STATUS_REMOVING_SLAVE
2016-11-16 21:47:48.514 Warning, Remove Node Failed - NodeID 0 Returned
2016-11-16 21:47:48.514 Detail, Notification: ControllerCommand - Failed
2016-11-16 21:47:48.517 Detail, Received: 0x01, 0x1a, 0x00, 0x4b, 0x20, 0x06, 0x00, 0x13, 0x04, 0x07, 0x01, 0x5e, 0x20, 0x25, 0x30, 0x71, 0x70, 0x85, 0x80, 0x5a, 0x59, 0x73, 0x98, 0x86, 0x72, 0xef, 0x20, 0x25
2016-11-16 21:48:14.088 Detail, Queuing (Controller) Remove Device
2016-11-16 21:48:14.092 Info, Remove Device
2016-11-16 21:48:14.092 Detail, contrlr, Queuing (Command) ControllerCommand_RemoveDevice: 0x01, 0x05, 0x00, 0x4b, 0x81, 0x21, 0x11
2016-11-16 21:48:14.092 Detail, Notification: ControllerCommand - Starting
2016-11-16 21:48:14.092 Info, contrlr, Sending (Command) message (Callback ID=0x21, Expected Reply=0x4b) - ControllerCommand_RemoveDevice: 0x01, 0x05, 0x00, 0x4b, 0x81, 0x21, 0x11
2016-11-16 21:48:14.096 Detail, contrlr, Received: 0x01, 0x07, 0x00, 0x4b, 0x21, 0x01, 0x00, 0x00, 0x93
2016-11-16 21:48:14.096 Info, FUNC_ID_ZW_REMOVE_NODE_FROM_NETWORK:
2016-11-16 21:48:14.096 Info, REMOVE_NODE_STATUS_LEARN_READY
2016-11-16 21:48:14.096 Detail, Node001, Expected callbackId was received
2016-11-16 21:48:14.096 Detail, Node001, Expected reply was received
2016-11-16 21:48:14.096 Detail, Node001, Message transaction complete
2016-11-16 21:48:14.096 Detail, contrlr, Removing current message
2016-11-16 21:48:14.096 Detail, Notification: ControllerCommand - Waiting
2016-11-16 21:48:22.895 Detail, Received: 0x01, 0x07, 0x00, 0x4b, 0x21, 0x02, 0x00, 0x00, 0x90
2016-11-16 21:48:22.895 Info, FUNC_ID_ZW_REMOVE_NODE_FROM_NETWORK:
2016-11-16 21:48:22.895 Info, REMOVE_NODE_STATUS_NODE_FOUND
2016-11-16 21:48:22.895 Detail, Notification: ControllerCommand - InProgress
2016-11-16 21:48:23.994 Detail, Received: 0x01, 0x1a, 0x00, 0x4b, 0x21, 0x03, 0x00, 0x13, 0x04, 0x07, 0x01, 0x5e, 0x20, 0x25, 0x30, 0x71, 0x70, 0x85, 0x80, 0x5a, 0x59, 0x73, 0x98, 0x86, 0x72, 0xef, 0x20, 0x21
2016-11-16 21:48:23.994 Info, FUNC_ID_ZW_REMOVE_NODE_FROM_NETWORK:
2016-11-16 21:48:23.994 Info, REMOVE_NODE_STATUS_REMOVING_SLAVE
2016-11-16 21:48:23.994 Warning, Remove Node Failed - NodeID 0 Returned
2016-11-16 21:48:23.994 Detail, Notification: ControllerCommand - Failed
2016-11-16 21:48:23.997 Detail, Received: 0x01, 0x1a, 0x00, 0x4b, 0x21, 0x06, 0x00, 0x13, 0x04, 0x07, 0x01, 0x5e, 0x20, 0x25, 0x30, 0x71, 0x70, 0x85, 0x80, 0x5a, 0x59, 0x73, 0x98, 0x86, 0x72, 0xef, 0x20, 0x24
blackdog65
Re: zwave: trouble including devices
Post by blackdog65 »
Hi Thelure,
when including a new z-wave device, I always exclude it 1st. With many devices this does a reset and clears the device data as far as I know (open to correction here). Then I find the inclusion process is always much smoother.
Sometimes a device can be a real pain and needs exclude/include 2 - 3 times before it settles in.
Also distance can be a factor. When I was running a Razberry, I would take it and the RasPi to the new device (as close as a lead would allow) to do the exclude/include.
Good luck
Sean
CubieTruck Master
RasPi slaves
EQ3 MAX!
TKB Sockets
RFXCOM
MySensors
ESPEasy ESP8266-12E
Thelure
Post by Thelure »
Thank you for the reply!
The devices are very close to each other when I'm testing, I keep them on my desk so I've tried holding them right next to each other, It does not seem to make any difference. I've been going at this a few more hours now since my post (including completely reinstalling raspian and domoticz) but no progress.
I have spent most time trying to include this Telldus door/windows sensor:
http://products.z-wavealliance.org/products/1455
Could the communication be running on the wrong baudrate? What baudrate is the communication on the GPIO serialport to the razberry board?
I'm trying to narrow down if the problem is with the razberry board or my zwave units. Is there any way in domoticz to verify the communication with the razberry board is correct? It seems to be detected correctly as it says:
Z-Wave.Me RaZberry Controller 2016 ZWave+
Type: 0x0400
This is correct, yes?
I've noticed I sometimes get **TODO: handle response for 0x12** Please report this message.
This is the log from the "Send Node Information" command:
2016-12-08 19:46:32.274 Detail, Node001, Queuing (Controller) Send Node Information
2016-12-08 19:46:32.274 Info, Sending a node information frame
2016-12-08 19:46:32.274 Detail, Node001, Queuing (Command) ControllerCommand_SendNodeInformation (Node=1): 0x01, 0x06, 0x00, 0x12, 0x01, 0x25, 0x0b, 0xc4
2016-12-08 19:46:32.274 Detail, Notification: ControllerCommand - Starting
2016-12-08 19:46:32.275 Detail,
2016-12-08 19:46:32.275 Info, Node001, Sending (Command) message (Callback ID=0x0b, Expected Reply=0x12) - ControllerCommand_SendNodeInformation (Node=1): 0x01, 0x06, 0x00, 0x12, 0x01, 0x25, 0x0b, 0xc4
2016-12-08 19:46:32.282 Detail, Node001, Received: 0x01, 0x04, 0x01, 0x12, 0x01, 0xe9
2016-12-08 19:46:32.282 Info, **TODO: handle response for 0x12** Please report this message.
2016-12-08 19:46:32.749 Detail, Node001, Received: 0x01, 0x05, 0x00, 0x12, 0x0b, 0x01, 0xe2
2016-12-08 19:46:32.750 Info, Node001, WARNING: ZW_SEND_NODE_INFORMATION failed. No ACK received - device may be asleep.
2016-12-08 19:46:32.750 Warning, Node001, WARNING: Device is not a sleeping node.
2016-12-08 19:46:32.750 Detail, Node001, Expected callbackId was received
2016-12-08 19:46:32.750 Detail, Node001, Expected reply was received
2016-12-08 19:46:32.750 Detail, Node001, Message transaction complete
2016-12-08 19:46:32.750 Detail, Node001, Removing current message
2016-12-08 19:46:32.750 Detail, Notification: ControllerCommand - Failed
Users browsing this forum: Google [Bot], willemd and 1 guest
