wunderground error
- Domoticz version: Stable
wunderground error
After updating to the last beta is get the error:
2016-11-15 18:20:45.059 Error: WUnderground: Invalid data received, or no data returned!
But when using the test from the wiki with the api key and location it is working fine.
Any idea what is going wrong ?
Ubuntu server, Raspberry Pi, PiFace 2, RFXCom, Z-wave Stick, Kaku, Sensor
- Siewert308SW
Re: wunderground error
Same here,gennapium wrote:Hi,
Sollution is to change your weather station name.
Before updating i used IGRONING16 as station id.
I changed it to pws:IGRONING16 under Settings->Hardware->your weatherunderground station
Setup:
- RPi4 - Domo Stable / Aeotec Z-stick7 / PiHole Unbound Gemini
- RPi4 - PiHole / PiVPN Unbound Gemini
- Synology DS923+ / DS218j
- P1 Gas/Power, SmartGateway watermeter
- Fibaro switches, contacts, plugs, smoke/Co2 ect
- rootfs @ USB HDD
- rootfs @ USB HDD
I use gennep (my hometown) as location, setting it to pws:Gennep doen't do the trick. Also just updated to 3.5921. Also not the solution.
Great,
Just updated location to pws:IHEIJEN2 and now it is working !!
- Siewert308SW
Gennep is a global name and when used it will seek the nearnest station.gennapium wrote:I use gennep (my hometown) as location, setting it to pws:Gennep doen't do the trick. Also just updated to 3.5921. Also not the solution.
New beta forces to use one station instead of several.
So you need the pws id for you station which is not gennep
for example:
pws:ILIMBURG180
edit: see you already found the right pws id...
Setup:
- rootfs @ USB HDD
- rootfs @ USB HDD
- Grobbebol
- Domoticz version: 2021.1
Thanks for the tip..
I had the same problem after the update. Changed "Veendam" to pws:IGRONING56 under "Instellingen"-> Hardware -> Weather Underground and than the tab "Locatie". Everything OK now.
Raspberry Pi B+ -- RFXtrx 433MHz -- OpenThermMonitor -- Growatt PV monitor -- Alecto WS-3500 -- MySensors
Lightning and heating/ventilation done with "Action" 433Mhz wall plugs, and MySensors nodes.
- Domoticz version: LastBeta
good evening,
i take the same solution, but in the log i have always the same error:
now i setting the psw:IBERGAMO2
in the log i find the follow error:
"2016-11-27 00:46:17.407 Error: WUnderground: Invalid data received, or no data returned!"
my version is the latest beta i find V3.5985
tomorrow i control the log again. bye bye.
Master (pi3) - MB sensors + Dummy + Sysfs gpio + 1 NodOn MSP-3 + 1 Aeotec DSB28 Energy Meter + 3 Danfoss RS Room + 7 Danfoss Z Thermostat + 1 Swiid Inter + 9 FGS222
Slave01 (pi2) - MB sensors + Dummy + Weather Underground + 2 FGS223 + 1 FGWPE/F
- bizziebis
- Domoticz version: 3.8805
WU is not reliable anymore for the last month. If they don't get their system sorted out we better search for an alternative.
It should be PWS in stead of PSW.
Verzonden vanaf mijn iPad met Tapatalk
schulpr wrote:It should be PWS in stead of PSW.
i control my log now, and after the modifie apported during this night, from about after 30 min the error log disappared and all work ok.
- Domoticz version: BETA
OWM ...bizziebis wrote:WU is not reliable anymore for the last month. If they don't get their system sorted out we better search for an alternative.
Is stable to..
I'm using pws:IARNHEM39, but have two questions about this.
1. I noticed some error messages "Error: WUnderground: Error: this key does not exist". But system is also retrieving correct data. How can I find which device (Temp/UV/Visability) is related to this error?
But in the logging I noticed that, at least some data is retreived.
2. In the Domoticz WIKI is mentioned that data is retrieved once in 10 minutes. I my logging it seems to several times within 1 minute (I got warning email from WUnderground). I could not find how to reduced this amout of requests. Can someone point me how to change this interval?
