Hello all, I'm busy with a script and I need to parse some json data.
I do also is on request on my smartmeter and it gives a nice output. From the data field I would like to split the value after the ";" can someone guide me in how to do that with jQ parser?
I now have .result[] ."Data"
It gives me "433777;877448;0;0;488"
But I only want the first value, so I need to cut it or split it after every ";".
But I can't seem to get it right in jqplay.org
Anyone who could help me with it?
Parsing JSON with JQ
- galadril
- Domoticz version: latest
Re: Parsing JSON with JQ
is it a python script?
or bash?
tim = '16:30:10'
hrs, mins, secs = tim.split(':')Code: Select all
#!/usr/bin/env bash
IN="[email protected];[email protected]"
mails=$(echo $IN | tr ";" "\n")
for addr in $mails
do
echo "> [$addr]"
doneSolar panels of Ginlong, Omnik-Solar, Transenergy or Solarman?? Try my Android app:
oopee
- Domoticz version: 3.x
I use curl and jq in a bash script like this:
temperature1=$(/usr/bin/curl -S -s 'http://dom.ipa.ddr.ess:8080/json.htm?type=devices&rid=172' | /home/pi/jq-1.5/jq -r .result[]."Temp")Re: Parsing JSON with JQ
I use it in a bash script, but now I've got jq result[].Data | cut - d ";" -f1
It gives me the first value of "12345;67892;112233;2234;0"
So it gives "12345
I'm a bit further now I only need to lose the first ".
But how?
So it gives "12345
But how?
Ahh I got it, it's :
jq -r .result[]Data | cut - d ";" -f1
So it's the -r that does the trick, don't know why yet. Have to figure out from the manual.
Thanks for the efforts.
VladGets
if you are interested in this questions, you can read more this blog http://djangostars.com/blog/python-in-a-1000-words/galadril wrote:is it a python script?
or bash?Code: Select all
tim = '16:30:10' hrs, mins, secs = tim.split(':')
#!/usr/bin/env bash IN="[email protected];[email protected]" mails=$(echo $IN | tr ";" "\n") for addr in $mails do echo "> [$addr]" done
