Fibaro Wall Plug
mrhedstrom
Domoticz version: 3.4834
Fibaro Wall Plug
Post by mrhedstrom »
I installed my new Fibaro Wall Plug today and had some problems.
1) When installing I got 4 new devices in Domoticz. One for the switch (Lighting 2), two energy meters (Usage Electric) and one energy counter (Energy CM119 / CM160). The energy counter has both actual energy use (in Watts) and historical energy consumption (in kWh). Is it supposed to show 4 devices?
2) I couldn't get the Network Range Tester to work with the wall plug. It didn't find any network in test mode. But obviously it is within range when in normal mode.
3) I can't get an event in blocky to work with any of the three energy devices. I'm trying to set up a notification if switch is on and energy below 65 W. But it doesn't work.
Blocky event
Blocky event
mrhedstrom
Re: Fibaro Wall Plug
3) It seems like the blocky event sends notification when using the historical energy consumption device. It has both W and kWh readings. But it does only update during polling so there is a gap between the switch on and when the Actual energy for the device gets a reading. So every time the switch turns on it generates a notification (or several until the device gets a energy reading).
Dejvidno1
Post by Dejvidno1 »
Hej,
I can answer 1). I was getting 4 devices but now only get 3. It seems I'm not getting the counter with counted kWh history anymore. I get two identical Meters and one switch.
It worked in a previous version of Domoticz but lost it when I built 2.4384 or when I did a reset of the plugs. It also worked in the Razberry application.
Dejvidno1
Post by Dejvidno1 »
Ah...found it. The counter was disabled, found the activation under the Setup/Hardware for the wall plug.
poelguedj
Post by poelguedj »
Since a few days, I am trying to setup my new domoticz system with my Fibaro wall plugs.
I have tried firstly in Windows but like Dejvidno1 , I had only 3 devices instead of 4 : two devices were corresponding to "Immediate Power" (type/subtype = Usage/Electric in Watt) and the third was corresponding to the switch (type/subtype = Lighting 2/Zwave).
But I was unable to activate the 4th device corresponding to the counter of energy in Kwh.
I have installed Domoticz on a Raspberry Pi2 but I have the same result than in Windows.
After reading the last post of Dejvidno1, I have tried to go in Setup/Hardware and I have clicked on the Setup Button for my Zwave controller (Z Stick Gen5) and then I have selected the nodeID correspopnding to my fibaro plug but I dont see any parameter that could activate this counter.
Could you help me ?
Though, when I click on the button "Node Management" and then select "Control Panel", I obtain a page entitled "OpenZWave Control Panel" and if I select my Fibaro device, I can see the value corresponding to the Energy that has been counted by the device since I have begin to use it.
So why this value is not available in the device list in Domoticz ? How ca I add it ?
My version of domoticz is 2.3530 on the raspberry pi and 2.4078 in Windows
Thank you for your help
Dejvidno1
Post by Dejvidno1 »
Unfortunately I misunderstood the configuration settings. It was parameter 49 in the configuration that I activated, but that only activates the metering of the plugs own consumption. I also activated parameter 1 ("Always on").
I thought that I would see the plugs counter update when the plug was updating, but it never did. So I haven't found a solution. I'm thinking of doing a hard reset of the plugs and maybe try to add them again. Last step would be to try a different version of Domoticz but I rather not...
Dejvidno1
Post by Dejvidno1 »
I updated to V2.4547 and now the counter seems to work. But sometimes I get strange readings from the power meter, like its missing measuring values. The update intervals probably needs some tweaking.
Gravityz
Domoticz version: 2025.1
Post by Gravityz »
i also have problems sometimes when reading out the actual status.
when the device is on sometimes the powerreading goes to 0
the only way i got it fixed is turn on enable polling on al my devices.
