I have a RPi2, Tellstick Duo and a "Remote temp sensor"
I have done all the installation (Domoticz SD-card image domoticz-raspberrypi-sdcard-4834.img )
Run apt-get update and upgrade.
Installed Tellstick, by instruction of itslav(blogg.itslav.nu/?p=875)
Have added Tellstick in Domoticz. Setup-Hardware-Tellstick
But no sensors show up.
When running "tdtool --list" in putty i get values from 2 sensors like this
SENSORS:
PROTOCOL MODEL ID TEMP HUMIDITY RAIN WIND LAST UPDATED
mandolyn temperaturehumidity 52 20.8° 22% 2016-11-11 08:49:37
mandolyn temperaturehumidity 32 -19.4° 23% 2016-11-11 08:49:58
I would really appreciate if someone can help me to solve this problem. (I´m a newbie to work with Domoticz)
Regards,
Micke
Remote tempsensor doesn´t show up in Domoticz
- emme
- Domoticz version: latest
Re: Remote tempsensor doesn´t show up in Domoticz
is ACCEPT NEW HARDWARE Option ticked ON under Config/Settings?
"We always done this way"
Yes, it is.
I click on Red button "Allow for 5 Minutes" but still no sensors.
i have the same problem with 2 devices working with rfxcom, one temperature sensor and other DIO contact, have others but are working.
has been working since time with no problem but since 2 last beta update has disappear and only can see on device tab and are working, at main plants cant see.
if i put on other plant it appear only main plant nothing.
thanks
thanks
I think it's s Tellstick issue (I'm using Tellstick myself and can only get switches to work by using dummy-switches, that executes a shell script to toggle the switches - I wonder if you must use similar approach to read sensor values
Do yo get any log data from Domoticz?
Some links to help you further:
viewtopic.php?t=10090
http://dev.fredrikjohnsson.se/home-auto ... -domoticz/
