Great, HansLe!HansLe wrote:YEEEEEEESSSSS! I'm able to use TTS on a RPI. As you can read Thorjb had some problems. I had the same. This problem exist when you don't use a file share but you use your RPI as place to read and find the MP3 files. I hope G3rard will change the following recommendations in the source files. If not you can do it by yourself after downloading these file![]()
Now is EasySonos Easy
I gave up on this project, but no I'll give it a try again
