Yes, I cannot seem to receive the state using any command and see no changes in the logs either.. If I'm able to get the status (and write that status away in the switch) I can integrate it with the rest of my automation in Domoticz.dynasticorpheus wrote:Sorry what script do you mean? The script I have running checks every minute the state of the system (Home/Away/Custom) and puts the selector switch in the same postition. This is the one you also want?Kwintessens wrote:
Wherever I can help let me know.Care to share your script? I think firing it off from a button press instead of scheduled job would definitely work for me as a workaround.
Gigaset Elements Cli - domoticz support
Kwintessens
Re: Gigaset Elements Cli - domoticz support
dynasticorpheus
- Domoticz version: 2.3295
Kwintessens wrote:Yes, I cannot seem to receive the state using any command and see no changes in the logs either.. If I'm able to get the status (and write that status away in the switch) I can integrate it with the rest of my automation in Domoticz.dynasticorpheus wrote:Sorry what script do you mean? The script I have running checks every minute the state of the system (Home/Away/Custom) and puts the selector switch in the same postition. This is the one you also want?Kwintessens wrote:
Sorry took a while to find some time. You need to adjust the config part ofcourse. This script assumes no password is required to access domoticz. If needed you can whitelist the local IP address or any other ip (range) this avoid auth. (settings --> Local Networks (no username/password)
The scripts sets a cookie in the temp dir specified so it only needs to authenticate with the gigaset elements servers every 6 hours. This makes the script quicker and prevents hammering their servers
Make sure it works by changing the alarm modus via de gigaset elements website and running the script manually. Once this is the case you can schedule a cron job which runs every minute. There is also a LUA script somewhere here on this forum which allows you to schedule jobs every 1,5 etc minute. I personally use that one because than the script only runs when domoticz is up and running.
Of course this needs to be added to the cli when running in domoticz mode but lacking time at the moment but it's def on my to-do list
#!/bin/sh -e
##########################CONFIG#############################################
[email protected]
PWD=mybigsecret
IP=127.0.0.1
PORT=8080
IDX=112
TMPDIR=/tmp
##########################URL################################################
URL_ID=https://im.gigaset-elements.de/identity/api/v1/user/login
URL_AUTH=https://api.gigaset-elements.de/api/v1/auth/openid/begin?op=gigaset
URL_BASE=https://api.gigaset-elements.de/api/v1/me/basestations
echo
echo Gigaset Elements Modus Curl-Cli version 0.1
echo
MODUS="unset"
LEVEL="$(curl -s "http://$IP:$PORT/json.htm?type=devices&rid=$IDX" | jq '.result[0].Level' | tr -d "'")"
if test `find "$TMPDIR/gse_expire" -mmin +355`; then
echo cookies older than 6 hours so deleting
rm -f $TMPDIR/gse_cookies
fi
if [ ! -f $TMPDIR/gse_cookies ]; then
echo [-] authenticating
touch $TMPDIR/gse_expire
curl -siSL --user-agent 'Mozilla/5.0' --insecure --cacert $TMPDIR/gse_expire --cookie $TMPDIR/gse_cookies --cookie-jar $TMPDIR/gse_cookies --data email=$EMAIL --data password=$PWD $URL_ID
curl -siSL --user-agent 'Mozilla/5.0' --insecure --cacert $TMPDIR/gse_expire --cookie $TMPDIR/gse_cookies --cookie-jar $TMPDIR/gse_cookies -H "Accept: application/json" -H "Content-Type: application/json" -X GET $URL_AUTH
echo "[-] pre-authenticated"
fi
MODUS="$(curl --insecure --cacert $TMPDIR/gse_expire -siSL --tlsv1 --ipv4 --user-agent 'Mozilla/5.0' --cookie $TMPDIR/gse_cookies --cookie-jar $TMPDIR/gse_cookies -H "Content-Type: application/json" -X GET $URL_BASE | sed -e 's/[{}]/''/g' | awk -v k="text" '{n=split($0,a,","); for (i=1; i<=n; i++) print a[i]}' | grep active_mode | cut -d '"' -f6)"
echo "[-] current modus $MODUS"
echo "[-] current level $LEVEL"
if [ "$MODUS" = "home" -a $LEVEL != "0" ]; then
ADJLEVEL=0
elif [ "$MODUS" = "custom" -a $LEVEL != "10" ]; then
ADJLEVEL=10
elif [ "$MODUS" = "away" -a $LEVEL != "20" ]; then
ADJLEVEL=20
echo "[-] update of selector switch not needed"
echo
exit;
fi
echo "[-] settting selector switch to $MODUS (level $ADJLEVEL)"
curl -s "http://$IP:$PORT/json.htm?type=command¶m=udevice&idx=$IDX&nvalue=1&svalue=$ADJLEVEL"
curl -s "http://$IP:$PORT/json.htm?type=command¶m=addlogmessage&message=(Gigaset%20Elements)%20$MODUS%20Modus%20Detected%20(Gigaset%20Elements)"
echo
exit;
- gse_syncmodus.zip
- (1.07 KiB) Downloaded 119 times
dynasticorpheus
Kwintessens wrote:Wherever I can help let me know.dynasticorpheus wrote:Thanks for the feedback!Kwintessens wrote:
Thanks you so much.
Everything's running smoothly for the past couple of weeks. Now I am trying to automate a little bit more and thinking of ideas how to do so.
I want to control more scripts and lighting on the basis of my home or away state. It doesn't seem to be possible to monitor mode from an event in the CLI.
I am currently setting my away mode from gigaset button on double press, and home mode from single press. The problem with this is that double-presses are not recognized as such (logs all show single press).
I don't think I should need an additional gigaset button to set alarm in addition to my current button.. so am I missing some logic here?
As workaround I currently have a curl script running every minute which updates the base selector switch to the current state should however be implemented in the CLI itself of courseDon't have too much time at the moment but I will put in on my to-do list.
We should probably also use a selector switch for button so we can differentiate between the actual press. From there we can assign an action to the respective level. Again I will put it on my to-do list.
00 Off 10 Short -------> gigasetelements-cli --modus home 20 Long 30 Longer 40 Double -------> gigasetelements-cli --modus awayCare to share your script? I think firing it off from a button press instead of scheduled job would definitely work for me as a workaround.
Work in progress ... actually not to much code to change to make this work ... will test a bit more tonight
Kwintessens
Great!!dynasticorpheus wrote:Kwintessens wrote:Wherever I can help let me know.dynasticorpheus wrote:
I am running the script after button push (to avoid cronjob) as this is my single source of status change, but not ideal because it doesn't distinguish between types of push, so that update is welcome!
The coming days I will tie my plugs, lights and robotic vacuum to my away mode
dynasticorpheus
Is the bash/curl script I shared earlier working for you? (will be the next thing I am going to add to the cli so in the end we don't need it anymore)Kwintessens wrote:Great!!dynasticorpheus wrote:Kwintessens wrote:
The coming days I will tie my plugs, lights and robotic vacuum to my away mode.
Kwintessens
Yes, it's working fine.. I just edited the states to positions 10, 20 and 30 as 0 state is off to me.dynasticorpheus wrote:Is the bash/curl script I shared earlier working for you? (will be the next thing I am going to add to the cli so in the end we don't need it anymore)Kwintessens wrote:Great!!dynasticorpheus wrote:
dynasticorpheus
You can test the button selector switch by installing below branch and update the config file so button is linked to the newly created selector switch:Kwintessens wrote:Yes, it's working fine.. I just edited the states to positions 10, 20 and 30 as 0 state is off to me.dynasticorpheus wrote:Is the bash/curl script I shared earlier working for you? (will be the next thing I am going to add to the cli so in the end we don't need it anymore)Kwintessens wrote:
Great!!
git clone -b 14-button https://github.com/dynasticorpheus/gigasetelements-cli.git
cd gigasetelements-cli
pip install -r requirements.txt
python setup.py install --force-
Kwintessens
Encountering the following error:dynasticorpheus wrote:You can test the button selector switch by installing below branch and update the config file so button is linked to the newly created selector switch:Kwintessens wrote:Yes, it's working fine.. I just edited the states to positions 10, 20 and 30 as 0 state is off to me.dynasticorpheus wrote:
Let me know if it also works ok for youCode: Select all
git clone -b 14-button https://github.com/dynasticorpheus/gigasetelements-cli.git cd gigasetelements-cli pip install -r requirements.txt python setup.py install --force
I think it has to do something with a missing dependency? I think I've encountered this before but I don't remember how I solved it./etc$ gigasetelements-cli -ss
File "/bin/gigasetelements-cli", line 11, in <module>
load_entry_point('gigasetelements-cli==1.5.0b2', 'console_scripts', 'gigasetelements-cli')()
File "/usr/lib/python2.7/site-packages/pkg_resources/__init__.py", line 564, in load_entry_point
return get_distribution(dist).load_entry_point(group, name)
File "/usr/lib/python2.7/site-packages/pkg_resources/__init__.py", line 2621, in load_entry_point
return ep.load()
File "/usr/lib/python2.7/site-packages/pkg_resources/__init__.py", line 2281, in load
return self.resolve()
File "/usr/lib/python2.7/site-packages/pkg_resources/__init__.py", line 2287, in resolve
module = __import__(self.module_name, fromlist=['__name__'], level=0)
File "build/bdist.linux-armv7l/egg/gigasetelements/gigasetelements.py", line 20, in <module>
File "/usr/lib/python2.7/site-packages/pushbullet/__init__.py", line 2, in <module>
from .pushbullet import Pushbullet
File "/usr/lib/python2.7/site-packages/pushbullet/pushbullet.py", line 8, in <module>
from .filetype import get_file_type
File "/usr/lib/python2.7/site-packages/pushbullet/filetype.py", line 12, in <module>
import magic
File "/usr/lib/python2.7/site-packages/magic.py", line 150, in <module>
dll = ctypes.util.find_library('magic') or ctypes.util.find_library('magic1') or ctypes.util.find_library('cygmagic-1')
File "/usr/lib/python2.7/ctypes/util.py", line 242, in find_library
raise RuntimeError("can not find library %s" % name)
RuntimeError: can not find library magic
dynasticorpheus
Did you also run?Kwintessens wrote:Encountering the following error:dynasticorpheus wrote:You can test the button selector switch by installing below branch and update the config file so button is linked to the newly created selector switch:Kwintessens wrote: Yes, it's working fine.. I just edited the states to positions 10, 20 and 30 as 0 state is off to me.
return ep.load()
import magic
pip install -r requirements.txt-
Kwintessens
I am running it on a Synology.. and I did install requirements.. it even says that all requirements are satisfied.dynasticorpheus wrote:Did you also run?Kwintessens wrote:Encountering the following error:dynasticorpheus wrote:
return ep.load()
import magic
I am guessing it's missing python-magic which should be installed when running above command. If this somehow does not work perhaps you can install it with your regular package install tool? What OS are you running?Code: Select all
dynasticorpheus
Below will get you back on the master or develop branch whilst we get this sorted.
git clone -b master https://github.com/dynasticorpheus/gigasetelements-cli.git
dynasticorpheus
I updated the code to lazy load the pushbullet module meaning that you most likely will not have this error as long as you do not use the --notify option. (or have a pushbullet token in the config file)Kwintessens wrote:I am running it on a Synology.. and I did install requirements.. it even says that all requirements are satisfied.dynasticorpheus wrote:Did you also run?Kwintessens wrote:
Please install the updated code and let me know if this helps for now. You should still try to solve the issue as other programs relying on python-magic will also fail I guess.
Kwintessens
It works now, but with -ss I still get the following errors, indeed related to pushbullet. Doesn't matter to me since it works just fine.. I've tried to resolve the python-magic before but was unsuccessful (see below).
Have yet to test the button in combination with the home/away modes.. What did you change in this version compared to the previous one? Then I know how to test your new additions to it
File "build/bdist.linux-armv7l/egg/gigasetelements/gigasetelements.py", line 764, in main
File "build/bdist.linux-armv7l/egg/gigasetelements/gigasetelements.py", line 740, in base
File "build/bdist.linux-armv7l/egg/gigasetelements/gigasetelements.py", line 444, in pb_message
import magic
dynasticorpheus
I have optimized the code so it really does not depend on the pushbullet module unless actually sending a notification. Should already have been like this so thanks for reportingKwintessens wrote:It works now, but with -ss I still get the following errors, indeed related to pushbullet. Doesn't matter to me since it works just fine.. I've tried to resolve the python-magic before but was unsuccessful (see below).
Have yet to test the button in combination with the home/away modes.. What did you change in this version compared to the previous one? Then I know how to test your new additions to it.
import magic
Button now needs to point to a selector button as it differentiates between the different kind of presses. From there you can attach actions to them using standard Domoticz functionality.
See below for my setup:
and the log entries:
Kwintessens
Great! It works like a charm, and the error is gone nowdynasticorpheus wrote:I have optimized the code so it really does not depend on the pushbullet module unless actually sending a notification. Should already have been like this so thanks for reportingKwintessens wrote:It works now, but with -ss I still get the following errors, indeed related to pushbullet. Doesn't matter to me since it works just fine.. I've tried to resolve the python-magic before but was unsuccessful (see below).
import magic
RuntimeError: can not find library magicPlease reinstall and let me know if you are now error free.
Do you advise an off delay of 2 seconds? It seems to work just fine without delay. I have never understood the 'very long' push, how many seconds is that?
Anyway, I'll start integrating everything now and share later
dynasticorpheus
I guess it is required once you start attaching activities to a button press because otherwise is detects the specific press over and over? (in reality you also release the button and it returns to unpressed status) Experiment a bit and use what works best for you I would sayKwintessens wrote:
Anyway, I'll start integrating everything now and share later. Again, great work!
Long press is like 2 seconds and very long like 5 seconds or more ...
Now thinking how to best implement to update the current modus using the selector switch, the actual updating is not the problem but we have now 2 domoticz sensors for base (alert/selector) which I would like to merge into one if possible ...
Kwintessens
I understand what you're saying for that is a more elegant way.. From a Gigaset Elements point of view (as seen in the app) these are different.. The base state is more related to status of sensors and intrusion, whereas the other is simply the away state. If you're trying to combine the two I am not sure how you will be able to use it for both showing and setting the state.dynasticorpheus wrote: Now thinking how to best implement to update the current modus using the selector switch, the actual updating is not the problem but we have now 2 domoticz sensors for base (alert/selector) which I would like to merge into one if possible ...
Small update on my part:
I wasn't able to have the button trigger the bash script of checking/setting gigaset mode directly.. So I made small lua script that does the same
The domoticz capabilities were the sole reason I invested in this system so it's awesome that everything is coming together now..
dynasticorpheus
Ok next round, I have updated the code and it now syncs the modus selector switch every 60 seconds. Just add the idx to the base sensor in your config file like below example. First the idx of the alert than the selector idx. (I also updated the instructions in gigasetelements-cli.conf.template)Kwintessens wrote:
I wasn't able to have the button trigger the bash script of checking/setting gigaset mode directly.. So I made small lua script that does the same. It works perfectly now, and I think it is a more elegant way than setting it directly on action. Since the button is my single point of changing state I also think this lua script is better than a timed one
F32A76C4DHJ1B743A0E0D74EFD2375D1=98,96Code: Select all
git clone -b 12-base https://github.com/dynasticorpheus/gigasetelements-cli.git
Kwintessens
I'll test ASAP. What is the benefit of syncing it every 60 seconds over having it sync on my button press (which means it only triggers that curl script 2-3 times a day), other than that it will also sync if status is changed from other source? Just wondering, as I might want to limit unnecessary server calls when my girlfriend and me are at work all day.dynasticorpheus wrote:Ok next round, I have updated the code and it now syncs the modus selector switch every 60 seconds. Just add the idx to the base sensor in your config file like below example. First the idx of the alert than the selector idx. (I also updated the instructions in gigasetelements-cli.conf.template)Kwintessens wrote:
Then install below branch for testing ... (dont forget to disable the curl/cron script as we don't need it anymore)Code: Select all
Let me knowCode: Select all
git clone -b 12-base https://github.com/dynasticorpheus/gigasetelements-cli.git cd gigasetelements-cli pip install -r requirements.txt python setup.py install --force
Few automations I have done so far:
-Lua script on single button tap (come home) that turns on single light IF time is not between sunrise and sunset: Someone comes home in the dark and disarms the alarm (or alarm is disarmed but it is still dark because someone is asleep).
- Lua script on Home mode: Turn on wemo switch for Gigaset Camera when away, turn off when home.
- Lua script on Home mode: Turn off TP-link switch when away (set top box and other random electronics that don't need power when away)/Enable when home.
Future:
- Set schedule to clean up/mop my home with robo vacuum with validation if I'm away.
- Set custom mode for sleeping
- Other cool ideas?
dynasticorpheus
Still testing a bit but next version will allow setting the API polling interval for new events and the interval for status/health syncKwintessens wrote:
Future:
- Other cool ideas?
O and ... send the robo vauum to my house as well please
