I quite new to Domoticz and RFX433e.
My problem is I cant get my Nexa power outlets to show up corect in Domoticz.
How do I read the codes between the outlet and the remote? Is there a software (the one at RFCCOM website wasn't able to download)?
How to read codes
stormychel
Re: How to read codes
on Domoticz go to Setup->Hardware, click the Set Mode button on your RFXCOM device in the list, then enable all protocols, click Set Mode.
Now go to the Switches tab, click Learn Light/Switch and press the button on your remote. If the command is received, a new window will pop up which will let you add that code to Domoticz.
If this does not work, you need the RFXmngr app from the RFXCOM site, which gives all information about received codes in a window, including the needed protocol.
Uhm I have a projecta screen, it works with 433 mhz. I tried rfxmngr on a computer with the Rfxtrx433e installed. However when i push the remote i see nothing? All protocolls are enabled. Or do I have to push receive somewhere? I dont understand I see nothing happening. What options do I have?
Verzonden vanaf mijn iPad met Tapatalk
stormychel
Did you push 'set mode' after selecting all protocols?
