homebridge-edomoticz Plugin
- TheRamon
- Domoticz version: BETA
Re: homebridge-edomoticz Plugin
If they are off, an on command is sent following a dimmer command. If they were already on, only a dimmer command is sent.
I'm guessing you don't have the right version, even though it says you're up to date. Try removing the folder with rm. Then in the node_modules folder type:
git clone https://github.com/PatchworkBoy/homebri ... moticz.git
simon_rb
- Target OS: -
Ok, the first time I did it I got loads of stuff come up saying what had changed lol so I think it is the right version.TheRamon wrote:If they are off, an on command is sent following a dimmer command. If they were already on, only a dimmer command is sent.
rom https://github.com/PatchworkBoy/homebridge-edomoticz
2cd5432..72068b5 master -> origin/master
Updating 2cd5432..72068b5
Fast-forward
CHANGELOG | 16 +-
InstallGuide | 60 +-
LICENSE | 19 +-
README.md | 33 +-
index.js | 1363 ++++-----------------------------------------
lib/constants.js | 33 ++
lib/domoticz.js | 112 ++++
lib/domoticz_accessory.js | 1218 ++++++++++++++++++++++++++++++++++++++++
lib/helper.js | 101 ++++
lib/mqtt.js | 85 +++
lib/services.js | 290 ++++++++++
package.json | 7 +-
12 files changed, 2036 insertions(+), 1301 deletions(-)
create mode 100644 lib/constants.js
create mode 100644 lib/domoticz.js
create mode 100644 lib/domoticz_accessory.js
create mode 100644 lib/helper.js
create mode 100644 lib/mqtt.js
create mode 100644 lib/services.js
simon_rb
- Target OS: -
Deleted the folder but I can't clone the repo now.. tried
git clone -b https://github.com/PatchworkBoy/homebri ... moticz.git
Doesn't work? Have I missed something
UPDATE:-me being a twat lol its sudo git clone https://github.com/PatchworkBoy/homebri ... moticz.git
simon_rb
- Target OS: -
is sudo npm update -g homebridge-edomoticz the correct master branch? or do I need to clone the repo?
- TheRamon
The master branch is good yeah. Mqtt-integration doesn't exist anymore
Just a simple git clone (URL) must work.
simon_rb
- Target OS: -
I've done the Sudo above but haven't cloned yet. With the master branch above I'm still getting an on command then the value with my dimmers. Whether it's via Siri or via the slider...
@TheRamon
"More iOs 10 problem:" -> today I moved my whole installation to my Ubuntu server (from rPi). We will see if it is happens again. It worth to enable the MQTT?
The updated version should fix my problem too /dimmer/?
No output from the update command. Maybe I have the latest version (I installed around 12:00)?
Current state:
Siri Turn the LED off => works
Siri Turn the LED on => works
Siri set LED to 100% (LED was ON) => dim command -> then on command => NOT OK
Siri set LED to 100% (LED was OFF) => dim command -> then on command => NOT OK
Home app => OK, after choosing the value it sends the dim command only.
@ubuntu:~$ sudo npm update -g homebridge-edomoticz
@ubuntu:~$
Current state:
Nautilus
Yes, this sounds very logicalTheRamon wrote: Yeah, I had to fall back to http for colour changing. MQTT does not support that yet. Dimming works through MQTT though so that's why it's sending level 100 through MQTT.
thom
- Domoticz version: 5837
Sorry to insist, but I try very Hard, and that never work...
thom wrote:Sorry, I try to reinstalled the Homebridge with MQTT, but I don't understand the way to have the broker running. I installed the MQTT Client in my Domoticz /Hardware. I put this config.json:simon_rb wrote:@Thom
Your config file is wrong. Are you using the latest plugin, if you are you need the MQTT info in their too and make sure you have a broker running and that you have added it to Domoticz under the hardware..
The result of npm run start:Code: Select all
{ "bridge": { "name": "Homebridge", "username": "B8:27:EB:0C:D1:C6", "port": 51826, "pin": "031-45-154" }, "description": "Configuration file for (e)xtended Domoticz platform.", "platforms": [ { "platform": "Homebridge", "name": "Homebridge", "server": "127.0.0.1", "port": "8080", "ssl": 0, "roomid": 2, "mqttenable": 1, "mqttserver": "127.0.0.1", "mqttport": "1883", "mqttauth": 0, "mqttuser": "", "mqttpass": "" } ], "accessories": [] }and the result of home bridge command:Code: Select all
pi@raspberrypi:~/.homebridge$ npm run start npm ERR! Linux 4.4.26-v7+ npm ERR! argv "/usr/local/bin/node" "/usr/local/bin/npm" "run" "start" npm ERR! node v4.2.1 npm ERR! npm v2.14.7 npm ERR! missing script: start npm ERR! npm ERR! If you need help, you may report this error at: npm ERR! <https://github.com/npm/npm/issues> npm ERR! Please include the following file with any support request: npm ERR! /home/pi/.homebridge/npm-debug.logThank you for the support.Code: Select all
pi@raspberrypi:~$ homebridge *** WARNING *** The program 'node' uses the Apple Bonjour compatibility layer of Avahi. *** WARNING *** Please fix your application to use the native API of Avahi! *** WARNING *** For more information see <http://0pointer.de/avahi-compat?s=libdns_sd&e=node> *** WARNING *** The program 'node' called 'DNSServiceRegister()' which is not supported (or only supported partially) in the Apple Bonjour compatibility layer of Avahi. *** WARNING *** Please fix your application to use the native API of Avahi! *** WARNING *** For more information see <http://0pointer.de/avahi-compat?s=libdns_sd&e=node&f=DNSServiceRegister> [Sun Nov 06 2016 16:05:49 GMT-0500 (EST)] Loaded plugin: homebridge-edomoticz [Sun Nov 06 2016 16:05:49 GMT-0500 (EST)] Registering accessory 'homebridge-edomoticz.eDomoticz' [Sun Nov 06 2016 16:05:49 GMT-0500 (EST)] Registering platform 'homebridge-edomoticz.eDomoticz' [Sun Nov 06 2016 16:05:49 GMT-0500 (EST)] --- [Sun Nov 06 2016 16:05:49 GMT-0500 (EST)] Loaded config.json with 0 accessories and 1 platforms. [Sun Nov 06 2016 16:05:49 GMT-0500 (EST)] --- [Sun Nov 06 2016 16:05:49 GMT-0500 (EST)] Loading 1 platforms... /usr/local/lib/node_modules/homebridge/lib/api.js:118 throw new Error("The requested platform '" + name + "' was not registered by any plugin."); ^ Error: The requested platform 'Homebridge' was not registered by any plugin. at API.platform (/usr/local/lib/node_modules/homebridge/lib/api.js:118:13) at Server._loadPlatforms (/usr/local/lib/node_modules/homebridge/lib/server.js:281:45) at Server.run (/usr/local/lib/node_modules/homebridge/lib/server.js:77:36) at module.exports (/usr/local/lib/node_modules/homebridge/lib/cli.js:40:10) at Object.<anonymous> (/usr/local/lib/node_modules/homebridge/bin/homebridge:17:22) at Module._compile (module.js:435:26) at Object.Module._extensions..js (module.js:442:10) at Module.load (module.js:356:32) at Function.Module._load (module.js:311:12) at Function.Module.runMain (module.js:467:10)
Rpi 2 Domoticz 5837
Mysensors Temp and Hum, Relay
Zwave.me, garage Door, light, Motion, Stelpro, temp Hum
simon_rb
- Target OS: -
@Thom
Try npm uninstall -g edomoticz or npm uninstall -g homebridge-edomoticz
then
npm install -g homebridge-edomoticz
then
thom
Thank you very much simon_rb, I try but I have the same result.
Error: The requested platform 'Homebridge' was not registered by any plugin.Code: Select all
pi@raspberrypi:~$ sudo npm uninstall -g edomoticz
npm WARN uninstall not installed in /usr/lib/node_modules: "edomoticz"
pi@raspberrypi:~$ sudo npm install -g homebridge-edomoticz
npm WARN deprecated [email protected]: ReDoS vulnerability parsing Set-Cookie https://nodesecurity.io/advisories/130
[email protected] /usr/lib/node_modules/homebridge-edomoticz
├── [email protected]
├── [email protected] ([email protected], [email protected], [email protected], [email protected], [email protected], [email protected], [email protected], [email protected], [email protected], [email protected], [email protected], [email protected], [email protected])
└── [email protected] ([email protected], [email protected], [email protected], [email protected], [email protected], [email protected], [email protected], [email protected], [email protected], [email protected], [email protected], [email protected], [email protected], [email protected], [email protected], [email protected], [email protected], [email protected], [email protected])Rpi 2 Domoticz 5837
- TheRamon
Check your config file. The plugin is not called homebridge. It's called eDomoticz. Change that and it'll work.
@simon_rb, hpapagaj:
I'll have a look at Siri!
NewFolk
Hope for release soon.TheRamon wrote: Yeah, I had to fall back to http for colour changing. MQTT does not support that yet. Dimming works through MQTT though so that's why it's sending level 100 through MQTT.
Is it posable to disable MQTT by config?
what does this setting does?
"mqttenable": 1Code: Select all
User: Admin initiated a switch command - TheRamon
It is always worth it to enable mqtt. Fast response times and all.hpapagaj wrote:@TheRamon
I _thought_ your problem was fixed with the latest version. (Git)
But there are reports that version is not working yet. So I'm going to try to reproduce the bug by tracing what happens when dimming a light through Siri. If the "on" command is sent, I'll look where it comes from.
simon_rb
- Target OS: -
Even using the slider within Home App iOS 10 shows an on command sent each time?? Strange eh
- TheRamon
Please see the issue on GitHub:
https://github.com/PatchworkBoy/homebri ... /issues/57
I have just fixed the dimming issue (kind of a workaround) on master.
Please git pull
Please git pull
- TheRamon
@bdormael:
Please see this issue on GitHub:
https://github.com/PatchworkBoy/homebri ... /issues/58
I have just pushed a new version to Git, could you please check and see if your issue with the SecPanel has been resolved?
simon_rb
- Target OS: -
Genius! My dimmers are working with Siri and the sliders in iOS 10 Home app!!! Whoop Whoop!TheRamon wrote:@simon_rb, hpapagaj:
Please git pull
Last edited by simon_rb on Tuesday 08 November 2016 19:34, edited 3 times in total.
dfranco
Hi all after installing my homebridge I’m getting the follow error:
/home/pi/domoticz/homebridge/node_modules/homebridge-edomoticz/index.js:1107
motionService.getCharacteristic(new Characteristic.StatusLowBattery()).on('get', this.getLowBatteryStatus.bind(this));
TypeError: Cannot read property 'on' of undefined
at Object.eDomoticzAccessory.getServices (/home/pi/domoticz/homebridge/node_modules/homebridge-edomoticz/index.js:1107:89)
at Server._createAccessory (/home/pi/domoticz/homebridge/lib/server.js:375:36)
at Server.<anonymous> (/home/pi/domoticz/homebridge/lib/server.js:361:32)
at /home/pi/domoticz/homebridge/node_modules/hap-nodejs/lib/util/once.js:15:19
at callbackLater (/home/pi/domoticz/homebridge/node_modules/homebridge-edomoticz/index.js:425:37)
at Object.<anonymous> (/home/pi/domoticz/homebridge/node_modules/homebridge-edomoticz/index.js:451:17)
at Request.self.callback (/home/pi/domoticz/homebridge/node_modules/homebridge-edomoticz/node_modules/request/request.js:198:22)
at emitTwo (events.js:87:13)
at Request.emit (events.js:172:7)
at Request.<anonymous> (/home/pi/domoticz/homebridge/node_modules/homebridge-edomoticz/node_modules/request/request.js:1082:10)
Any idea?
Any idea?
NewFolk
Is Npm version the same to Git master branch?
